The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. May 30, 2014 at 11:32 AM
    #7461
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Haha can't believe you forgot that haha
  2. May 30, 2014 at 4:02 PM
    #7462
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Eh, none of the write ups really went through what you were suppose to swap over. Just how to get it out. Everyone said "it's simple; you just swap it in" so I assumed any gear parts would be taken care of :notsure:. By the time we did get it dropped we both just wanted to get it in and not see a front diff again :p. I am rather surprised they leave it out. I guess my mistake isn't all that uncommon.
    However, I am surprised that was my only real issue. I am prone to forget things or finish with bolts left over. I should never be a mechanic :p. I just swapped out my gear oil and found a washer that goes to the rear plugs when I was all done. Just hoping its for the fill plug :pray:.
  3. May 30, 2014 at 6:33 PM
    #7463
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Wait so my idea worked? Wow finally got a good idea, only took me 28 years:eek:
  4. May 30, 2014 at 7:42 PM
    #7464
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha yea it did. Thank god
    Can't get the inner race in for the pinion now..
  5. May 30, 2014 at 8:35 PM
    #7465
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Nice. I knew you would get it outa there. :rolleyes: <stubborn>
    IMO this is how they should come from the factory.
  6. May 30, 2014 at 8:38 PM
    #7466
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea was a pain
    Also..wtf. Yet ANOTHER part that doesn't fit. These kits fucking suck ass. Fuck Yukon. My solid pinion spacer doesn't fit either pinion.
  7. May 30, 2014 at 8:53 PM
    #7467
    Digiratus
    Roaming the PNW
    The RedHead
    My guess is that is on ECGS, not Yukon. Pretty sure the solid spacers are not part of the standard install kits. They are an addon.
    Still, should fit, regardless. A little surprised really. Do the shims for the spacer fit?
  8. May 30, 2014 at 9:13 PM
    #7468
    Blackdawg
    Monte
    Wyoming/St. Louis
    There is a lip in it that doesn't let it slide all the way down. The label is for 7.5" Toyota.
  9. May 30, 2014 at 9:13 PM
    #7469
    BabyTaco
    Wyoming
    2011 RC Tacoma
    That sucks man. Make it fit!
  10. May 30, 2014 at 9:18 PM
    #7470
    Blackdawg
    Monte
    Wyoming/St. Louis
    If I had a machining lathe I could. No way could I do it accurately enough by hand
  11. May 30, 2014 at 9:23 PM
    #7471
    nagorb
    Alabama
    2001 dbl cab 4x4
    Awesome!
    Sucks, makes me think if/when I re gear I won't be doing it myself:D
  12. May 30, 2014 at 9:58 PM
    #7472
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wish I could have afforded not too. Jesus.
  13. May 30, 2014 at 10:14 PM
    #7473
    Digiratus
    Roaming the PNW
    The RedHead
    Knowledge is King. Now you have it.
    Besides, you would not have it any other way. This one is just one of the harder ones. :cool:
  14. May 30, 2014 at 10:24 PM
    #7474
    Blackdawg
    Monte
    Wyoming/St. Louis
    True i am, glad to have done..well..be doing it..not done yet..
    But still..missing out on mountain time now :mad: and the fact the part I paid for that don't fit really REALLY bugs me
    It looks like I could press it on..but what worrys me is it's 60 thousands smaller then the crush one on the stock one
  15. May 30, 2014 at 10:31 PM
    #7475
    Digiratus
    Roaming the PNW
    The RedHead
    .060 seems like a lot. That would be a question for Zuk. Is the solid spacer supposed to fit veeeeerrrry snug on the shaft?
    One of those well kept secrets no doubt.
  16. May 30, 2014 at 10:39 PM
    #7476
    Blackdawg
    Monte
    Wyoming/St. Louis
    Who is Zuk?
    And how shit! my freaking roller bearing I pressed on the the pinion almost came totally apart! The whole thing!
    Good...god..seriously...w..t..f..Yukon????
  17. May 30, 2014 at 10:49 PM
    #7477
    Digiratus
    Roaming the PNW
    The RedHead
    This really surprises me. An incredible resource and a legendary toyota diff builder.
    http://www.gearinstalls.com/
  18. May 30, 2014 at 10:49 PM
    #7478
    Blackdawg
    Monte
    Wyoming/St. Louis
    What a shit show..
    And of course it's the weekend so can't call ECGS or Yukon. :frusty:
    My rear shims better show up tomorrow or this weekend is going to suck
  19. May 30, 2014 at 10:51 PM
    #7479
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ha I found one of those threads but the site is so poorly put together there was no button to get to the home page.
    Ill browse it and shoot him an email
  20. May 30, 2014 at 10:56 PM
    #7480
    Digiratus
    Roaming the PNW
    The RedHead
    I only kno of his work by browsing. But one thins is obvious, he is old school. Having a modern website is not high on the list of priorities. :D
