The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Sep 28, 2013 at 9:31 PM
    #4701
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Okay.. haha long as it wasn't to break em off.
  2. Sep 28, 2013 at 9:34 PM
    #4702
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Fuck no! I have a 2 ft 1x1 square tubing that goes over my 1/2" ratchet for that
  3. Sep 28, 2013 at 9:35 PM
    #4703
    Blackdawg
    Monte
    Wyoming/St. Louis
  4. Sep 30, 2013 at 11:21 AM
    #4704
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Trail gear never replied to my email, so I called them just now. The guy I talked to didn't have a clue as to what the sound might be. He said he has never heard of it. Also said I should pull the tranny back out and inspect the flywheel, clutch plate, and pressure plate
    Edit: I found the paper. Under Diagnosing Bearing Noises, #2 reads:
    2. Pilot Bearing or Bushing
    A. With the engine running, depress the clutch fully
    B. select first gear
    C. Release the clutch. If the squeal is heard at the point of the clutch taking up, then the pilot bearing is faulty. In the event it is a bronze bush, it will indicate lack of lubrication on the I.D. of the bush. If the bush has been lubricated on the I.D., there is a greater possibility that the O.D. of the bush is undersized and worn. The noise then caused by the bush spinning in the end of the crank. If the new pilot bush has not been pressed in evenly, this could also result in the bush spinning, which could cause a grumbling or squealing noise. Pilot bush noises are more apparent when the engine and transmission are cold (i.e. in the morning)
  5. Sep 30, 2013 at 12:13 PM
    #4705
    Blackdawg
    Monte
    Wyoming/St. Louis
    damn dude. :eek: that sucks.
    so gonna pull it??
  6. Sep 30, 2013 at 12:23 PM
    #4706
    TACOMABOSS
    96 SR5 4x4
    I think so. Id rather not leave it. The sound gets really old lol
  7. Sep 30, 2013 at 12:28 PM
    #4707
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i bet its driving you nuts haha id be going crazy haha id have pulled it like the next day haha well..if i could..
    hope nothing super bad is screwed up man..
  8. Sep 30, 2013 at 12:31 PM
    #4708
    TACOMABOSS
    96 SR5 4x4
    Im not sure when im going to pull it though. Its my daily and I have to drive an hour to and from school 2 days a week
  9. Sep 30, 2013 at 12:34 PM
    #4709
    Blackdawg
    Monte
    Wyoming/St. Louis
    ooooo...that does complicate things...
  10. Sep 30, 2013 at 12:38 PM
    #4710
    TACOMABOSS
    96 SR5 4x4
    Quite a bit lol. il have to work something out
  11. Sep 30, 2013 at 12:41 PM
    #4711
    Blackdawg
    Monte
    Wyoming/St. Louis
    well keep me posted on what you figure out.
  12. Sep 30, 2013 at 12:46 PM
    #4712
    TACOMABOSS
    96 SR5 4x4
    Will do thanks for the help
  13. Oct 2, 2013 at 2:54 PM
    #4713
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Monte, I've got a popping sound coming from my front right strut, everything is tight (i'll check torque when the torque wrench comes tomorrow).
    The popping only happens when it flexes, either up or down.
    Could it be coils hitting? I parked the truck with the left front corner up on a small mound, and pushed down on the front right, i couldn't hear anything, but i noticed that the coils where touching when compressed and not touching when not under load.
  14. Oct 2, 2013 at 3:20 PM
    #4714
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your coils are progressive so normal for them to touch.
    Your not the first to mention the piping noise though. I have seen it posted before and actually I have heard it myself from mine. I only heard it actually after I lifted mine and like you only when it would flex.
    I have yet to figure out what it is though :eek:
    I am curious as to if it's due to the fixed top plate of the struts we have and it's the lower bushing perhaps.
    Or a ball joint.
    Either way. Mine has been doing it for years and nothing has exploded...on that side..so :notsure:
  15. Oct 2, 2013 at 3:29 PM
    #4715
    95 taco
    95 taco Battle Born
    That's good to know, thanks.
    How much did you have to flex to get it to pop?
    Mine pops when i go up and down our driveway, which isn't very steep, but it's off camber and going from a incline to a steeper incline.
  16. Oct 2, 2013 at 3:34 PM
    #4716
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I believe on mine its the axle popping.. but been wheeling it for a few years with it clicking and popping and no issues thus far.. OEM axle ftmfw! it started after the boot got a cut in it way after lift so I don't think its the strut, but may be I guess... Mine also does it in the driveway with very minimal flex but enough to cycle the suspension up and down
  17. Oct 2, 2013 at 3:42 PM
    #4717
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea mine didn't need much flex. Usually just a bump.
    I guess it could be the axles..be kinda odd.
    But ya. No issue with mine either haha
  18. Oct 2, 2013 at 8:49 PM
    #4718
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  19. Oct 2, 2013 at 8:59 PM
    #4719
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hey Mike :wave: how's it goin?
  20. Oct 2, 2013 at 9:03 PM
    #4720
    Digiratus
    Roaming the PNW
    The RedHead
    Awesome, except its raining...AGAIN! How about you? Got to do anything fun lately?
    other than TW
