The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. May 21, 2014 at 8:26 PM
    #7321
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Sounds like a call or email to ECGS is in order.
  2. May 21, 2014 at 8:26 PM
    #7322
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    wish I had some helpful imput man
    i didnt deal with the shims :eek:
    head to a gear/shop tomorrow and see if they have any shims laying around?
  3. May 21, 2014 at 8:30 PM
    #7323
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Gonna try and find some tomorrow.
    But yes. A call is in order. Be downright retarded to have to pull the stupid bearings off the carrier every time to set the ring right after using a 20ton press to get them on. I have no way of getting them off without destroying them
  4. May 21, 2014 at 8:36 PM
    #7324
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    I've honestly never heard of any skims going between the bearing on the carrier. Always seen them on the outside at the race and housing. The only shims that has shims under a bearing is a pinion. Might be able to find a shop close enough that will have one but I'd be calling east coast as soon as they open.
  5. May 21, 2014 at 8:38 PM
    #7325
    Blackdawg
    Monte
    Wyoming/St. Louis
    I can't sadly as I work 6-4 so yea have to wait till later
    Pissing me off though.
  6. May 21, 2014 at 8:49 PM
    #7326
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes it does. Annoying no doubt. Thought it would disappear with the new clutch and stuff but didn't
  7. May 21, 2014 at 8:53 PM
    #7327
    Digiratus
    Roaming the PNW
    The RedHead
    #manualtranyissues
    What's a pilot bearing?
  8. May 21, 2014 at 8:54 PM
    #7328
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    x2
  9. May 21, 2014 at 8:55 PM
    #7329
    Blackdawg
    Monte
    Wyoming/St. Louis
    I dont have that mod done.
    I have to tap my pedal and hold it down to get the chirp to go away as well.
    Not sure what the fix is.
  10. May 21, 2014 at 8:56 PM
    #7330
    Blackdawg
    Monte
    Wyoming/St. Louis
    X2
  11. May 21, 2014 at 9:05 PM
    #7331
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I believe I heard a wise man one say, turn up the radio and the sound will go away:p
  12. May 21, 2014 at 9:06 PM
    #7332
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    My pilot bearing sounds like crickets. it comes and goes. If I put just a touch of pressure on the pedal it goes away..
  13. May 21, 2014 at 9:09 PM
    #7333
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't. I mean, its definitely the pilot bearing. And the clutch fork has play in it.
  14. May 21, 2014 at 10:10 PM
    #7334
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    its some stupid bearing like right in the center of the clutch that does stupid things for stupid manual transmissions
    nothing we need to concern ourselves with
  15. May 21, 2014 at 10:11 PM
    #7335
    nagorb
    Alabama
    2001 dbl cab 4x4
    LOL
    Though I might have been exaggerating on the smart thing.
  16. May 21, 2014 at 10:14 PM
    #7336
    nagorb
    Alabama
    2001 dbl cab 4x4
    Hmm...I don't know about that...he might be an engineer:eek:
  17. May 21, 2014 at 11:25 PM
    #7337
    nagorb
    Alabama
    2001 dbl cab 4x4
    In a deranged sort of way, yes.
  18. May 22, 2014 at 5:37 AM
    #7338
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ya know Ben I thought about it more as I went to bed and it could be a wore out spring in the slave cylinder.
  19. May 22, 2014 at 7:45 AM
    #7339
    Redneck92
    Concord, NC
    I find it best to roll the windows down as well. That way with the tire roar and the radio I can't hear any squeaks or rattles.
  20. May 22, 2014 at 7:48 AM
    #7340
    Redneck92
    Concord, NC
    If it sounds like crickets more than likely it's the throw out bearing. The pilot bearing would only make noise whenever the trans input and crankshaft are spinning at different rates.
