The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Apr 10, 2014 at 10:47 PM
    #6761
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yes very true...
    Hmm..maybe 4.88s would be a bit better..
  2. Apr 10, 2014 at 10:50 PM
    #6762
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I think frank is likely to keep getting bigger and fatter.
  3. Apr 10, 2014 at 10:52 PM
    #6763
    Blackdawg
    Monte
    Wyoming/St. Louis
    Did for like 30 minutes today haha
    That...is true..
  4. Apr 10, 2014 at 10:54 PM
    #6764
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Just because Frank no longer has DD duties, does not mean it is exclusively a trailer queen trail rig. It still has to handle the interstate or at least be able to cruise comfortably at 75.
  5. Apr 10, 2014 at 10:57 PM
    #6765
    BabyTaco
    Wyoming
    2011 RC Tacoma
    What, why 75? 65 is a great speed :).
  6. Apr 10, 2014 at 11:03 PM
    #6766
    Blackdawg
    Monte
    Wyoming/St. Louis
    75??? Haha I never have cruised at 75. Other then the Colorado thing :anonymous:
    If I went over like 72 I'd go from 17mpgs to 13, even with my 31s :notsure:
    But you are right. Not a trailer queen.
    The FRV could do it but..all the time would suck haha
    Yea fast as we need to go in wy. It's those pesky interstates...
    :cool:
    Didn't help though! Hana :frusty:
  7. Apr 10, 2014 at 11:05 PM
    #6767
    Digiratus
    Roaming the PNW
    The RedHead
    haha. After re-gearing, the sweet spot for performance and mpgs definitely moved to a higher speed for highway driving on my rig. Actually, 70-75 seems ideal for my combination. The truck just loves to run at those speeds and gets the best fuel mileage to boot.
    I realize 35s will effect that but also the trans gear ratios play a role as well.
  8. Apr 10, 2014 at 11:05 PM
    #6768
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Got a little of this action going on. Can you guys tell I am suppose to be doing homework? :D
  9. Apr 10, 2014 at 11:07 PM
    #6769
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea tranny gears are different..I'm gonna see how they are the same with the gear calc
    :rofl:
  10. Apr 10, 2014 at 11:09 PM
    #6770
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    What's your setup? (lift, tires, tire size, gears)
  11. Apr 10, 2014 at 11:12 PM
    #6771
    Blackdawg
    Monte
    Wyoming/St. Louis
    33x10.5r15s 4.88s 2.5"ish lift
    LOTS of armor..shit loads of steel haha
  12. Apr 10, 2014 at 11:13 PM
    #6772
    Digiratus
    Roaming the PNW
    The RedHead
    I'm running about 2-2.5" of suspension lift with 33s and 4.88s and an auto.
  13. Apr 10, 2014 at 11:14 PM
    #6773
    95 taco
    95 taco Battle Born
    He has a auto also (I remembered the info under the username after i posted), I think i know what setup I'd go with if i were to theoretically run 33's and reappear.
  14. Apr 10, 2014 at 11:14 PM
    #6774
    Digiratus
    Roaming the PNW
    The RedHead
    A little lighter than Frank, but not by much. ~200 lbs maybe.
  15. Apr 10, 2014 at 11:17 PM
    #6775
    95 taco
    95 taco Battle Born
    Cool, thanks
    Really? Frank looks a lot heavier (more cluttered maybe?).
  16. Apr 10, 2014 at 11:18 PM
    #6776
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not anymore..haha probably 400 with the 35s
  17. Apr 10, 2014 at 11:19 PM
    #6777
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't have a belly skid yet either. He does.
    Carries more shit then me too unbelievably..haha
  18. Apr 10, 2014 at 11:21 PM
    #6778
    Digiratus
    Roaming the PNW
    The RedHead
    I thought those were aerodynamic enhansements.
    Def more cluttered. :laughing:
  19. Apr 10, 2014 at 11:23 PM
    #6779
    Digiratus
    Roaming the PNW
    The RedHead
    Thats tthe way it is when you have further to travel to get to your destination. :rolleyes:
  20. Apr 10, 2014 at 11:26 PM
    #6780
    95 taco
    95 taco Battle Born
    How do you not have a belly skid? I woulda thought you were all skid'd out.
    How in the world? he has a shell and you have a rack.
    Having the camper shell makes your truck look smoother.
    You really need a build thread, that way I don't have to think of questions and PM you, i just go in and see what you have and if you've broken it yet.
