The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Apr 11, 2014 at 11:55 PM
    #6841
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    haha, I guess I stopped using them just in time then, :D
    So you have one white one and one yellow one now?
    edit: they have little colling fans embedded in the heatsinks
  2. Apr 12, 2014 at 12:15 AM
    #6842
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yep haha one spare now haha
    And they look nice. Expensive. But..all LEDs are..
  3. Apr 12, 2014 at 1:51 AM
    #6843
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i have no adversion to anything at night. far more entertaining :rolleyes:
  4. Apr 14, 2014 at 5:29 PM
    #6844
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    question on the cs144 alt. i hate electrical but i need to grasp a few things now because i realize my stock one is just not enough at this point.
    1st off im running a single yellow top on a 2.7 motor so i know you wont be able to answer any fit up questions being that you have the 3.4
    2nd i think from everything ive read that i need to run a power wire straight to my battery from the alt with a 150A breaker in there and completley bypass the stock fuse box, correct?
    3rd im planing on getting a plug to go from the toyota plug to the 4 pin GM plug that way i dont have to clip any wires and if i remember what i read in one of your replies that is the same thing you did and you dont have any issues. correct?
  5. Apr 14, 2014 at 8:36 PM
    #6845
    Blackdawg
    Monte
    Wyoming/St. Louis
    1) yea :eek: sorry no idea if it'll fit a 3rz man.
    2) Yes. But you will still connect the fuse box to the battery. You don't have to make a new cable though. Its part of the stock battery connection so make sure it stays there. You do need to disconnect the old power wire from the fuse box that goes on the stock alt. I left mine in the loom though so if i need to swap in the stock one i carry for a spare i can very easily.
    3) I made my own quick disconnects. But there are GM to Toyota connectors out there that should work fine yes.
  6. Apr 14, 2014 at 8:53 PM
    #6846
    4banger4x4
    Eric
    Whorelando, Fl
    Ok so let me wrap my head around this. Leave the stock wire from the fuse box to the batt and then disconnect the wire that runs from the fuse box to the alt. And then make a new 4 gauge line with a 150a breaker that runs from the alt to the batt.
  7. Apr 14, 2014 at 8:57 PM
    #6847
    Blackdawg
    Monte
    Wyoming/St. Louis
    Right.
    You need to disconnect the wire that runs from the stock alt to the fuse box at the fuse box though too. Tape off both ends and just leave it in place to use with the stock alt if you ever need it.
  8. Apr 14, 2014 at 9:08 PM
    #6848
    4banger4x4
    Eric
    Whorelando, Fl
    Im thinking I might do the stage one wire upgrade from bama1997 so I would be taking out the whole harness and putting a new one in. But im gonna try and see if he can modify his wires so it works with the cs144
  9. Apr 14, 2014 at 9:09 PM
    #6849
    Blackdawg
    Monte
    Wyoming/St. Louis
    his kits are a nice way to go for sure!
  10. Apr 14, 2014 at 9:11 PM
    #6850
    4banger4x4
    Eric
    Whorelando, Fl
    Yup. And I hate wiring so its really nice for me. I just hope he can modify his harness to work for this that way I dont have to make my own or modify his on my own.
  11. Apr 14, 2014 at 9:12 PM
    #6851
    Blackdawg
    Monte
    Wyoming/St. Louis
    think you can just get an new alt from him too..i have no idea if a cs144 fits a 3rz..
  12. Apr 14, 2014 at 9:18 PM
    #6852
    4banger4x4
    Eric
    Whorelando, Fl
    I saw one write up on customtacos.com. but he made a weird top mount for it thats why im trying to see if anyone else has done it on a 3rz. And I dont want one of bamas alts because my truck likes to eat alternators so I need a stock alt that I can buy at the parts store and keep swaping out under warranty.
  13. Apr 14, 2014 at 9:21 PM
    #6853
    Blackdawg
    Monte
    Wyoming/St. Louis
    PM him. Might be warrantied. I don't remember if his are just custom ones or modified or stock..not sure...can't remember haha been a while since I chatted with him about it.
  14. Apr 14, 2014 at 9:27 PM
    #6854
    4banger4x4
    Eric
    Whorelando, Fl
    Either way I always carry a spare with me on the trail and just like to beable to swap it out and keep going. And then stop at the parts store on the way home and tell them I have no clue why it stopped charging or why the bearing went bad.
  15. Apr 14, 2014 at 9:28 PM
    #6855
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha so why are you swapping in a cs144?? Or trying too..
  16. Apr 15, 2014 at 8:54 AM
    #6856
    4banger4x4
    Eric
    Whorelando, Fl
    Because I can buy two of them at the parts store and have a life time warranty on both of them. I short one out while im on the trail and I swap the spare in, and then on the way home I stop at the parts store and swap out the broken one under warranty.
  17. Apr 15, 2014 at 10:00 AM
    #6857
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ahh gotcha.
    Well hopefully they fit. If not. I bet a bracket won't be too hard to fab
  18. Apr 15, 2014 at 10:13 AM
    #6858
    4banger4x4
    Eric
    Whorelando, Fl
    The bottom should fit no problem, just might have to fab a too mount from what ive seen, and then I can buy a 5 rib pulley. But first I wanna find a junkyard 144 so I dont waste 120 bones if it doesnt work
  19. Apr 15, 2014 at 10:29 AM
    #6859
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wouldn't change the pully. Not needed. And if it's a different size you'll change the output
  20. Apr 15, 2014 at 10:49 AM
    #6860
    4banger4x4
    Eric
    Whorelando, Fl
    If I go to a small diameter ill change the output so it puts out more output at idle. But I found the 5 rib pulley and its diameter, just gotta find the diameter of the stock one that comes on what ever cs 144 I decide to go with.
