The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Dec 16, 2013 at 10:59 PM
    #5561
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea..have fun with that. Sounds like a PITA and too expensive for the "cool" factor.
  2. Dec 16, 2013 at 11:00 PM
    #5562
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    http://www.youtube.com/watch?v=8xqIeFtVvpY
  3. Dec 16, 2013 at 11:00 PM
    #5563
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    dam we are just on the same page tonight :rolleyes:
  4. Dec 16, 2013 at 11:04 PM
    #5564
    Blackdawg
    Monte
    Wyoming/St. Louis
  5. Dec 16, 2013 at 11:04 PM
    #5565
    Blackdawg
    Monte
    Wyoming/St. Louis
  6. Dec 16, 2013 at 11:05 PM
    #5566
    BradyT88
    BradyT88 Well-Known Member
    You can run bypasses with the ORI's shouldn't affect much really, you just wouldn't quite have the tuning flexibility that you would without them but the extra dampening will be nice.
    Nothing weird is happening once they break in. With the temps, when it gets cold they drop, when it warms up they raise. It's not more than an inch really anyway. If you have N2 like JW does, then you just add some or take some out as needed. Basically just add some pressure once winter sets in and remove some once summer arrives. So far my favorite thing about them is the fact that I have like no body roll! It is awesome! They are also easy to tune. You don't have to take them apart and rebuild them to tune them
    The once a year thing is just a piece of mind example I threw out there. There are a lot of guys out there that Jerry found that have been running their ORI's for 3-5 years now without rebuilding. The reason for the piece of mind, is that if an air shocks go out you have nothing to hold you up anymore.
    Although it may not be that big of a deal. Jerry put too much air in one of his and blew it up and last I knew he hasn't fixed it yet. When he wants to go wheeling he just airs it up and it holds long enough for him to wheel that day. I imagine if you are on the trail and have CO2 or N2, you could just air it up with that to get you home.
  7. Dec 16, 2013 at 11:08 PM
    #5567
    Blackdawg
    Monte
    Wyoming/St. Louis
    well glad your happy with them.
    i don't see an real advantages for me.
  8. Dec 16, 2013 at 11:09 PM
    #5568
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
  9. Dec 16, 2013 at 11:10 PM
    #5569
    Blackdawg
    Monte
    Wyoming/St. Louis
  10. Dec 16, 2013 at 11:11 PM
    #5570
    BradyT88
    Given my major I could probably just build a board with selectable switches and just flip the switches and have pressure sensors shut it off at set pressures so it would be as easy as flipping some switches and waiting a few seconds.
    You can't really see it in this pic, but that switch has 4 settings. Each setting is a terrain type, ie mud, snow, highway, gravel. You flip the switch to the setting you want and it sets the pressure to desired setting.
    If I wanted to be simple I could just have one 3 setting switch. Street, Dunes, Rocks. Or have 4 switches each with those 3 settings and just flip them.
    When we wheel in groups it is slow moving enough that you have plenty of time to look at the trail ahead and flip the switches and go.
  11. Dec 16, 2013 at 11:13 PM
    #5571
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    and in the same situation...i bet monte and myself would do the same thing...braap right on through with out much more thought than "how much more skinny pedal does it want" without giving a thought to what setting the shocks should be at
  12. Dec 16, 2013 at 11:19 PM
    #5572
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea..if you want to wire and setup up something like that..go for it.
    Sounds complicated and asking for something to fail..plus a solenoid to handle those kind of pressures accurately..pricey..haha
    I guess..:notsure:
    Pretty much..haha while your sitting wait and deciding on what to run..we will be gone..haha
    I mean its a cool idea and im sure it could work.
    But id rather just drive my shit i brought..i'll know how it handles and how to drive it through whatever im driving it through..i see no reason to change stuff on the fly..
  13. Dec 17, 2013 at 12:01 AM
    #5573
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Just felt like saying it lol I probably will end up with Kings cause icons aren't valved right for daily driving
  14. Dec 17, 2013 at 12:11 AM
    #5574
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Icons are valves better for daily driving? Or at least I thought so? They're digressive so the faster you go the smoother they are versus Kings that are progressive.
  15. Dec 17, 2013 at 12:14 AM
    #5575
    Blackdawg
    Monte
    Wyoming/St. Louis
    Opposite man.
    Icons will ride stiffer slower and crawling stuff. But yes, the faster you go, the smoother they get.
    Kings/Foxes/SAWs are progressive..so the faster you get the harder they get. But for DDing and crawling they are a softer.
    Not that thats saying Icons are a lesser shock and aren't good for DDing..just a personal thing and will ride different. Some hate it, some love it.
  16. Dec 17, 2013 at 12:18 AM
    #5576
    PcBuilder14
    Brent
    Nor Cal
    How is stiffer better for daily driving? Wouldn't icons be better for driving on the highway since they get softer?
  17. Dec 17, 2013 at 12:20 AM
    #5577
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I don't do much highway driving so the "softer" ride might be the better way to go. But anything has to be better than these spacers...
  18. Dec 17, 2013 at 12:23 AM
    #5578
    Blackdawg
    Monte
    Wyoming/St. Louis
    Its not..so Icons usually aren't favored to DD..as they are stiffer at slower speeds.
    Just because your going fast doesn't mean they just get smoother. When we say that..we mean over whoops/washboards. Shocks can't tell if your going faster..obviously..
    The harder you push icons the smoother they run..But for just driving on a road..they are stiffer.
    Kings/foxes/SAWs run softer on the roads..but when you push them through the whoops and wash boards stiffen up more.
    Now..this might seem bad..but is it?
    Softer through washborads is great..long as yoru going perfectly straight..as softer means more body roll..
    which means Kings ect. would roll a bit more then Icons on just a normal road.
    But Kings get a big stiffer on whoops/washboards so while you might feel it a bit more..there is more control at speed..
    Then for slow trail stuff..your ride will feel smoother with kings then icons.
    Make sense?
    All in all..the effects of it can be a big difference or hardly noticeable. All depends on you really.
  19. Dec 17, 2013 at 12:24 AM
    #5579
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Makes sense to me :thumbsup:
  20. Dec 17, 2013 at 12:25 AM
    #5580
    Blackdawg
    Monte
    Wyoming/St. Louis
    well..you mean when it hits a bump or pot hole..or something..in the road at hwy speed. Shock can't tell your going 65mph over 5 mph on smooth road..haha
