The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Oct 20, 2013 at 3:43 AM
    #5061
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    No doubt
    :D
  2. Oct 20, 2013 at 10:50 AM
    #5062
    00YotaComa
    00YotaComa HAWAII SELLS MORE TACOMAS THAN ANY OTHER STATE!
    Jack
    Big Island, Hawaii
    00 Tacoma SR5 TRD OFF ROAD
    1in. leveling kit, Deck plate mod, grey wire mod, K&N Filter , custom paint, Cyron LED lighting, head and tail blackouts
    Hey BlackDawg, How did u do the dual battery set up and what are the benefits of running that GM 140amp CS144 alternator. Im sorry if it's already in here somewhere but I was not goin to look thru all 260 something pages to find it. I have a lot of accessories I run and wanted to do a dual set up...although I have recently seen a lithium ion battery used to eliminate the need for two battieries in diesel applications. Ideas or knowledge of that comparision? thanks!
  3. Oct 20, 2013 at 11:13 AM
    #5063
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dual batteries are nice because you can run all your accessories off their own battery while you never effect the starter battery. This means you know the truck will start the next day no matter what. You can ever jump yourself which I've done if it's too weak.
    The cs144 is a 140 amp alternator that puts out about 110 at idle! When under load. That's just awesome. Bigger alternator means better recovery of your batteries and it'll run your stuff off the alternator much better. Seriously well worth it. Awesome easy cheap mod.
    Lithium s are sweet..but damn expensive. I've not seen one that'll fit our trucks yet. But I'm sure they would work great as a deep cycle alternative.
  4. Oct 21, 2013 at 11:41 AM
    #5064
    00YotaComa
    Jack
    Big Island, Hawaii
    Sweet!! Thanks! So u don't have two connect the two batteries...just connect both to the alternator...right? This seems easier and cheaper than I thought it was goin to be! :headbang:
  5. Oct 21, 2013 at 3:43 PM
    #5065
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea sorta.
    You'd run the positive from the alternator to the first battery. Your starter battery that runs your truck systems and such. Ten a cable from the starter battery to a solenoid then from solenoid to the second battery.
    Or you could run without an isolator and run it as a parallel setup...but you could kill both.
    The point of isolating is so you can pretty much kill the second one and the starter battery will still start your truck in the morning.
  6. Oct 24, 2013 at 7:02 PM
    #5066
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Hey so what are the pros/cons of re-gearing to 4.88s instead of 4.56?
    I say this because with the intent that if someday I have to get rid of it (for whatever reason) I would buy another 1st Gen but possibly in an auto. So I figure do the 4.88 now and not have to re-do it AGAIN if I do it to this truck whenever that may be
  7. Oct 24, 2013 at 7:07 PM
    #5067
    Blackdawg
    Monte
    Wyoming/St. Louis
    With a manual and 33s you'll be pretty low geared. Manuals are geared lower then autos.
    That said I got to drive and ride in an auto with 4.88s and 33s with a tone of armor and it felt just like my 03 on 31s.
  8. Oct 24, 2013 at 7:15 PM
    #5068
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mmmm not by much. Just felt slower without a stick shift for you haha yours did not impress me..idk where this speed is that your always gloating about haha
  9. Oct 24, 2013 at 7:16 PM
    #5069
    yote
    Mark
    Tacoma, WA
    So if stock manuals are 4.10 gearing then what are autos?
  10. Oct 24, 2013 at 7:18 PM
    #5070
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also 4.10s
    Well...unless your a prerunner or a 4 banger..then could be 3.93 or 4.30 or 4.56..
  11. Oct 24, 2013 at 7:23 PM
    #5071
    yote
    Mark
    Tacoma, WA
    If they are also 4.10 then how are autos geared lower than manuals? :confused:
  12. Oct 24, 2013 at 7:25 PM
    #5072
    Blackdawg
    Monte
    Wyoming/St. Louis
    Transmission gears are lower. Sorry should have clarified.
  13. Oct 24, 2013 at 7:30 PM
    #5073
    yote
    Mark
    Tacoma, WA
    AH!
    ...okay that makes much more sense.
    So a 1st Gen. re-gearing from 4.10 to 4.88 wouldn't be too swell for a manual, but ideal for an auto?
  14. Oct 24, 2013 at 7:30 PM
    #5074
    BradyT88
    BradyT88 Well-Known Member
    Numerically lower, mechanically higher.
    The 1st gen auto's 1st gear is like 2.83ish and the 1st gen manual's is 3.83ish.
    The 1st gen auto's last gear is like 0.70ish and the 1st gen manual's is 0.84ish.
    That's a huge difference in 1st gears...
  15. Oct 24, 2013 at 7:31 PM
    #5075
    BradyT88
    If you are running 35's or bigger it would be pretty nice in the manual. Might not be enough for the auto though.
  16. Oct 24, 2013 at 7:32 PM
    #5076
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea perfect for autos. And if you don't mind a super high rpm on the hwy fine for manual. Be super torquy. But damn near 3k for 70mph I think
  17. Oct 24, 2013 at 7:33 PM
    #5077
    Blackdawg
    Monte
    Wyoming/St. Louis
    Agreed.
    4.88s with manual an 35s would be fine.
    5.29s for auto and 35s
  18. Oct 24, 2013 at 7:33 PM
    #5078
    yote
    Mark
    Tacoma, WA
    I just want to make sure that an auto (or my manual for that matter) won't have problems when carrying these items:
    Front/Rear Plate Bumpers, 33s (won't go bigger), Canopy & a Winch
    Edit: If it's gonna be extremely sluggish then I'll plan on re-gearing EVENTUALLY but otherwise will probably keep it how it is
  19. Oct 24, 2013 at 7:36 PM
    #5079
    Blackdawg
    Monte
    Wyoming/St. Louis
    I floored it..a bunch..wasn't impressed haha not far off from me..haha
    Hell no regearing will do that still..haha
    For an auto, 4.88s
    But your a manual..unless your thinking of buying one very soon..
  20. Oct 24, 2013 at 7:44 PM
    #5080
    yote
    Mark
    Tacoma, WA
    Got it. Not gonna re-gear unless I get an auto then. That's lightyears away and not very likely so 4.10 manual 1st gen it is :woot:
