The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Oct 27, 2013 at 8:37 PM
    #5101
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Man that looks like a lot of work just to get 4 doors... BUT I wouldn't have to do quite as much because I'd be keeping everything with the frame except the cab, right?
  2. Oct 27, 2013 at 8:47 PM
    #5102
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well..yes and no..
    still a shit load of work. You have to remove everthing that is attached inside the engine bay to the cab/fenders walls/front support. which is a lot of stuff. A LOT haha
    everything on the under side which ain't too bad..few wiring stuff and fuel lines.
    Then you'd have a major wiring issue..you'd have to put out the harness of one of the trucks and decided on which you want. 01-04s are going to be different.
    The deciding factor of course being what tranny you want..im going to assume your manual so you don't have to transfer the crawl box.
    so you'd have to swap ECUs over to the 01-04 body..which should be pretty simple. But the tricky part is the in cab harness for the fuse boxes. Im not sure how you would use that...if you'd just leave everything as is..or if you'd have to swap your 96 in cab harness over and loose some features. Why? well..the double cab in cab harness will be wired for an AT tranny...so some things will be there that suddenly won't..
    Id look at doube cab manual T swap threads to get a better idea of that side of it though..but could be a nightmare..not sure. In theory..should be fine..
    But why you want a double cab? You'd have to change your sliders..have a smaller bed..loose the softtopper..
  3. Oct 27, 2013 at 8:52 PM
    #5103
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    But you gain useable cab space.
    If you keep the 96 ECU then you can't put a TRD SC on it stock.
  4. Oct 27, 2013 at 8:53 PM
    #5104
    Blackdawg
    Monte
    Wyoming/St. Louis
    SC fix is getting a 97 ECU. And there are some cases where the 96 ECU does fine some times.. But he can't put a 01-04 as all double cab ECUs are for AT trannies..
  5. Oct 27, 2013 at 8:58 PM
    #5105
    95 taco
    95 taco Battle Born
    So go to a junkyard, find a truck with his engine/trans, 4x4, that's 97-04 (if he wants to SC. :notsure:
  6. Oct 27, 2013 at 9:01 PM
    #5106
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im assuming that the 01-04 body swap he is wanting to do comes with an ECU as its in the cab..
    Not talking about SC.
    The only ecu he can run in his truck right now is a 95-97 4x4 5vzfe manual
    nothing else. there are too many small tweaks made otherwise. Most 95-97s have EGR or remnants of it and we have no ABS at all. The pin out could be different too. As far as i know. Thats the only option is a 97. No 98-04.
  7. Oct 29, 2013 at 7:46 PM
    #5107
    Lumpskie
    New Hampshire
    Couldn't I keep my ecu, wiring etc. And only use the physical cab? Where is my ecu anyway?
  8. Oct 29, 2013 at 7:52 PM
    #5108
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea you'd want to keep your ECU and engine harness. Its the Cab harness of the Dbl cab you'd be using though to keep all the power windows..power mirrors..dash lights..wipers..blinkers..ect. Which would be fine. i think. You should in theory just be able to leave the fuse box mounted and everything should be fine..Unless the pin out for the fuse box to the ECU is different..which it could be..in which case some wiring would need to be done. Im not sure on that. But the only major function the cab harness does to the ECU is really give power..so you should be fine.
    The ECU is right up ontop of the heater core under the dash. You access it by ripping off the glove boxe and the upper piece of plastic thats like the bottom of the dash. I should have a pic somewhere if you want me too look.
  9. Oct 29, 2013 at 7:57 PM
    #5109
    Lumpskie
    New Hampshire
    Yeah I'm pretty sure that I'd give RyWire a call for an OBD I to OBD II harness conversion. I did that when. I swapped an Integra motor/trans into Wifey's civic and it worked great.
    So, physically, do you think the cab would match up to my front end?
  10. Oct 29, 2013 at 8:07 PM
    #5110
    95 taco
    95 taco Battle Born
    Your truck is OBD1?
    My 95 was OBD2.
  11. Oct 29, 2013 at 8:29 PM
    #5111
    Blackdawg
    Monte
    Wyoming/St. Louis
    no need for that. Your OBDII as it is.
    Im talking about just the ECU pin out. The rest should be fine.
    Yes the front should be the same. From what i have seen you'd have to change the rear cab mounts and bed mounts on your frame and it should be fine. Im not making any promises though. Could be a slight difference. But i doubt it.
    your grill will also line up but you'll need to swap over your hood and fenders too. So you'll have to wrap or paint the truck since no colors from 01-04 are the same as 95-97. or just live with it haha
    Honestly though..this is a big project just for a back door..Be easier to just get a double cab and swap your goodies over and call it day. Unless you roll the truck tomorrow..i wouldn't really recommend doing this swap. Takes a LOT of work and space and time..
    You can always do just a manual swap into the Dbl cab and move all the armor over too it as well and locker and suck.
  12. Oct 30, 2013 at 8:32 AM
    #5112
    Lumpskie
    New Hampshire
    Doh! I retarded... I mean't OBDIIA to OBDIIB. Or are all of our trucks on the exact same OBD setup?
    (I know that I had to do the Rywire jumper on Wifey's car... but it was a JDM Integra Motor/Trans/ECU I mated to her USDM Civic harness.)
    And you're right, Blackdawg, about all the work. I'm not too serious about the project, but I thought it would be cool to be the only '96 dbl cab out there. I thought it would look cool too.
  13. Oct 30, 2013 at 8:43 AM
    #5113
    Blackdawg
    Monte
    Wyoming/St. Louis
    hmmm..ya know..im not sure about that..Would have to get that confrimed by someone that really knows.
    And ya it would be pretty sweet! haha i have both in my possession..could do it..but..having done it once..NOT in a rush to do it again..haha even though it might be easier then what i did as its not a full interior swap. But still...lot of work just for a back seat..
  14. Oct 30, 2013 at 10:35 PM
    #5114
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
  15. Oct 30, 2013 at 10:47 PM
    #5115
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea basically, pretty much useless for us. It's used for boats with fiberglass body that do t conduct electricity.
    For use..you can easily just make a short ground for your lights right next to it..cause the whole body and frame is grounded.
  16. Oct 30, 2013 at 10:58 PM
    #5116
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I connected mine to the negative post on the battery with 4 ga. in case I used the full capacity of the fuse block. Should I have grounded it to the chassis instead?
  17. Oct 30, 2013 at 11:04 PM
    #5117
    Blackdawg
    Monte
    Wyoming/St. Louis
    The neg bus? Nah if you connected Tim I'd do it to the battery. But running two wires to everything is annoying and pricey. Instead you could just run positives everywhere and ground the lights on a point somewhere by it.
    Even if you do or don't have the neg bus connected directly, power still flows through the block. Max rating of 100amps.
  18. Oct 30, 2013 at 11:07 PM
    #5118
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, gotcha. I guess I misunderstood what was being asked. :eek:
  19. Oct 30, 2013 at 11:09 PM
    #5119
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. But I mean..if nothing is connected to the neg bus in the first place..no real point.
  20. Oct 30, 2013 at 11:16 PM
    #5120
    yote
    Mark
    Tacoma, WA
    Nice, yeah alright that's what I thought. It's nice to get reassurance before shipping the item out
