The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jan 7, 2014 at 12:15 PM
    #5921
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Don't overtighten the center pin. They strip very easily. Nice work on the fender trim.
  2. Jan 7, 2014 at 2:07 PM
    #5922
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    I used a little of "The Right Stuff" on other body panels that I've cut. I bet your could do a really narrow bead then put your trim on top...
  3. Jan 7, 2014 at 2:25 PM
    #5923
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    nice work on the fenders! looks great!
  4. Jan 7, 2014 at 3:34 PM
    #5924
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ah thats not a bad idea..the trim i used tho is super tight so i think it would just scrape it all off..ill prbably just paint it with a brush.
    thanks Bob!
    So my drivers side fender is done and im going to start the fire wall soon. Not really happy how i did the fender. Think its too much cut..but i wanted to cut enough as im hopefully gonna be adding LT this year :pray: and i know my up travel will be much higher then stock. so hopefully it all works out.
    im still torn on if i should try the passenger side a bit different and see what i like better and maybe just order a new driverside fender as its a tad damaged anyways..idk yet.
  5. Jan 7, 2014 at 7:25 PM
    #5925
    Madjik_Man
    Colorado Front Range
    No kidding. I imagine your write up would go something like this:
    1. Wait until it's 1:45am
    2. Stand 4 feet away from the fender, visualize the cut.
    3. Step up to the fender.
    4. Start cutting along the imaginary visualized line.
  6. Jan 7, 2014 at 7:26 PM
    #5926
    Madjik_Man
    x2 me too :laughing:
  7. Jan 7, 2014 at 7:26 PM
    #5927
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    i thought about it..haha
  8. Jan 8, 2014 at 1:30 AM
    #5928
    Blackdawg
    Monte
    Wyoming/St. Louis
    well calling it a night. can't believe i am still cutting on the drivers side. Thought i was done and ready to start making a cut out. Had just cut off a bit of my sliders and threw the tire on for one last final check..and bam..its like i had barely even cut! WTF! had cleared fine all the other times..till then..sheesh..kicking my ass so far..I think my caster is set pretty far back but i need to cut a lot more and feel comfortable with it with LT coming hopefully..sleep time.
  9. Jan 8, 2014 at 1:36 AM
    #5929
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yeah have fun with that. I hated it. So much to cut through, sawzall won't work, and an angle grinder doesn't fit. :mad: I ended up basically chopping it up little by little, I can't tell you how many cut-off wheels I went through.
  10. Jan 8, 2014 at 1:44 AM
    #5930
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea yours goes much further in towards the center of the truck then mine right now..and the outer edge is higher which is where im hitting now..
    i have gone through 2 cut off wheels so far and 4 sawzall blades..gonna by shorter sawzall blades next tho. 4'' or less. the 6'' ones where just too long.
    driving me nuts. My timelapse vid is like almost 3 minutes..which means i have been working on it for 6 hours almost..sheesh..stupid.
    hopefully the passenger side will go smoother.
  11. Jan 8, 2014 at 1:49 AM
    #5931
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Well shit.
    :popcorn:
    Not gonna lie, after seeing everyone's tub job I can probably do mine without even stuffing the tire. I've seen where everyone cuts...just take a giant chunk out, more than is totally necessary and boom. Done
  12. Jan 8, 2014 at 1:51 AM
    #5932
    Blackdawg
    Monte
    Wyoming/St. Louis
    NO
    do not do that. You need to pull the CO and check yourself. Everyone has different alignments resulting in different amounts cut. Mine looks nothing like Jons. Or Pauls. Or Travis's. Not to mention you'll be putting in used tires. so you probably won't have to cut as much as others with new tires. and your doing 13.5s and THAT is gonna TOTALLY change how your tub job ends up.
  13. Jan 8, 2014 at 1:53 AM
    #5933
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ill just cut out the entire fire wall and make my own haha
  14. Jan 8, 2014 at 2:16 AM
    #5934
    Blackdawg
    Monte
    Wyoming/St. Louis
    Don't pull a Jon.
  15. Jan 8, 2014 at 2:29 AM
    #5935
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Dude wait a day. I can give you old man perception. (I'm willing to share with whomever will listen) Totally worth it and free! Remember I'm with you!
  16. Jan 8, 2014 at 2:38 AM
    #5936
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    X2! Everyone's shit is different! You know this. Do it right the first time so you won't ever have to do it again. Cutting sucks but rubbing while your wheeling sucks more
  17. Jan 8, 2014 at 5:09 AM
    #5937
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    lol
    :anonymous:
  18. Jan 8, 2014 at 6:38 AM
    #5938
    Madjik_Man
    Not gonna lie, after seeing everyone's tub job...
    ...I'm sticking with 31s
    :eek:
  19. Jan 8, 2014 at 7:27 AM
    #5939
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    Although they're cheap and I don't like to buy stuff there very often, this little guy was quite impressive and I wonder if it would make things a bit easier when trimming the firewall. Cuts through sheet metal like butter and easy to control. [​IMG]
  20. Jan 8, 2014 at 7:41 AM
    #5940
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    The problem with the sawzall was with the reciprocating action, the blade would constantly impact the sheet metal behind the sheet metal. Wish I had a plasma cutter.
