The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. May 23, 2014 at 6:06 AM
    #7381
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    It doesn't have to be down a year :spy: but it will be a while. I do have to say it's not jus throwing a turbo on there, there's a lot more work to it and then you have to track down problems that show up and all other kind of crap. And thats coming from my experience with the 240 (which was only custom intercooler/tube routing)
  2. May 23, 2014 at 7:32 AM
    #7382
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I like where this is going. :popcorn:
  3. May 23, 2014 at 7:45 AM
    #7383
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Pre-95 2wd pickups had the 7.5 rear
  4. May 23, 2014 at 9:58 AM
    #7384
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Are you planning on using stock cats? I'd suggest at least getting high flows
  5. May 23, 2014 at 10:31 AM
    #7385
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You say that now...but one you have boost it always is just a little more.
  6. May 23, 2014 at 11:00 AM
    #7386
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea my rebuild on my supra took 2.5 years.
    Sure. I bet it's over 2 months easy.
    But yea 300 is easy.
    Ahh that makes sense
  7. May 23, 2014 at 2:25 PM
    #7387
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    you will need to fly in monte every weekend for months AFTER its "done" to constantly work on it and tune it and fix the little things
    but more so you need to realistically be able to build the thing by your self, if not how do you ever hope to fix it if something goes seriously wrong? And guess what even very well built turbo set ups eat shit every now and then.
  8. May 23, 2014 at 3:06 PM
    #7388
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well...when you graduate...its time to buy a shit ton of tools and let the endless frustration of working on vehicles begin!
  9. May 23, 2014 at 6:36 PM
    #7389
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Make sure your workspace is comfy... a radio/sound system is a good idea. I've spent more time in my garage than i thought i would... nice lighting and a radio makes a huge difference, also concrete floors are a must, or that rubber tile stuff is nice. It's the little stuff :D
  10. May 23, 2014 at 8:33 PM
    #7390
    Blackdawg
    Monte
    Wyoming/St. Louis
    Working under a truck with headphones...not gonna work haha
    Cheap stereo ain't bad.
    But it'll be fun no doubt.
    Also...one of the top rules of overland expedition truck Ben...don't fuck with the engine, leave it stock. Just saying. Haha
    Just pulled the front diff. Mother of fucking god what a pitfa. Couldn't get the fill or drain plugs off. Mounts where a bitch. Just...what a bitch.
    So pissed I don't have lockers. Doing this twice is gonna suck.
  11. May 23, 2014 at 9:24 PM
    #7391
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Couldn't get the drain? I always have trouble with that 10 mm allen socket thing. Not sure why its so hard.
    Also, agree a 100% on not messing with the engine for best dependability. Stock is best.
  12. May 23, 2014 at 9:38 PM
    #7392
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ya I've tried a number of times with head phones. Just doesent work. Always rip em out when I'm trying to think or they also get caught on stuff.
    And that's what I thought on the expo thing but didnt say anything. High hp turbo motor and reliable long distance off road expo truck don't really go together, sorry. It just doesent
  13. May 23, 2014 at 9:42 PM
    #7393
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Which is why I went away from the supercharger idea... Haha don't want more parts to have to worry about.
  14. May 23, 2014 at 9:50 PM
    #7394
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh he's gonna come in and say if it's built right it's perfectly fine and it won't break yada yada
  15. May 23, 2014 at 9:51 PM
    #7395
    PcBuilder14
    Brent
    Nor Cal
    Can't predict everything. Sometimes stuff just breaks haha
  16. May 23, 2014 at 10:05 PM
    #7396
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    The front diff was so shitty. I am glad we started with it first. It made the rear seem like nothing.
  17. May 23, 2014 at 10:24 PM
    #7397
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's a 12 for the drain and 10 for the fill.
    Yea big boost especially custom..not always the smartest idea.
    Sc is okay long as you don't over do it IMO.
    Yea freaking sucked. Now can't figure out how to get the carrier off the clam shell
  18. May 23, 2014 at 10:42 PM
    #7398
    Digiratus
    Roaming the PNW
    The RedHead
    Whatever, haha
    Maybe this? :notsure:
  19. May 23, 2014 at 10:49 PM
    #7399
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm hold back ,y dad from that. He is like Jeremy clarkson after 10 mins of dicking with it haha
  20. May 24, 2014 at 12:03 AM
    #7400
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Mine fucking stripped with very little torque applied, i fucking hate allen sockets. I've gotta weld a bolt to it to get it off, did it for another local member too who had stripped his.
