The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jun 6, 2014 at 2:57 PM
    #7581
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sounds different..be interesting to see
  2. Jun 6, 2014 at 6:32 PM
    #7582
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Here are some pics...
    The tan side of the zipper slides off and allows you to choose either driver or passenger side to have the zipper on.
    This is the one side with the tubing, I've since moved it like yours since that's the only way it makes sense haha
  3. Jun 6, 2014 at 6:56 PM
    #7583
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea you fixed it the right way.
    But interesting. Yes at is a new feature. The part mine zips to is not movable like that.
  4. Jun 7, 2014 at 3:05 PM
    #7584
    Blackdawg
    Monte
    Wyoming/St. Louis
    Welp put the front diff together..holy shit. Not even close to in spec.
  5. Jun 7, 2014 at 3:16 PM
    #7585
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Regear level: Monte
  6. Jun 7, 2014 at 3:34 PM
    #7586
    Blackdawg
    Monte
    Wyoming/St. Louis
    Zuk told me to add a .020 shim to the pinion...now to get the pinion bearing off...
  7. Jun 7, 2014 at 4:14 PM
    #7587
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    FIFY
  8. Jun 7, 2014 at 4:15 PM
    #7588
    Blackdawg
    Monte
    Wyoming/St. Louis
    True. I gotta build something real quick like..
  9. Jun 7, 2014 at 4:23 PM
    #7589
    Digiratus
    Roaming the PNW
    The RedHead
    Makes me wish I could be there to watch this process.
  10. Jun 7, 2014 at 4:52 PM
    #7590
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha its not that exciting haha
  11. Jun 7, 2014 at 6:57 PM
    #7591
    Blackdawg
    Monte
    Wyoming/St. Louis
    And done. Homemade bearing splitter took a while to make. But, least I have one now!
  12. Jun 7, 2014 at 7:24 PM
    #7592
    Digiratus
    Roaming the PNW
    The RedHead
    What did you make? It doesn't actually split a bearing does it? It splits it off the pinion shaft right? Pic?
  13. Jun 7, 2014 at 7:31 PM
    #7593
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes off the shaft. It's basically a wedge that is circular to go inbetween the bearing and pinion. No other way to separate it.
    I haz many pics but still working so give me a few hours :p
  14. Jun 7, 2014 at 8:22 PM
    #7594
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    That's interesting... Would solve my problem of the cover being in the way when I grab a beer from the fridge in the back seat. I don't think my zipper piece can be removed but if it can I could spin the cover around so it opens in the opposite direction that the tent opens.
  15. Jun 7, 2014 at 9:58 PM
    #7595
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn, new wear is okay. Better then before but still not good. Another pinion shim it is!
    My bearing preload is gonna be hard to dial in..
  16. Jun 7, 2014 at 10:10 PM
    #7596
    Blackdawg
    Monte
    Wyoming/St. Louis
    Holy crap I'm an idiot..
    So I missed that the OEM pinion had a big ass spacer on it. Used my new fancy bearing splitter to seperate it and bam. Damn thing is huge. 0.086 under the bearing. I had nothing on my first test and not 0.020 on my second.
    Thus..shitty patterns.
    So!
    Disassemble again!
    Well...my roller bearing just came apart...:frusty:
  17. Jun 7, 2014 at 10:23 PM
    #7597
    Digiratus
    Roaming the PNW
    The RedHead
    :eek: ruined?
  18. Jun 7, 2014 at 10:35 PM
    #7598
    Blackdawg
    Monte
    Wyoming/St. Louis
    No, just needed put back together. Pita. Got it done and pressed back on tho with the new spacer.
    Should know how well it is in 5 minutes or so
  19. Jun 7, 2014 at 10:40 PM
    #7599
    Digiratus
    Roaming the PNW
    The RedHead
  20. Jun 7, 2014 at 11:12 PM
    #7600
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well if it ain't one thing it's another..partial stripped the pinion nut. God damn it
