The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Nov 30, 2012 at 4:51 PM
    #2221
    YotaKid62
    YotaKid62 Dirty mall crawler
    Forrest
    North Dakota
    00 Tacoma TRD Sr5 5 speed
    Grey Wire Locker Mod, 3" coil spacers & custom leaf packs, 2" BL, Skyjacker rear nitro shocks, Monroe front gas shocks; 15" eclipse sub & 1400 watt visonik amp with Kenwood stereo, Billet Petals, Black Aries series Grille guard, ebay baja lights (unsure of brand)
  2. Nov 30, 2012 at 4:53 PM
    #2222
    BradyT88
    BradyT88 Well-Known Member
    If that comes with all those switches that is a killer deal.
    EDIT: Just looked that over and I think that is just for a carling switch to replace the ones in the panel. The actual panels run for over $100.
  3. Nov 30, 2012 at 4:54 PM
    #2223
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea I might have to put mine there. But I can't find a rock that'll hold enou switches Haha
    Maybe ill just make my own with toggles. Hopefully I can find some 1/8" steel lying around or something..should have an old license plate somewhere..
  4. Nov 30, 2012 at 4:54 PM
    #2224
    Blackdawg
    Monte
    Wyoming/St. Louis
    No that link is just for a switch haha
  5. Nov 30, 2012 at 4:58 PM
    #2225
    BradyT88
    Yep. Just noticed that. The picture is a lie!! haha
  6. Nov 30, 2012 at 5:31 PM
    #2226
    YotaKid62
    Forrest
    North Dakota
    Well shit, i didnt even notice, but u get the idea.
  7. Nov 30, 2012 at 5:40 PM
    #2227
    YotaKid62
    Forrest
    North Dakota
  8. Nov 30, 2012 at 5:41 PM
    #2228
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not bad that. I don't want the light up switches though..
  9. Nov 30, 2012 at 5:48 PM
    #2229
    YotaKid62
    Forrest
    North Dakota
    If they're anything like the ones i bought you wont have to worry about thay haha. I wanted mine to have a nice glow but theres just a bright yellow light in the square part that doesnt effect the lever part.
  10. Nov 30, 2012 at 6:07 PM
    #2230
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    hey monte, so ur planning on a crawl box.... do u think a crawl box is as streetable as just regearing? im worried the gears will be too lowfor me on the street.... but the crawl box would be slick on the trail obviously. ur thoughts?
  11. Nov 30, 2012 at 6:13 PM
    #2231
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I was under the impression you could switch out of the crawl box like switching out of 4Lo :notsure:
  12. Nov 30, 2012 at 6:15 PM
    #2232
    lotsoftoys
    Jace
    Denver
    bunch of crap
    yeah ur right. its just like a tcase... but im saying. then im trying to spin 33s daily with 4.11s and a manual trans. clutch wont like it much
  13. Nov 30, 2012 at 6:21 PM
    #2233
    Drunknsloth
    Retribution
    South West
    Ah, okay
  14. Nov 30, 2012 at 6:28 PM
    #2234
    BradyT88
    So you are meaning to drive around with the crawl box in low? Well they come in 2 gear ratios, 2.28 and 4.7. Your stock Tcase is already geared at 2.28 so it would be the same as driving every where in 4lo only you would be in 2wd obviously. If you went with the 4.7 it would be even slower. So I would say no it isn't streetable...
    Personally I think regearing is more for driving on the freeway than anything, well and taking off from a stop with a manual. I don't think it affects crawling very significantly and even less if you get a crawlbox, but it helps a ton with driving at higher speeds. With my 33's and 3.73's my automatic would pretty much run in 4th at 75 on the freeway and now with the gears it will rarely shift out of 5th.
  15. Nov 30, 2012 at 6:59 PM
    #2235
    BradyT88
    Yeah, but you are running anorexic tires that aren't that much taller than stock really.
  16. Nov 30, 2012 at 8:48 PM
    #2236
    Blackdawg
    Monte
    Wyoming/St. Louis
    Carl box is more street able. It's selectable so like your locker you can use it when you want.
    Seeing as to how your already locked I see nothing wrong with just getting a crawl box instead of regearing.
    However regearing will help bring back low end torque for just all around driving and it makes the load on the motor lighter.
    Personally I wouldn't waste money for a regear on 33s. 35s I would though.
    But right now I'm happy with driving around on my 4.10s. The thing that kills me is the roof rack and all the drag it adds. Supercharger or turbo is going to be my fix for that.
    So my future setup will be 4.88s gears, 35" tires, crawl box, FAI. 4.88s and 35s is supposed to be close to stock. But I want the lower rpms for hwy driving and the FAI will give me the power to keep it moving.
    It's not the daily driving that'll kill the clutch so much as the crawling around :D haha
    Yep what I'm going to do
    I hope he isn't driving with it engaged haha
    Autos are different too. I think it helps em much more the manuals.
    And nothing a supercharger couldn't have fixed haha
    Granted just getting gears is cheaper then a crawl box and FAI...but hey..pays to play :cool:
  17. Nov 30, 2012 at 8:56 PM
    #2237
    BradyT88
    I think that is what Jace was getting at. Putting the crawl box in low to be like he re-geared.
    Autos are higher geared than manuals since the torque converter works like an extra gear ratio when unlocked so they can produce more torque at the rear wheels than a manual. Because of this they can handle low diff gears without the RPM's going through the roof like the manuals. I think the biggest reason why autos seem to need to regear more often than manuals is because I think the computer gets tripped up from bigger tires and it starts to act kind of funny and shifts down to soon or when not necessary.
  18. Nov 30, 2012 at 9:02 PM
    #2238
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ahhh that could be.
    And I don't think so..well..I'd hope not. That would be odd
  19. Nov 30, 2012 at 9:17 PM
    #2239
    BradyT88
    Hope not about driving in low in the crawl box?
  20. Nov 30, 2012 at 9:24 PM
    #2240
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. Would be like driving around in 4lo all the time basically
