The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Mar 15, 2014 at 8:14 AM
    #6501
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I have the mounting system all figured out, so I'm god there. And I might have gotten a good deal on 14s and said sur why not
  2. Mar 15, 2014 at 1:55 PM
    #6502
    BradyT88
    BradyT88 Well-Known Member
    I'm like 99% sure that all the front clamshells are the same on 1st gens. Same 7.5" ring gear and all.
  3. Mar 15, 2014 at 7:14 PM
    #6503
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    14s??? wth..why? haha you'll loose up travel compared with using 12s.
    yes. Any front tacoma diff will swap.
    NOT a pre tacoma diff though.
  4. Mar 15, 2014 at 11:11 PM
    #6504
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Cuz they were a decent price. And ya I know I lose up travel, oh well
  5. Mar 21, 2014 at 6:30 PM
    #6505
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    After the inspiration of Frankenstein for my build, I finally have a thread
  6. Mar 21, 2014 at 6:40 PM
    #6506
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Monte, I pulled the trigger and bought a CVT Mt. shasta. What did you say was the magic number as far as the bed rack height? Mine is 11" above the rail. I watched your video on the annex. Are you able to utilize the floor on yours?
  7. Mar 21, 2014 at 7:03 PM
    #6507
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweet man! Ill go sub now :cool:
    Cool man! Why did you switch??
    Mine is at 14" from the bed rail to the bottom of my 1.5" tubbing.
    I wouldn't go lower then 12. But you might be okay. You'll find out :cool:
    I can use the floor but I have to poof it out a bit.
  8. Mar 21, 2014 at 7:48 PM
    #6508
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    This whole time I thought my buddy had a mt shasta. Turns out he has a mt bachelor. Don't think I'm going to change it out now.
  9. Mar 21, 2014 at 8:18 PM
    #6509
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh ha darn!
  10. Mar 21, 2014 at 8:21 PM
    #6510
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Bachelor and the ayer not much difference. Ayer and shasta. . Big difference.
  11. Mar 21, 2014 at 8:26 PM
    #6511
    Blackdawg
    Monte
    Wyoming/St. Louis
    Very true.
    Well bummer man.
  12. Mar 23, 2014 at 6:28 PM
    #6512
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Are you running 15X8" or 15X10" wheels on your 35's
  13. Mar 23, 2014 at 7:09 PM
    #6513
    Blackdawg
    Monte
    Wyoming/St. Louis
    15x8 3.75'' BS + 1.5'' spacers.
    Mark has 15x10s and they are WIDE wide wide. Im glad mine were. Not sure how much more i could have cut out..haha
  14. Mar 23, 2014 at 8:46 PM
    #6514
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    :wave:
    I scored a full size spare today. A used 33x10.5-15 KM1. Was free. :)
  15. Mar 23, 2014 at 8:48 PM
    #6515
    Blackdawg
    Monte
    Wyoming/St. Louis
    :woot:
    awesome man!! finally!!! haha now just need a place to put it :spy:
  16. Mar 23, 2014 at 9:07 PM
    #6516
    Digiratus
    Roaming the PNW
    The RedHead
    So true. :D
    Also need a rim. You'd think with my garage full of useless wheels, I'd have a 15", but nope. :facepalm:
  17. Mar 23, 2014 at 9:11 PM
    #6517
    Blackdawg
    Monte
    Wyoming/St. Louis
    HAHAHA!!
    So what..you have..two sets of 17s..and a set of 15s..but no spare 15..hahaha funny.
    Well if all you have to do is buy a $50 steel rim for a full size spare..id say your doing pretty good! haha
  18. Mar 23, 2014 at 9:33 PM
    #6518
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, if only it was so simple. :rolleyes:
    Never had any 15s. 2 sets of 17s though, one of which is spoken for.
    I did have a set of 16's with 31s on them but Mark has them on the Raisin.
    Sorry dude, no $50 15" steelies that will clear the calipers. Even the Wheelers ones are $60+ shipping. so $70. :(
  19. Mar 23, 2014 at 9:40 PM
    #6519
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh..well. 70 bucks is still pretty darn cheap..i don't see the issue :p haha
    i have a set..one with a blown tire..haha you want that one? lol
    Ben going to 17s..tsk..haha
  20. Mar 23, 2014 at 9:44 PM
    #6520
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
