The Flying Krawler
Discussion in '2nd Gen. Builds (2005-2015)' started by BradyT88, Nov 19, 2012.
  1. Jan 3, 2016 at 9:42 PM
    #321
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    I like ls route
    If i got my hands on another 2nd gen id be doing a ls swap!
  2. Jan 4, 2016 at 5:35 PM
    #322
    Manwithoutaplan
    ID
    When does this Frankenstein build come alive again.
  3. Jan 4, 2016 at 5:54 PM
    #323
    BradyT88
    BradyT88 [OP] Well-Known Member
    I don't know... I'm still stuck trying to decide. Which isn't a bad thing since it lets me build up some money for it...
    Just some rough numbers, but... (in order of most HP to least)
    LS Swap:
    6.2L ~$3500
    6L80E ~$2200
    Tcase ~$500 unless I go Atlas now then $4000
    plus another $5000 in all the other shit I will need for the swap...
    Total: $12000 - $15000
    Built 1GR (assuming mine is salvagable):
    Bore and sleeve: $2200
    Pistons, rods, maybe a crank: $2000-$3000
    Some sort of boost down the road: $7000
    Total: $12000 - $13000
    New crate motor:
    Remanned 1GR $2500
    $500 for misc stuff
    Total: $3000
    AR15xAR10 likes this.
  4. Jan 4, 2016 at 5:55 PM
    #324
    Manwithoutaplan
    ID
  5. Jan 5, 2016 at 9:29 AM
    #325
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    If you want reliable power ls swap
    Technically you could the extras much cheaper than you think, you can get the same power out of a 6.0 hell even a 5.3
    Id go the route of a write off truck and pulling everything you need
    That way you have a wiring harness already ;)
  6. Jan 20, 2016 at 11:06 AM
    #326
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Well, now that I am kind of in your position...I fully understand your struggle of making this decision. After seeing prices of swapping in the same motor it seems stupid to spend the money on something that didn't make you happy before. I am looking at 2-3 grand without labor to replace the 2tr-fe. If I pony up and toss in an extra 3-4 grand I can have the power and reliability I want. I vote LS swap...or a cheaper swap that still has promising power.
    My engine likely only has a leaking piston ring. Which mean I can do an overhaul when it's out of the truck and sell it to regain cost. Decisions...
    BradyT88[OP] likes this.
  7. Jan 20, 2016 at 1:14 PM
    #327
    BradyT88
    Yep... for me the part that makes the decision the hardest is having to swap the trans and all. If I could reliably bolt my trans to an LS I wouldn't think twice about another 1gr. The problem is I don't think my trans would last long behind an LS... not the 6.2L anyway...
  8. Jan 20, 2016 at 10:06 PM
    #328
    Manwithoutaplan
    ID
    This thing alive yet :p
  9. Jan 21, 2016 at 9:02 AM
    #329
    BradyT88
    Nope... haven't done anything. Just waiting on money.
  10. Jan 21, 2016 at 10:13 AM
    #330
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    how long do you plan to keep your tacoma? 13k seems like a shit load to throw at a somewhat older truck, would u be able to recoup some of the money if it ever came time to sell it?
  11. Jan 21, 2016 at 2:56 PM
    #331
    BradyT88
    Indefinitely! I'm way too deep into it now to ever recoup anything... It'll just become some shit like this if I ever trash it bad enough!
    I already have another DD and a full size truck plus my wife has her DD. The Taco is literally just a toy. If worse comes to worse you can always move engine and suspension and shit to a new tube frame/chassis.
    AR15xAR10 and BabyTaco like this.
  12. Oct 18, 2016 at 2:15 AM
    #332
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  13. Oct 20, 2016 at 11:18 AM
    #333
    BradyT88
    :boink:
  14. Oct 23, 2016 at 1:47 PM
    #334
    TonyDobbs
    TonyDobbs Well-Known Member
    Tony
    Cotati, CA
    2012 LT TRD OR + 2007 TRD Sport
    So... decide on an engine yet? :)
  15. Oct 25, 2016 at 6:36 PM
    #335
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Brady!!
    Long time no see.....i miss you in the funny pics thread.
    Surely youve got quite the bank built up.
    :thumbsup:
  16. Oct 25, 2016 at 6:40 PM
    #336
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    braaaaaaaaaaaaaaaaaaaaaaaaaady
    ImplicitlyAlberta likes this.
  17. Oct 25, 2016 at 6:44 PM
    #337
    AR15xAR10
    i vote LS3 or bust
  18. Oct 26, 2016 at 9:39 AM
    #338
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
  19. Oct 26, 2016 at 10:26 AM
    #339
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  20. Oct 26, 2016 at 11:47 AM
    #340
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Maybe Brady is trying to recover from the TW addiction? Or maybe he's built his Ford by now and he's on the f150 forums :rofl:
