The Flying Krawler
Discussion in '2nd Gen. Builds (2005-2015)' started by BradyT88, Nov 19, 2012.
  1. Dec 30, 2014 at 8:48 PM
    #61
    Manwithoutaplan
    ID
    what brand type were those gears?
  2. Dec 30, 2014 at 8:55 PM
    #62
    BradyT88
    BradyT88 [OP] Well-Known Member
    ECGS uses nitros for their assembled diffs.
  3. Dec 30, 2014 at 9:00 PM
    #63
    Manwithoutaplan
    ID
    ok that is what i have. Installed by Yotamasters.
  4. Dec 30, 2014 at 9:39 PM
    #64
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    :sorry: i'm the noob here
  5. Dec 30, 2014 at 10:30 PM
    #65
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    For what? Please.
  6. Dec 30, 2014 at 10:35 PM
    #66
    AR15xAR10
    Learning through silly questions. :D
    Been a lot of it from me lately
  7. Dec 30, 2014 at 10:42 PM
    #67
    Idaholandho
    No one cares. Those that might, fuck em. Follow me around throughout a day in the life.
  8. Jan 6, 2015 at 3:32 AM
    #68
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I like this "action" build thread. :thumbsup: You have similar wheeling interests that I do. I just subscribed to your on Youtube. I wish I had good videographers and photographers who wheeled with me in my area.
  9. Jan 6, 2015 at 8:09 AM
    #69
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Hey! So I picked up Steves ORIs and they seem to be holding up fine now. I'm trying to get a list of things needed for them.
    Would a 5lb tank be big enough for them? It didn't look like we used much when setting everything up and I want to save bed space where I can. Also, what fittings do you use on your tank?
  10. Jan 6, 2015 at 8:46 AM
    #70
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    FYI Brady, Gage only needed 600 psi to get the same lift he had with the old coilovers!
  11. Jan 6, 2015 at 9:21 AM
    #71
    BradyT88
    Nitrogen is rated by volume not weight and I don't think a 5lb equivalent would get you more than a few fills from empty... Do you know what pressure they put in them to get you to the ride height you wanted?
    I bought a 125 cu ft bottle. I was talking with the guy at Air Gas and he was stunned that I was going to be using 800-900 psi and was worried that I would kill off a bottle very quickly. They fill the bottles to 2000 psi. Once I drop below 800 psi I can't fill my shocks anymore... So I use about half the bottle and I can't use the other half... I filled my shocks up around 20 times each maybe less and I've used about a 1/4 of the bottle.
    Since the volume of the shocks is so small though I think I could have got away with a smaller bottle. I wish I had got an 80 cu ft because it would fit in the bed better. I usually throw my 125 cu ft in the back seat and leave it at camp, but I'm not real worried about my shocks leaking out on me.
    You could pick up a 5lb and it would be a nice trail tank though for emergencies.
  12. Jan 6, 2015 at 9:33 AM
    #72
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Ya I forgot about the cu ft. Thanks for the info! And for the see below to answer your question.
  13. Jan 6, 2015 at 9:34 AM
    #73
    SconnieHailer
    Marc
    Derp, Gage beat me to it :D
  14. Jan 6, 2015 at 9:41 AM
    #74
    BradyT88
    Wow that's so crazy. How much pressure was in the lowers? And when you filled the lowers were they installed? The more pressure you put in the lower the more you have to put in the upper.
    At 700 psi my rig doesn't even move upwards with 120 in the lower installed. I think I run about 2" of lift and have to use 850-900 psi.
  15. Jan 6, 2015 at 5:01 PM
    #75
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I dont think Marc messed with the lowers so not sure. He might though.
    What regulator did you get? Monte was saying they couldnt find one that went high enough so they didnt have one?
  16. Jan 7, 2015 at 12:31 PM
    #76
    Manwithoutaplan
    ID
    The truck all ok now?
  17. Jan 7, 2015 at 2:08 PM
    #77
    BradyT88
    I got this one. It says it only goes to 800 psi but mine will go to 900. Sometimes it will run out of adjustment around 600-700 psi so if I back it off a couple turns; turn the bottle off and then drain the regulator it will go up to 900 again. I think it does that if you turn it down too far since it doesn't stop spinning in the off direction.
    http://www.amazon.com/Turbotorch-03...1&keywords=TurboTorch+0386-0857+DP250-800-580
    JW had an old nitrogen regulator lying around and he tore it apart and used adapters to just hook the fill kit straight to the bottle. I tried to get Air Gas to just sell me the adapter but they wouldn't do it for safety reasons...
    Nope. The third was supposed to get to ECGS tomorrow but UPS says it has been delayed due to bad weather.
  18. Jan 7, 2015 at 2:09 PM
    #78
    Manwithoutaplan
    ID
    are the warranty the work?
  19. Jan 7, 2015 at 2:33 PM
    #79
    BradyT88
    huh? haha
  20. Jan 7, 2015 at 2:37 PM
    #80
    AR15xAR10
