The Flying Krawler
Discussion in '2nd Gen. Builds (2005-2015)' started by BradyT88, Nov 19, 2012.
  1. Dec 29, 2015 at 8:15 AM
    #301
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    How bout when you get another 1gr, build it up a wee bit before it goes in?
  2. Dec 29, 2015 at 8:18 AM
    #302
    BradyT88
    BradyT88 [OP] Well-Known Member
    Used to have it all laid out. Got tired of keeping it up to date, plus it's kind of like a grocery list for potential theft. Though I keep mine in my garage now so it's a bit safer I guess.
    I'll answers questions about stuff you want to know specifically though.
  3. Dec 29, 2015 at 8:21 AM
    #303
    BradyT88
    Forged internals? haha. I don't think it's worth sleeving... Last I knew that was about $10K itself... Maybe @Torspd will part with Goldylocks when his stroker is done;)
  4. Dec 29, 2015 at 8:22 AM
    #304
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    if u supercharged a new 1gr i would think ud have more then enough power..
  5. Dec 29, 2015 at 8:33 AM
    #305
    BradyT88
    Maybe. I've rode in a few stock TRD S/C'd trucks and wasn't that impressed with the extra power. Though adding a smaller pulley would certainly help, but reliably you are looking at about 350 RWHP from a 1GR with a TRD S/C. A stock L92 is probably about 350 RWHP (403 HP at the crank). The L92 stock internals are good for up to 600HP and a lot of guys are getting 500RWHP out of them by just adding the Corvette intake and a little more aggressive tune. The difference in RWHP between the 2 setups is almost as much as my stock 1GR is putting down at the wheels!:eek: There's no replacement for displacement! 6.2L > 4.0L
    Plus that 6L80E is a much tougher trans, I would have a lower 1st gear and a higher overdrive, plus the Tcase will be stronger and lower geared than my Taco Tcase.
  6. Dec 29, 2015 at 8:40 AM
    #306
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    yeah for sure.. are the toyota frames strong enough for that?? :eek:
  7. Dec 29, 2015 at 8:46 AM
    #307
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sleeving is only about $2200. Not cheap, but definitely not crazy expensive either. LCE could do that work for you. Get some JE or CP pistons ($800 - 1100) and some Molnar rods (~$700) , like @armyoffoo and you'd be done.
    If the sleeves aren't needed, then rods and pistons. Engine build can be cheap or expensive. You just have to weigh all of your options and time frames. Then go from there.
    First and foremost is clearly knowing the full extent of damage, to determine how much work is needed.
    Weighing everything includes doing a swap. As that might be preferable. There are many more in's and out's to those. So a lot more has to be considered. No forgetting fitments, and what possible work arounds to be able to keep all desired drive components. Keep in mind, which every way is chosen, the money to be spent, along with how long it will take, add up very quickly in the small details and parts.
    A comprehensive outline is the most effective tool in helping you decide which path to take, as well as all of the associated costs. Then you'll have it right in front of you.
  8. Dec 29, 2015 at 9:03 AM
    #308
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh. I might part with Goldylocks. I have no definitive plans other than restoration and proof of power. My stroker isn't all that far behind in terms of being completed. So I'll just use Goldy for the time being. Dyno her up, and wait for the beast to show up. :D
    BradyT88[OP] likes this.
  9. Dec 29, 2015 at 9:05 AM
    #309
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Dec 29, 2015 at 9:06 AM
    #310
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    :popcorn: Sorry about the engine man. It's not a good feeling when shit goes south :laugh:. Can't wait to see the route you go.
  11. Dec 29, 2015 at 9:08 AM
    #311
    BradyT88
    Well Tor's frame is still alive and he hit 475 at the wheels! I'd bet I have a lot more steel welded onto mine than he does.
    Yeah I am sorting of working that out. It's all the fine details of what will be needed for an LS swap that are hard to work out. As for time, it could be unlimited. The Taco is just for wheeling, We have another truck and a car for DD's plus dirt bikes for offroading. I'd just be missing rock crawling and snow wheeling.
  12. Dec 29, 2015 at 9:24 AM
    #312
    BabyTaco
    Wyoming
    2011 RC Tacoma
    A little motivation for your dream. I vote LS swap...cause power.
    https://youtu.be/GIQn8pab8Vc
    BradyT88[QUOTED][OP] likes this.
  13. Dec 29, 2015 at 10:08 AM
    #313
    BradyT88
    I could potentially do an Atlas 4spd Tcase with the LS swap too! If I do the 11.7:1 low I'd be geared a little lower than a Taco running a 4.7:1 crawlbox in compound low!:eek:
  14. Dec 29, 2015 at 10:49 AM
    #314
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  15. Dec 29, 2015 at 11:23 AM
    #315
    BradyT88
  16. Dec 29, 2015 at 11:43 AM
    #316
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    i feel like you might even be able to pick up a used atlas fairly easily if u look hard enough.
  17. Dec 30, 2015 at 8:03 AM
    #317
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    And 549 WTQ. :burnrubber:
  18. Dec 30, 2015 at 8:05 AM
    #318
    BradyT88
    Nobody cares about Torque! It's all about that peak HP number ;) haha
  19. Dec 30, 2015 at 9:50 AM
    #319
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  20. Dec 30, 2015 at 10:06 AM
    #320
    BradyT88
    :bikewhoops:
