The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Nov 4, 2012 at 10:13 PM
    #2021
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    All part of learning :) still can't believe I fucked this up..was real excited to have something so unique done!
  2. Nov 4, 2012 at 10:19 PM
    #2022
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's coming together damnit!! Lol
  3. Nov 4, 2012 at 10:25 PM
    #2023
    Blackdawg
    Monte
    Wyoming/St. Louis
  4. Nov 4, 2012 at 10:25 PM
    #2024
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Your description of what just transpired suggests otherwise. :D
  5. Nov 4, 2012 at 10:29 PM
    #2025
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    :rofl:
  6. Nov 4, 2012 at 10:32 PM
    #2026
    Blackdawg
    Monte
    Wyoming/St. Louis
    :brianr:
  7. Nov 4, 2012 at 10:33 PM
    #2027
    Blackdawg
    Monte
    Wyoming/St. Louis
  8. Nov 4, 2012 at 10:34 PM
    #2028
    Drunknsloth
    Retribution
    South West
    Just thought of something, if all your wiring checks out maybe the internals of one of the lights is mis-wired. I would try testing that on a fused power source too.
  9. Nov 4, 2012 at 10:35 PM
    #2029
    Blackdawg
    Monte
    Wyoming/St. Louis
    I tested the lights when I first got them. Worked lovely.
  10. Nov 4, 2012 at 11:38 PM
    #2030
    Blackdawg
    Monte
    Wyoming/St. Louis
    Reassembly!
    Glass backer
    All screws a torqre T10s
    two up here.
    Two at the base.
    This is the joint assembly. I forgot to show another part of it though. Its sitting on the top part of the door mount
    Mirror side of joint before insert
    after insert
    There then goes another plastic half sphere then the door mount
    then the smaller plastic half sphere
    before
    after
    next the bolt.
    there is a washer on the bottom, then spring, then washer, then bolt.
    torque to desired torque. The more you tighten, the harder it is to move the mirror..
    put plastic cover over bolt. There is one T10 torque screw as well
    here was my first way of routing the wire to the door..
    as you can see and why i didn't notice at first, the gasket would squish the wire. I need the wire to come out up by the bolts..easy fix.
    so i cut a notch to let the wire up higher into the gasket.
    put a new hole in the gasket and viola!
    driver side done :D
    Both done!
    Test fit..looks cool
    NOT AGAIN!
    yay light!
    then of course it went down hill when i added the second light..oh well. Ill get em up and running with in the week. Should be cool!
    The lights can piviot 100% like stock which will allow me to use them as sort of spot lights if i wish. I mostly want them for a kind of fill light up the front side of my truck. That way when i get some bigger LED bars for the side of the roof i should have a good 180* slight line of good light. But thats a different project for later.
  11. Nov 5, 2012 at 6:25 AM
    #2031
    Madjik_Man
    Colorado Front Range
    Geez... that would have been horrible.
    You would have eventually had to make a, "the life, death, resurrection, death, and reincarnation of my truck" thread.
  12. Nov 5, 2012 at 6:31 AM
    #2032
    Madjik_Man
    Nice write up/pics
    So I guess there's no way to run the wires internally the whole way to the sail panel? That's where I am getting hung up with my project. I see you just diverted trying to go through that joint by running the wire around it on the exterior.
    While it's not horrible looking, I'd still want to see if there's a way to run it through the mirror internally the whole way.
  13. Nov 5, 2012 at 8:28 AM
    #2033
    Blackdawg
    Monte
    Wyoming/St. Louis
    I thought about it. But to do that and still keep the mobility you'll have to cut two very wide and long notches in all the joint to allow the wire to be there. And there just isn't room for it with the bolt and spring. The way I did it keeps the mobility and it's not two obvious. Yes it's not super clean but it works quite well.
  14. Nov 5, 2012 at 8:40 AM
    #2034
    Madjik_Man
    While not super clean, it is super easy to run the wire(s) like that.
    Thanks Monte.
  15. Nov 5, 2012 at 8:51 AM
    #2035
    Blackdawg
    Monte
    Wyoming/St. Louis
    :thumbsup:
    Hope the pics help
  16. Nov 5, 2012 at 9:13 AM
    #2036
    Madjik_Man
    They do. A lot.
    Hope you realize I'll still be PMing you in a tizzy :thumbsup:
  17. Nov 5, 2012 at 9:22 AM
    #2037
    Blackdawg
    Monte
    Wyoming/St. Louis
    :D no worries man! Here to share information :cool:
  18. Nov 7, 2012 at 10:02 PM
    #2038
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good news! Both lights work!
    Most of the melted wire is on the passenger side so I pulled the light to check the wire..nothing wrong with it. Other then the trailer connector wire being melted a bit like the power wire I soldered to it.
    Alas due to not enough wire and I need another trailer connector I won't be wording them tonight.
    I'm just glad the lights still work.
  19. Nov 7, 2012 at 10:57 PM
    #2039
    Blackdawg
    Monte
    Wyoming/St. Louis
    Decide to throw these in. Very handy I think!
    Ill have two on each side. They are 2 feet long and the tie down points are moveable and there are many different types to get.
  20. Nov 10, 2012 at 4:47 PM
    #2040
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wtf. Why is this so hard?!
    Everything is wired up perfect. Exactly like my light forces...but when I flip the switch..led bars turn on then off after like half a second. They won't stay on!! Daaaa faaaawwwkkkkkk!!!!
