The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Oct 14, 2013 at 12:45 PM
    #5021
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    thinking it might be a good option as it's compact and would be an upgrde from the 20 watt rms HU output going to the 50 watt rms of the amp...
    not going to be running a sub, so 4-ch is all i need really..
  2. Oct 14, 2013 at 12:47 PM
    #5022
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    might be able to fit the amp under my center console too which would make hiding wires easy
  3. Oct 14, 2013 at 12:50 PM
    #5023
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ya that amp isn't powerful enough. Only 50w rms feeding 100w rms speaks and 60w rms speakers.
    It would work but it won't drive them good. It would be an improvement but not a drastic one. I'd get a bigger amp.
  4. Oct 14, 2013 at 12:55 PM
    #5024
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    would i get a 60w and go with the lower amount or try to get closer to the 100w?
  5. Oct 14, 2013 at 12:58 PM
    #5025
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    from crutchfield..
    RMS...Pairs should be the same, but if your front and rear pairs are slightly different, it's okay — use the lower rating. Multiply that number by 75% (0.75) — this is the minimum RMS wattage the amp you're looking for should have per channel. Now, multiply that rating number by 150% (1.5) — this is the maximum output power per channel you'll want for your amp
    so i would need RMS ranging from 45-90
  6. Oct 14, 2013 at 1:04 PM
    #5026
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
  7. Oct 14, 2013 at 2:36 PM
    #5027
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Monte, our family is gonna be moving to MS in the next year so i figure i should prep my truck for driving ~1,800 miles in 2 days, We're not sure if i'll be towing anything, but there is a possibility of me having the quad in the back.
    Should i get a trans cooler? i have the auto trans, no tow package.
    I know that the trans in our f-250 is quite warm by the time we get to MS (you can feel the heat coming through the floorboard).
  8. Oct 14, 2013 at 4:06 PM
    #5028
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    If you are just having a quad in the back I wouldn't worry about it.
    But if you know you will be towing stuff in the future it's never a bad idea to have. Pretty cheap insurance.
  9. Oct 14, 2013 at 4:14 PM
    #5029
    Blackdawg
    Monte
    Wyoming/St. Louis
    I disagree with this.
    Id go with the higher rated speakers. You can ALWAYS turn down the gain on the amp which you will do to set your gain staging correctly. you'll set the gain for the rears..and the fronts, totally seperate. That said, id go with something that will power the 100w speakers easily. It'll handle the 60w no problem, the gain on the amp will just be down a bit.
    id go for an amp of at least 110w RMS..which is gonna be harder to find..but not impossible.
    Gotta pay to play :p haha
    that amp i like MUCH better. the the first. You can set the gains for the rear and front separate. Nothing fancy on the LPF or HPF but has them.
    only thing i personally don't like is it doesn't ultilize the RCA preamps..paint to wire with out those.
    Signal to nosie ratio is a bit low too..but probably won't notice.
    I'd still personally get a stronger amp..but it'll work. Your speakers will still be a bit starved.
    they do help the autos a lot. That said, i drove 1300 miles out to St Louis and had no issues. Had the cab full of stuff.
    it can't hurt, but not super needed yet id guess.
  10. Oct 14, 2013 at 4:20 PM
    #5030
    95 taco
    95 taco Battle Born
    In frank or the 03?
    From what i've read it's cheap insurance to get one, not that much money and they can help the life of the fluid and trans.
  11. Oct 14, 2013 at 4:25 PM
    #5031
    Blackdawg
    Monte
    Wyoming/St. Louis
    Frank is a 5 speed
    My 03 is the auto double cab. Just like yours.
    yea like i said, it doesn't hurt, but if you can't do it..don't worry to much about it.
  12. Oct 14, 2013 at 7:37 PM
    #5032
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Get a scanguage and monitor your trans temp.
  13. Oct 14, 2013 at 9:00 PM
    #5033
    95 taco
    95 taco Battle Born
    :thumbsup:
    Cool, I'll see what I can do
    Scan gauge is to much $$$
    I do have a old droid, the free torque app, and a Bluetooth OBD thingie though, that'll work if I find a way to mount it and get it power cleanly.
  14. Oct 14, 2013 at 9:20 PM
    #5034
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I monitor my tranny fluid temps very closely. Tho I don't tow, I do carry a lot of weight. I have seem high fluid temps only when climbing. This happens both on the highway and the trail. Never happens on flat ground, regardless of speed or load.
    A Hayden 678 passive cooler is on my mod list for this winter.
    I totally agree with this.
    Only a scangauge is capable of showing you the actual fluid temps in real time. Without one you will never know when the temps are too high. No android app is going to do this and the dash indicator is worthless.
  15. Oct 14, 2013 at 10:02 PM
    #5035
    95 taco
    95 taco Battle Born
    There's suppose to be a hack for torque to read the trans fluid temp, but it hasn't been tested on 1st gens.
  16. Oct 15, 2013 at 8:06 AM
    #5036
    Pyro
    Pyro Well-Known Member
    Jon
    Tehachapi, CA
    14' Tacoma TRD Offroad
    Bilstein 5100
    sub'd
    such a sick truck man. love that rack tent... me and a buddy have been looking at those recently..
  17. Oct 15, 2013 at 9:06 AM
    #5037
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man! I love the rack, it turned out great.
    CVT tents are awesome too! Really any RTT is sweet. Makes trips super nice!!
  18. Oct 17, 2013 at 11:37 AM
    #5038
    95 taco
    95 taco Battle Born
    Hey monte, it'd be possible to extend my bed a little shouldn't i?
    The major thing would be extending the frame correctly correct?
    I could do a 6ft bed and bob it a little, or I could extend my bed.
    The reason I want to extend my bed is I want the bumper with the swing out, but it wouldn't work with my quad in the back, and the quad has priority.
    Thoughts?
  19. Oct 17, 2013 at 11:41 AM
    #5039
    Blackdawg
    Monte
    Wyoming/St. Louis
    You'd have to make a custom bed.
    The frame on your truck is the same as a extended cab. So you couldn't put a 6' bed on it as the only difference between a 6' bed and 5' bed reall is 1' is taken out or so from the front portion of the bed.
    This means if you tried putting a 6' bed on your frame the wheel well would be 1' back..
    So you'd have a crap load of custom body work and it would look over all just awkward being a foot longer on the back portion.
    I suggest getting a small trailer for the quad.
  20. Oct 17, 2013 at 11:46 AM
    #5040
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
