The Flying Silver Brick build and FOS thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Texoma, Mar 26, 2018.
How do you feel about this thread
  1. It's OK
    75.5%
  2. This thread sucks
    16.3%
  3. Center Hoop only
    6.1%
  4. Add Headlight hoops
    0 vote(s)
    0.0%
  5. Fuck some damn hoops
    0 vote(s)
    0.0%
  6. Your full headlight hoops look stupid, but I like it
    4.1%
Multiple votes are allowed.
  1. Apr 6, 2018 at 8:42 AM
    #41
    Texoma
    Texoma [OP] IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    130 amp should be a direct swap with the 80 amp that is there. All connections and mounts are the same, so I'm really hoping there's no belt alignment issue.
  2. Apr 6, 2018 at 11:21 AM
    #42
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    for mine it was the sleeve on the alternator that the bolt passed through. was about 1/8-1/4 inch shorter than stock. The pulley was the same diameter though so the belt was same size. I did a gm cs130 alternator and also needed a new pigtail adapter. But maybe that's a first gen thing. can't say for sure on yours.
    MattCowsmasher and ChadsPride like this.
  3. Apr 6, 2018 at 11:39 AM
    #43
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Mine should be a direct replacement as they came with 80amps for non tow package and 130amps with tow package. Hoping.
  4. Apr 6, 2018 at 11:53 AM
    #44
    Misplaced Nebraskan
    Zach
    Austin
    Good deal. Not that it was difficult by any means to make it work, but a direct 1 for 1 swap is always a plus! :fingerscrossed:
  5. Apr 7, 2018 at 5:28 PM
    #45
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    In
    ChadsPride likes this.
  6. Apr 10, 2018 at 7:07 AM
    #46
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Got the new Alternator and Starter installed this past Sunday. Old alternator was putting out 4-5 amps. I'm gonna put the amp clamp on the new one and check its output. All in all, it's an upgrade from the 100amp alternator now at 130amps. Pro tip, once the alternator is torqued to spec, make sure the pulley turns. Had an issue where the slide nut didn't slide and bound the alternator up to where it wouldn't turn. So removed and jammed some antiseize in the slide nut and cycled it a few times, good to go now.
  7. Apr 10, 2018 at 7:09 AM
    #47
    Misplaced Nebraskan
    Zach
    Austin
    Straight 1 for 1 swap on 2nd gen?
  8. Apr 10, 2018 at 7:41 AM
    #48
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yup, but I feel the need to upgrade the fuse block to battery wire as it's a little thin.
  9. Apr 10, 2018 at 7:41 AM
    #49
    ChadsPride
    Sponsored by TacomaWorld.com
  10. Apr 10, 2018 at 7:42 AM
    #50
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
  11. Apr 10, 2018 at 7:43 AM
    #51
    ChadsPride
  12. Apr 10, 2018 at 7:49 AM
    #52
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    :cheers:
  13. Apr 10, 2018 at 7:49 AM
    #53
    riz_atx
    Sohail
    Spicewood Texas
  14. Apr 10, 2018 at 7:50 AM
    #54
    ChadsPride
  15. Apr 10, 2018 at 7:58 AM
    #55
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    :mudding:
  16. Apr 10, 2018 at 7:59 AM
    #56
    riz_atx
    Sohail
    Spicewood Texas
  17. Apr 10, 2018 at 8:04 AM
    #57
    ChadsPride
  18. Apr 10, 2018 at 8:07 AM
    #58
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    :welder::itllbuffout:
  19. Apr 10, 2018 at 8:10 AM
    #59
    ChadsPride
  20. Apr 11, 2018 at 3:32 PM
    #60
    pheerles
    pheerles Well-Known Member
    Rosemead, CA
    '15 Access Cab 4x4
    Yo Tex, I saw your post about preferring BAMF's HD Shackle mount over the ATO Shackle Flip. Can you elaborate on why? I've got the same rear setup as you, albeit with APExpo leafs instead of your Dakars, and different shocks of course. Thanks in advance
