The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jun 1, 2014 at 10:26 PM
    #7541
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :yay::yay::yay: :yay::yay::yay:
    :goingcrazy::goingcrazy::goingcrazy: :goingcrazy::goingcrazy::goingcrazy:
    I FUCKING GOT THE BASTARD IN!!!!! :woot:
    I FEEL LIKE THIS
    Hot damn i can't believe i spent so long on that. :frusty:
    ended up taking super super super fine sandpaper to the outside of the race. Slid right in after that with the cool jig Zuk told me about :D
  2. Jun 1, 2014 at 10:30 PM
    #7542
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  3. Jun 1, 2014 at 10:32 PM
    #7543
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Haha prerunner boy tried to make a joke
  4. Jun 1, 2014 at 10:39 PM
    #7544
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Haha you can't come up with another joke
  5. Jun 1, 2014 at 10:42 PM
    #7545
    Blackdawg
    Monte
    Wyoming/St. Louis
    Calm down boys..as of now..no parting out will happen now that the major obstacle is done :p haha
    Still need to finish the solid pinion spacer, only a bit more to grind and it'll be golden. Then..bolt it all up and check the BL and wear.
  6. Jun 2, 2014 at 5:46 AM
    #7546
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Before you sanded it down did you try freezing it and or dry icing it to shrink it before putting it in?
    Glad you got it though!
    Hey, if we are claiming shit on the truck i want the 4 hids on the roof rack k?
    7 pepe touches and a snickers. Yes? Deal? Good!
  7. Jun 2, 2014 at 7:17 AM
    #7547
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    I just checked in after a long time. Good job on fighting your way through that diff, Monte. I can't wait to see this rig in person.
  8. Jun 2, 2014 at 3:36 PM
    #7548
    Blackdawg
    Monte
    Wyoming/St. Louis
    I did not. My mom would throw a fit finding a truck part in the freezer haha
    And only want the Hellas? Haha figures. You love those after Christina haha
    Thanks man! Ditto to you as well!
  9. Jun 3, 2014 at 9:03 PM
    #7549
    Digiratus
    Roaming the PNW
    The RedHead
  10. Jun 3, 2014 at 9:07 PM
    #7550
    Blackdawg
    Monte
    Wyoming/St. Louis
    Didn't work on it today :eek: barely did last night too. I only finished grinding the solid spacer to fit. Took an hour and a half. That thing is hard hard steel.
    I'm headed to bed tho. My head is killing ,e and allergies are kicking my ass. Pulling 13 hour days is hurting too.
    Ill be done this weekend for sure though.
  11. Jun 3, 2014 at 9:10 PM
    #7551
    Digiratus
    Roaming the PNW
    The RedHead
    :sick: The candle ain't long enough...
  12. Jun 3, 2014 at 9:18 PM
    #7552
    Blackdawg
    Monte
    Wyoming/St. Louis
    Never is..
  13. Jun 3, 2014 at 9:31 PM
    #7553
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Do you think you'll be rolling by Saturday?
  14. Jun 4, 2014 at 4:28 AM
    #7554
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not sure really
  15. Jun 4, 2014 at 8:17 AM
    #7555
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Gonna get truck painted soon monte, can't decide between the color of your original body or the 2nd gen MGM
  16. Jun 4, 2014 at 8:30 AM
    #7556
    PcBuilder14
    Brent
    Nor Cal
    2nd gen MGM!
  17. Jun 4, 2014 at 8:55 AM
    #7557
    LSC15
    Logan
    2008 TRD D-Cab
    I mixed some MGM the other day and it came out so nice. I put blues and other colors in it
  18. Jun 4, 2014 at 9:47 AM
    #7558
    BabyTaco
    Wyoming
    2011 RC Tacoma
    MGM is a gorgeous color. Do it!
  19. Jun 4, 2014 at 9:50 AM
    #7559
    PcBuilder14
    Brent
    Nor Cal
  20. Jun 4, 2014 at 2:10 PM
    #7560
    Blackdawg
    Monte
    Wyoming/St. Louis
    Really? Why?
    I have seen the MGM. Is very nice. I'd go with mine but I am pretty darn bias :p
    Where do you find 5-7 grand lying around for a good paint job?
    I see it's a Vimeo link. Ill get on my computer in a minute to see it
