The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. May 12, 2014 at 11:40 PM
    #7141
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Bright blue silicon is pretty common is turbo land. That or black.
    Yea their intercoller setup isn't idea for us.
    And no, the cross over pipe ties into the turbo s all 6 spin it. Look at the pics below the main ones.
    Better get damn good with a TIG welder if ya want build your own that flows good
  2. May 12, 2014 at 11:51 PM
    #7142
    Blackdawg
    Monte
    Wyoming/St. Louis
    Water IC are pricey. Don't know a ton about them as most don't use them.
    Idk if it would be worth it either. Not sure you could make one that flows better or not really. Not a lot of space to work with and having a crossover pipe air ever nice.
  3. May 12, 2014 at 11:56 PM
    #7143
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh no doubt they work better. Just expensive. I know it would be easy to get and air/air that would fit just behind your grill. Lots of shapes and sizes.
    I have never looked at water ones really.
  4. May 13, 2014 at 12:00 AM
    #7144
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    :popcorn:
    Y'all are talking about trubos and custom manifolds while I'm over here wondering when I'll get to regear... Haha
  5. May 13, 2014 at 12:02 AM
    #7145
    Blackdawg
    Monte
    Wyoming/St. Louis
    I will help out for sure :cool:
    But yea..your motor has so ething odd going on...
    Or..ill just 2jz mine and you can have my 5vz. Less emissions stuff on it and less miles :p
  6. May 13, 2014 at 12:05 AM
    #7146
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Would love a 2jz swap in mine...
  7. May 13, 2014 at 12:07 AM
    #7147
    PcBuilder14
    Brent
    Nor Cal
    Should worry about a simple 4x4 swap first ;)
  8. May 13, 2014 at 12:07 AM
    #7148
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea always a possibility.
    Used to be some bad ass parts to overhaul it with forged parts and cams and valves. Not sure if LCE sells that stuff anymore.
  9. May 13, 2014 at 12:07 AM
    #7149
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  10. May 13, 2014 at 12:13 AM
    #7150
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why the hell would you only want boost for 2.5k?? Be a horrible power band.
  11. May 13, 2014 at 12:23 AM
    #7151
    Blackdawg
    Monte
    Wyoming/St. Louis
    You'll be in boost not vacuum at 2500rpm
    I would. More power available. And you would never get to really enjoy the boost since out motors top out so low and fast especially with boost
  12. May 13, 2014 at 12:30 AM
    #7152
    Blackdawg
    Monte
    Wyoming/St. Louis
    Easy to make a turbo kick in late. A 60-1 a/r .70 would do the trick I bet.
  13. May 13, 2014 at 6:16 AM
    #7153
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    One thing to keep in mind is that, just because your turbo CAN make full boost at a given RPM, doesn't mean it will at all times. If you're cruising down the interstate at 2500 RPM without accelerating, the turbo will be spinning, but your wastegate will be open preventing you from making boost. Usually, in the Evo, I'll see the boost float around from vacuum to about 2 psi just cruising around. But, since the turbo can make boost at those RPMs, I can just press the throttle and go!
  14. May 13, 2014 at 8:24 AM
    #7154
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    The wastegate is not open while cruising. It doesn't open till you have reached boost pressure for whatever spring you are running. But yes while on highway it will not make boost unless there is an additional load applied such as accelerating. Which even with cruise on won't be that often except on large hills.
  15. May 13, 2014 at 12:38 PM
    #7155
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes very good points guys.
    My second battery is fine. Was at 6v is all. Flipped the solenoid for the starter and bumped it to 12v and connected my deep cycle charger. Took like an hour and it was at 11v by itself.
    Deep cycles FTW!
    Also thank you mike for reminding me about "jumping" deep cycles.
  16. May 13, 2014 at 7:51 PM
    #7156
    Blackdawg
    Monte
    Wyoming/St. Louis
    More truck porn cause..i can..haha
    [​IMG]Frankenstein.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Frankenstein-2.jpg by Monte Nickles Photos, on Flickr
    puppies were happy to be out again!
    [​IMG]Frankenstein-4.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Frankenstein-5.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Frankenstein-6.jpg by Monte Nickles Photos, on Flickr
  17. May 13, 2014 at 7:58 PM
    #7157
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    love the last two! haha!
  18. May 13, 2014 at 8:03 PM
    #7158
    Blackdawg
    Monte
    Wyoming/St. Louis
  19. May 13, 2014 at 8:05 PM
    #7159
    SconnieHailer
    Marc
    probably was sitting on your feet im guessing haha. Loves the leg lean :D
  20. May 13, 2014 at 8:08 PM
    #7160
    Blackdawg
    Monte
    Wyoming/St. Louis
    just about..was scooting his butt across the ground working his way closer haha
