The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. May 13, 2014 at 11:23 PM
    #7181
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It is real odd. Does your Tim or one of his buddies have a lathe we could borrow? Would not require much. I would estimate maybe a 1/16" or less of material in a very small area. haha.
  2. May 13, 2014 at 11:25 PM
    #7182
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nah he doesn't have one..might know someone that does though
  3. May 13, 2014 at 11:26 PM
    #7183
    Digiratus
    Roaming the PNW
    The RedHead
    I just read the exchange you guys had, Its not clear whether he is interested in that spare or not. Are you thinking he wants all 5?
  4. May 13, 2014 at 11:27 PM
    #7184
    Blackdawg
    Monte
    Wyoming/St. Louis
    No idea :notsure:
  5. May 13, 2014 at 11:29 PM
    #7185
    Digiratus
    Roaming the PNW
    The RedHead
    Hmmm. Would take a fairly large one to be able to handle a 15" diameter object.
  6. May 13, 2014 at 11:30 PM
    #7186
    Blackdawg
    Monte
    Wyoming/St. Louis
    The local metal shop could do it I'm sure.
  7. May 13, 2014 at 11:31 PM
    #7187
    Digiratus
    Roaming the PNW
    The RedHead
    Lets see what he wants. If he only wants the 4, then maybe you and I can work something out for the 5th.
  8. May 13, 2014 at 11:31 PM
    #7188
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay ill ask him
  9. May 13, 2014 at 11:41 PM
    #7189
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks Monte
  10. May 13, 2014 at 11:42 PM
    #7190
    Blackdawg
    Monte
    Wyoming/St. Louis
  11. May 14, 2014 at 11:17 AM
    #7191
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Hmmm... I'm what sure what you mean here. The waste gate can and will open partially on partial throttle. The wastegate is controlled by the wastegate actuator, which is vacuum driven. The actuator is attached to a little arm that controls the wastegate, opening and closing it to maintain your desired boost pressure.
    The Blow-off valve, on the other hand, work just like you were describing. It won't actuate until you need to release boost on the compressor side though. The wastegate is on the turbine side of the turbo.
    I think of it this way: when I'm at 4-5k, partial throttle, I have enough mass-air-flow to spool my turbo even at partial throttle. To prevent me from getting closed loop boost at that time, my waste gate is partially open.
    Here's another way of describing what I'm talking about:
    http://www.gencoupe.com/2-0t-discus...tegate-actuator-blow-off-valve-explained.html
    Does your system work differently?
  12. May 14, 2014 at 11:40 AM
    #7192
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Just because the turbo is spinning/spooling does not mean it it's making boost. It still has to overcome atmospheric pressure. I'm not sure where you are getting information that the wastegate is open. The only thing that opens a wastegate is boost pressure (which is measured above atmospheric). Any turbo motor can be in vacuum anywhere in the rpm range if there isn't a load on the engine.
  13. May 14, 2014 at 11:46 AM
    #7193
    Lumpskie
    New Hampshire
    Recheck my post. I updated it with better information. And I should clarify. They wastegate is not always open, but may be.
    Here's a quote for what I'm trying to say:
    When this swing arm gate opens exhaust gas is bypassed from the turbo. When the gas is bypassed the turbo doesn't spin as much, which results in a boost drop. So depending on the boost level this swing arm constantly opens and closes to keep the boost level at a desired level. Then what controls this internal swing arm gate(internal wastegate)?
    This swing arm gate is controlled (opened and closed) by the actuator.
  14. May 14, 2014 at 12:08 PM
    #7194
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Exactly. The wastegate is only opened by boost pressure at a certain max then closes again till it hits that max again. Say there's a 7 psi spring in the wastegate, it won't open till there's 7 psi boost and stays open till it goes lower than 7. Therefore it is not open to "maintain" vacuum. The turbo just isn't building enough pressure to overcome atmospheric and you can still have vacuum. That's how turbo vehicles get better gas mileage, because the turbo does help compress air even when in vacuum.
    I'm not going to "argue" about it but they aren't open till boost pressure has been reached.
  15. May 14, 2014 at 12:31 PM
    #7195
    Lumpskie
    New Hampshire
    ^I'm not trying to argue either but keep in mind that the system is based on the differential boost pressure from both sides of the turbo. That's my point. I think we agree that the gate is not always open, but it does open (frequently) in cases of partial throttle, even when you are cruising. In my case, I'll sit at 2 psi, partial throttle and, as my foot moves on and off throttle, I will hear both my recirculating blow-off valve and my waste gate cycle. Hence:
    "So depending on th eboost level this swing arm CONSTANTLY opens and closes to keep the boost level at a desired level"
    Bottom line: Without the wastegate opening, you'll end up with a "closed loop" system and rely on the intermittent use of a blow off valve to prevent a runaway boost situation. The wastegate is especially designed to prevent that.
  16. May 14, 2014 at 12:37 PM
    #7196
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You don't have to have a boost controller to maintain lower boost levels. It's simple there just isn't the full load on the engine to make full boost, thats all there is to it. If I had my old car id take video to prove you can maintain a lower boost level without the wastegate being open.
    It's just like having max torque/hp at a certain rpm. It's not always there unless the engine is loaded all the way....
  17. May 14, 2014 at 12:43 PM
    #7197
    Lumpskie
    New Hampshire
    The engine doesn't have to be loaded "all the way" to make boost. In fact, most if the time it isn't. (I can hit my peak boost at 70% throttle with my boost spike) Again, I updated my post to clarify.
    Bottom Line: The waste gate prevents closed loop boost runaway. You don't need full throttle to be in that condition. In fact, you can hit that condition almost anywhere. That's why the wastegate is "constantly" moving. Not just at full throttle situations.
  18. May 14, 2014 at 12:59 PM
    #7198
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I understand how it works. But the whole reason this started is cause you were saying the wastegate is open while in vacuum which it is not.
  19. May 14, 2014 at 1:01 PM
    #7199
    Lumpskie
    New Hampshire
    OH! No, you're right. It's not open in vacuum. I must have been confused:confused: I thought you were saying you needed full throttle situations to activate your wastegate.
  20. May 14, 2014 at 1:08 PM
    #7200
    Sacrifice
    KS
    DCSB OR 4X4 LT
    :thumbsup: no I understand you don't need full throttle to build boost. But it also won't always have boost which is what I was trying to say (vacuum is still possible at any rpm in other words). This talk makes me miss my turbo 240 I had, so fun. 300hp at 2500 rpm.
    Now lets see some moar truck pictars!!!
