The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jan 8, 2014 at 5:24 PM
    #5961
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Sorry Steve, they didn't have the Pappy Van Winkle at that exxon... She said its a special order and it goes real fast when they get it in!
    Edit: Dammnit I posted that in the wrong thread... SOrry monte but im sure ur dad will see it in here haha.
  2. Jan 8, 2014 at 5:25 PM
    #5962
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    FINALLY done cutting the driver side up. Gonna eat then get to work on welding it up.
    Cut a CRAP load more then i was ready for. Looks closer to Jons then it does Pauls or Travis's. Probably because mine(and jons:p) are 35x12.5r15 and theirs are 315/75r16s.
    Mark..good luck with those 35x13.5r15s..your gonna have to cut even more then i did. A lot more. kinda worried about it actually..
    anyways. here are a few photos. I have a time lapse movie that shows most of the cutting but its kinda boring and long so probably won't post it.
    33
    IMG_7954.jpg by Monte Nickles Photos, on Flickr
    35..as high as it'll go with the fender not cut..
    IMG_7955.jpg by Monte Nickles Photos, on Flickr
    fender roughly cut up. Will have to take even more off the cab side though
    IMG_7957.jpg by Monte Nickles Photos, on Flickr
    let the cutting begin!
    IMG_7958.jpg by Monte Nickles Photos, on Flickr
    9 hours later..it fits!
    IMG_7959.jpg by Monte Nickles Photos, on Flickr
    the damage..
    IMG_7960.jpg by Monte Nickles Photos, on Flickr
    IMG_7961.jpg by Monte Nickles Photos, on Flickr
    IMG_7962.jpg by Monte Nickles Photos, on Flickr
    i will say that the passenger side is going to be MUCH easier as there aren't quite as many curves on that side. Plus i won't be cutting through old welds as some may remember i had to patch a rusted out hole there when i did the cab swap. shoulda just tubed it then..
  3. Jan 8, 2014 at 5:29 PM
    #5963
    SconnieHailer
    Marc
    Yea buddy! Excited to see it in person tomorrow :D
  4. Jan 8, 2014 at 5:33 PM
    #5964
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha hopefully it'll roll under its own power tomorrow! haha
  5. Jan 8, 2014 at 5:38 PM
    #5965
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Looks like the amount you cut off the A pillar is identical to mine. You gonna reinforce the A pillar before throwing the sheet metal on?
  6. Jan 8, 2014 at 5:41 PM
    #5966
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i went and looked at your build last night..idk if i will or not. Maybe ill check it when i get home.
    I bought 16 ga metal to use instead of 22 ga so..idk..think it'll be fine. if i get hit right there by a car anyways..probably be screwed as it will have to be a TALL truck to get past my sliders..or it'll just tip me over..haha
  7. Jan 8, 2014 at 5:46 PM
    #5967
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Not sure if it is needed or not, but I did it for peace of mind. :eek: Not in regards to impact with another vehicle, but (potentially) seriously weakening the pillar and combined with cab flex it could cause some stress cracks.
  8. Jan 8, 2014 at 5:57 PM
    #5968
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    fire extinguisher...good thing to have!
    thats a big hole ya got there haha!
  9. Jan 8, 2014 at 6:21 PM
    #5969
    Blackdawg
    Monte
    Wyoming/St. Louis
    good point...hmm..maybe. idk. haha
    yours is gonna be bigger. you'll have .5'' more tire per side AND you have less backspacing..so..have fun :D haha
    its the soul of Frankenstein...:spy:
  10. Jan 8, 2014 at 7:26 PM
    #5970
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Holy shit I didn't even see the hand, I was mesmerized by the cutting. I had to scroll back up to see if you were fucking with me hahaha.
  11. Jan 8, 2014 at 7:46 PM
    #5971
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hope so :eek: cutting it close tho..
    All good :D
    :rofl:
  12. Jan 8, 2014 at 8:28 PM
    #5972
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Hang in their buddy. The old man makes a good point. :D
    I ran 32x11.5-15s on 7" wide stock alloys on my first Tacoma. Was a very nice combination overall. Was very capable on and off pavement, looked nice and had good wear pattern.
    If I was running a 32s on 15" rim, I would not hesitate to do it again.
  13. Jan 9, 2014 at 6:25 AM
    #5973
    Madjik_Man
    Colorado Front Range
    Damn Monte... 9 hours of cutting etc? Nice work.
    Btw - that garage is bigger than my house. Lucky to have a nice workspace like that
    Thanks Mike, I appreciate it. Your opinion has always been valuable to me.
    If Discount still has the 32x11.5s $25 cheaper than the 31x10.5s I'll step up in size.
  14. Jan 9, 2014 at 8:01 AM
    #5974
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea the garage is huge. Very very lucky to get to work in it.
  15. Jan 9, 2014 at 10:03 AM
    #5975
    Digiratus
    Roaming the PNW
    The RedHead
    Huge is an understatement. [​IMG]
    Its bigger than 2 houses combined. :eek: I estimate its at least 8,000 s.f., maybe 10.
  16. Jan 9, 2014 at 11:21 AM
    #5976
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea it's big. Holding 5 cars and 3 boats with tons of room..haha I like it :D
  17. Jan 9, 2014 at 7:46 PM
    #5977
    Blackdawg
    Monte
    Wyoming/St. Louis
    Finally got the driver side buttoned up. Gonna paint it later when the seam sealer dries.
    Huge thanks to my dad. Was soooo much nicer having a helping hand and his black smithing skills.
    Ended up buy so,e new 20 ga for it instead of the 16ga I had. Was much more Malleable. Welding that stuff sucks but I got it done well enough. Tire clears great. And still managed to do it with just one piece of steel.
    Pics later tonight.
  18. Jan 9, 2014 at 8:20 PM
    #5978
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    ive decided tonight im gonna have to beat the firewall back or start tubbing real soon. Ive cranked my c/os way to high to beaable to clear my tires and my cvs are not happy looking.
    do you have to move any of the wires or ECU after you get everything buttoned up?
  19. Jan 9, 2014 at 8:30 PM
    #5979
    Blackdawg
    Monte
    Wyoming/St. Louis
    D you have 35s?
    If not. No need for tubbing n just beat the cramp out if it with a big hammer.
    But yes. Major wire moving for tubing.
  20. Jan 9, 2014 at 8:35 PM
    #5980
    Digiratus
    Roaming the PNW
    The RedHead
