The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jul 31, 2013 at 9:36 PM
    #4301
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you get started on the clutch? I kno you've running around putting out fires all day today. :eek:
  2. Jul 31, 2013 at 10:22 PM
    #4302
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Fires?...ohhhh I see what ou did there :p
    Nope no clutch. Tomorrow is the day I think.
    Just finish the stereo which is awesome. Battery cleaned up. Piaas back in. Figured out how to put em together sorta easy. Bulbs come tomorrow.
    Just mounted my front skid
    048cccde8dd6f9d6e8b5e27348587ba1_zpsb6f3_2ed1f731a0785c8627fcf5257a2a4e3988bed070.jpg
    Which I just realized was probably a waste of time as I have one more cv to do. I got the new seal today. And was going to ad a bit of gear oil...oh well. Ill take it off on the lift tomorrow.
    Now just cleaning stuff up and putting my interior back in and get stuff together.
  3. Jul 31, 2013 at 10:26 PM
    #4303
    Digiratus
    Roaming the PNW
    The RedHead
    that is the best that skid will ever look. :rolleyes:
  4. Jul 31, 2013 at 10:27 PM
    #4304
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why i have a photo :p haha
  5. Jul 31, 2013 at 10:29 PM
    #4305
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    :jellydance:
    I need real skids. Trying to hold out until the FJ Rally on Labor day to see if I can win some...
  6. Jul 31, 2013 at 10:33 PM
    #4306
    Blackdawg
    Monte
    Wyoming/St. Louis
    I still don't have a belly pan..want one out of UHMW or whatever. Just didn't have time.
  7. Jul 31, 2013 at 10:34 PM
    #4307
    PcBuilder14
    Brent
    Nor Cal
    That'll be cool when/if you get a chance to try that. Could probably sell them too... :spy:
  8. Jul 31, 2013 at 10:35 PM
    #4308
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I'd thought about it. Be damn expensive belly skid tho..400 or more. But it's also a tranny skid..so maybe that's reasonable. Idk.
  9. Jul 31, 2013 at 10:37 PM
    #4309
    PcBuilder14
    Brent
    Nor Cal
    Hmm, yeah. But for how lightweight it is I wouldn't think that it's terribly expensive considering regular ones are near the $300 price range.
  10. Jul 31, 2013 at 10:40 PM
    #4310
    Blackdawg
    Monte
    Wyoming/St. Louis
    Idk if it would end up lighter. Not how im gonna do it. But shouldn't be bad.
  11. Jul 31, 2013 at 10:55 PM
    #4311
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hurray!!! Some one can read!!
    Yea. Manual. Way more fun. Makes everything fun.
  12. Jul 31, 2013 at 10:57 PM
    #4312
    PcBuilder14
    Brent
    Nor Cal
  13. Jul 31, 2013 at 10:59 PM
    #4313
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    thank you. was going to mention that, but did not have the stats to back it up. :thumbsup:
    see but that is just a shitty personal opinion. There is nothing fun to be about dealing with a clutch when wheeling. nothing, zero, nada. With my bike...totally different. I get one appendage to one operation. not 2 feet to 3 pedals. thats just retarded. Monte. your argument is shit and based solely on a biased opionion. you are arguing like OZ now. stop.
  14. Jul 31, 2013 at 11:02 PM
    #4314
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wasn't really arguing...I mean I even said I like my auto in my dbl cab..it was you and Brady who rushed in to defend your auto honor haha
    Manuals are fun. And yes. Fun offroad. I offroaded plenty in an auto. I'm not an idiot. I have more time behind the wheel of an auto offroad then you do. I'm well aware of them and their greatness.
    Manuals are more fun.
    Don't like that?
    Then shutup and respect my opinion.
  15. Jul 31, 2013 at 11:03 PM
    #4315
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    no no no no and no :p
  16. Jul 31, 2013 at 11:06 PM
    #4316
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol
    Gtfo loser :p
  17. Jul 31, 2013 at 11:13 PM
    #4317
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Crap are we still talking about this manual vs auto shit!!!
  18. Jul 31, 2013 at 11:28 PM
    #4318
    Blackdawg
    Monte
    Wyoming/St. Louis
    I moved on
    Lets go to LT vs SAS now
    Or turbo vs sc
    Or fat tires vs skinny
    Or plate bumpers vs tube
    Or..
  19. Jul 31, 2013 at 11:31 PM
    #4319
    PcBuilder14
    Brent
    Nor Cal
    I think I've seen nearly all of those arguments on here and involved you... Haha
  20. Jul 31, 2013 at 11:36 PM
    #4320
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
