The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jan 8, 2014 at 8:02 AM
    #5941
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    calm down ladies
    i was kidding:p
    LAME
  2. Jan 8, 2014 at 8:49 AM
    #5942
    BradyT88
    BradyT88 Well-Known Member
    You know Mark... If you get down to Konsta's with those tires, He has a plasma cutter. haha
  3. Jan 8, 2014 at 10:05 AM
    #5943
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I could have the cleanest tub of the bunch...
    Since I got this internship with almost unlimited work hours I can actually justify diving down there......
    Brady I think I'll be paying you gentleman another visit.
  4. Jan 8, 2014 at 10:06 AM
    #5944
    BradyT88
    :woot:
    Konsta has a 37 you can use to tub ;) haha Not sure if it is on a wheel though, or it you will have any fender left after you cut for that.
  5. Jan 8, 2014 at 10:10 AM
    #5945
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea ill keep working at it. It'll be nice to have help for the passneger side though.
    32s!! come on!
    have one. The saws tho rip the metal apart and the blades on those wander too much.
    i have a plasma cutter :anonymous: its brand new in the box still haha but no way would i use it on this. Spray slack and sparks ALL over the cab no matter how well you covered it. Ill pass on spraying molten steel everywhere..haha
    wouldn't use a plasma. Thats just asking for big problems.
  6. Jan 8, 2014 at 10:13 AM
    #5946
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    How so? I can just go from the inside.
    Either way, konsta has 80000 tools and a lift in his personal shop.
    Would be much better and quicker than my driveway fab area
  7. Jan 8, 2014 at 10:14 AM
    #5947
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Quick, what's the best soda to mix with my expensive whiskey??
  8. Jan 8, 2014 at 10:18 AM
    #5948
    Blackdawg
    Monte
    Wyoming/St. Louis
    you won't be able to do 80% of it from inside. Its not possible. There are like 6 layers you have to cut through and you cant get to them from the inside. its on the door side thats a bitch. The floor board is easy with just a grinder.
  9. Jan 8, 2014 at 10:23 AM
    #5949
    BradyT88
    He has a welding blanket as well that might help with that.
    You get rid of that shit and get yourself some good Tequila or Rum ;) haha
  10. Jan 8, 2014 at 10:29 AM
    #5950
    Blackdawg
    Monte
    Wyoming/St. Louis
    still wouldn't do it. I have used plasmas, they send shit EVERYWHERE.
  11. Jan 8, 2014 at 10:41 AM
    #5951
    Madjik_Man
    Colorado Front Range
    I've read a few posts that a 11.5 wide tire on a 7" wide rim would not ride nicely on road.
    Kind of dissuading me from stepping up in tire size.
  12. Jan 8, 2014 at 10:47 AM
    #5952
    BradyT88
    255/85R16 is a 33x10" tire. If you are on 17's they make a 255/80R17 and if you are on 15's there are a lot of 33x10.50's out there.
  13. Jan 8, 2014 at 10:50 AM
    #5953
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    so after hacking into your fire wall (where are my pics) what tool have you found to work the best? sawzall with a fine blade?
    tequila only in a margarita...rum, eh malibu is ok. i do love cinnamon whiskey though. that shit can be drank straight from the bottle. we do that when we go boarding
    it would be a fountain of beauty! and fire...
    its a truck...it doesent ride nicely anyway
  14. Jan 8, 2014 at 10:52 AM
    #5954
    Madjik_Man
    Rather not step up to 33s.
    I'm on a stock suspension.
    ^^ The end all be all argument of derptards.
    :p
  15. Jan 8, 2014 at 10:53 AM
    #5955
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i would say you could have my 33s, but i still want to wear them down to nothing lol
  16. Jan 8, 2014 at 10:55 AM
    #5956
    Blackdawg
    Monte
    Wyoming/St. Louis
    both a angle grinder with cut off wheel. Grinder. And sawzall with small blade. And something to clean the area with. Need em all really..haha
    you'd have to run a lower psi in the tires on a 11.5 with a 7'' rim to get even wear..so really should ride nice..not much different then a 12.5'' tire on a 8'' rim.
  17. Jan 8, 2014 at 11:14 AM
    #5957
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    good! I even have all of those things
    brady, dont get mad if i become impatient and start hacking the truck up
  18. Jan 8, 2014 at 11:17 AM
    #5958
    Blackdawg
    Monte
    Wyoming/St. Louis
    you won't haha cause once its cut..its cut. haha
  19. Jan 8, 2014 at 11:31 AM
    #5959
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Rides fine, I've been running an 11.50 tire on some older steelies that are 15x7. A 32x11.50 is a perfect size for stock susp on these trucks imo.
  20. Jan 8, 2014 at 11:44 AM
    #5960
    Madjik_Man
    Man, I'm flip flopping worse than my balls on a hot summer day.
    Come spring/summer when I'm due for new tires I'll price out 31s vs 32s. That'll be my deciding factor.
