The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Oct 12, 2013 at 8:03 PM
    #4941
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Monte, i think i figured out my noise, i need to retighten where the sway-bar connects to the LCA.
    Not sure if i'm gonna do it tonight, kinda sore from shooting today.
  2. Oct 12, 2013 at 8:44 PM
    #4942
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ahhh could be that.
    i don't have that any more but could be yours.
  3. Oct 12, 2013 at 9:18 PM
    #4943
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Easy fix. Remove the swaybar.
  4. Oct 12, 2013 at 9:20 PM
    #4944
    95 taco
    95 taco Battle Born
    It was, i got my butt in gear and fixed it.
    Can't, i drive it too hard to not have it.
  5. Oct 12, 2013 at 9:22 PM
    #4945
    Blackdawg
    Monte
    Wyoming/St. Louis
    glad you found out what it was.
    I still have a pop and i have long since removed the sway bar.
  6. Oct 12, 2013 at 9:26 PM
    #4946
    95 taco
    95 taco Battle Born
    Thanks, i'm glad i don't have that noise anymore, it was getting annoying.
    eventually the suspension will wear out (or you'll go LT) and it'll get fixed.
  7. Oct 12, 2013 at 9:30 PM
    #4947
    Blackdawg
    Monte
    Wyoming/St. Louis
    i agree. Not worth it on stock suspension. I did it before my eibachs but really i never had stock suspension so..
    yea hopefully it'll work out. Used to the truck making all sorts of noises now haha
  8. Oct 12, 2013 at 9:33 PM
    #4948
    Digiratus
    Roaming the PNW
    The RedHead
    Pretty sure he is installing an OME (?) lift.
    Are you saying you are running your sway bar?
  9. Oct 12, 2013 at 9:35 PM
    #4949
    95 taco
    95 taco Battle Born
    Not yet, i just got some 5100's and i'm happy with them for now, when i get a bumper and/or skids i'm gonna upgrade to either eibachs (cheaper then 883' with shocks) or got MT in the front.
  10. Oct 12, 2013 at 9:42 PM
    #4950
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, If you are still on stock coils, leave it on. When you go to eibacks or 882/883s, at least try it for a while without. I'm betting you'll never put it back on.
    :thumbsup: :rolleyes:
  11. Oct 12, 2013 at 10:28 PM
    #4951
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    What am I thinking haha! I forgot Ian's dad is moving their off road fab shop up here and it should be done over the winter. Hopefully I can build some skids and tub in Ian's shop. That would be sweet!
    You should see what they are building now. Linked f 150 pre runner
  12. Oct 12, 2013 at 10:30 PM
    #4952
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh well perfect haha that'll be handy if they let ya in there.
    Are you getting 35s now???
  13. Oct 12, 2013 at 10:34 PM
    #4953
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh they will :cool: me and Ian like to do truck shit
    And whaaa? Monte you know I've pretty much wanted 35s for a month now. I'm still planning on getting it all done by moab
  14. Oct 12, 2013 at 10:37 PM
    #4954
    Blackdawg
    Monte
    Wyoming/St. Louis
    I meant like in the next 2 months haha you kinda need them to tub...
  15. Oct 12, 2013 at 10:47 PM
    #4955
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh oh oh. No I won't till I get them. The shop will be done in the next couple months, not me starting the project
  16. Oct 12, 2013 at 10:54 PM
    #4956
    95 taco
    95 taco Battle Born
    Monte, i've set a goal.
    My truck will be Moab ready by may of 2017.
  17. Oct 12, 2013 at 10:54 PM
    #4957
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh okay gotcha haha was gonna say where did that come from??? Haha
  18. Oct 12, 2013 at 11:06 PM
    #4958
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    2017? Jesus dude that's a far ways off. Your truck can be plenty Moab ready by 2014
  19. Oct 12, 2013 at 11:08 PM
    #4959
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'm probably gonna miss out on Moab again. :(
    Monte, where the fuck is the build thread for the double cab? You've HAD to of done something to it by now.:p
  20. Oct 12, 2013 at 11:09 PM
    #4960
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Even my truck could do Moab. Just have to pick and choose what to go through.
