The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Nov 2, 2012 at 6:06 PM
    #1981
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you the only member? :rolleyes:
    Still...nice recognition tho. :thumbsup:
  2. Nov 2, 2012 at 6:27 PM
    #1982
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lol I guess so haha
  3. Nov 3, 2012 at 7:03 PM
    #1983
    Blackdawg
    Monte
    Wyoming/St. Louis
    My latest project.
    Cut up
    Coooolll
    This one is cut a little nicer haha
    Drying
    More to come
  4. Nov 3, 2012 at 7:06 PM
    #1984
    Madjik_Man
    Colorado Front Range
    F that.
    TRAITOR :mad:
    :p
  5. Nov 3, 2012 at 7:08 PM
    #1985
    Blackdawg
    Monte
    Wyoming/St. Louis
    Traitor??
    Yea I can't wait to see how it turns out. Should fill the voile of blackness right off the side good.
  6. Nov 3, 2012 at 7:09 PM
    #1986
    Madjik_Man
    Hey Monte
    When your new project is all done, do you mind detailing how you run the wire from the mirror housing to the sail?
    Like I said in the other thread, I'm trying to run a heating element to the back of the glass and can't remove that honeycomb (for lack of a better term) piece. And I'm pretty sure there's no way to run wires without removing it, right?
    Thanks.
  7. Nov 3, 2012 at 7:10 PM
    #1987
    Madjik_Man
    TW :(
  8. Nov 3, 2012 at 7:22 PM
    #1988
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea man ill take more pics when I do that.
    Nah I hardly post over there.
  9. Nov 3, 2012 at 7:27 PM
    #1989
    Slodgetto
    Slodgetto Über Posre
    Silas
    Yeah, congrats on TTORA rig of the month!!! :cool:
    And now I see what you're doing with the mirrors. Sweet idea!!!
  10. Nov 3, 2012 at 7:28 PM
    #1990
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man!
    And yea I'm interested to see how it turns out. Hopefully not too bad.
  11. Nov 4, 2012 at 10:39 AM
    #1991
    losers101
    losers101 Well-Known Member
    Brandan
    Texas
    2004 Dbl Cab 4x4
    Starting fresh :)
    Did your tires rub when you first put your wheels on? Or did you leave the spacers on the whole time? I'm looking to get 33x12.5 with 4.0 backspacing wheels
  12. Nov 4, 2012 at 12:17 PM
    #1992
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Cool idea, kinda like the FJ mirrors. I like it!
  13. Nov 4, 2012 at 1:15 PM
    #1993
    Blackdawg
    Monte
    Wyoming/St. Louis
    well 33s will rub pretty much no matter what..i had to do the pinch weld mod big time. I never did any super hard core wheeling though with the 4'' BS. I do know that the owner of my rims and tires did and it rubbed on the frame pretty bad. So he used 1'' spacers up front.
    I just decided to go ahead and use mine and instead of buying new 1'' ones just reused my 1.5'' ones. Now..i like the look :D haha
    thanks man!!
    im excited to see the results. its coming along..
    :spy:
  14. Nov 4, 2012 at 1:37 PM
    #1994
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Doesn't look bad at all!
  15. Nov 4, 2012 at 1:50 PM
    #1995
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Holy crap monte that's bad ass!! Much props on the featured rig! You should get some sponsorships lol!
    God you are a genius!
  16. Nov 4, 2012 at 3:18 PM
    #1996
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Clever idea!
  17. Nov 4, 2012 at 3:21 PM
    #1997
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea it's a bit different but I think it's kinda cool
    Yep. Plus with my bed lights and the side lights and rock lights...it'll be day light for setting up camp :p
    Thanks Mark!!
    And I suppose I have a good idea or two haha
    Thanks!
    Wiring as we speak
  18. Nov 4, 2012 at 8:46 PM
    #1998
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Clever idea on the lights man, ive been looking at a way to build a small bracket from the bottom of it that could hold a light but i kinda like this way more.
  19. Nov 4, 2012 at 9:40 PM
    #1999
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea it was. Good idea haha blew up in my face not 10 mins ago. Literally finished wiring it and flipped on the switch to see both lights on(I'd had the drivers side done for a while) and nearly burned the truck down. My dad and I were baffled at this. Could not for the life of us figure out what had happened.
    But being its late and I was sick of working on it. I just left the truck half tore open and the battery disconnected till tomorrow where I can redo it all.
    I sure hope I didn't kill the lights though..I have no more mirrors left and no more lights :eek:
  20. Nov 4, 2012 at 9:46 PM
    #2000
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    That sucks man lol hopefully you didnt royally fuck anything up
