The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jun 7, 2014 at 11:15 PM
    #7601
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I hope threads still good on the pinion?
  2. Jun 7, 2014 at 11:20 PM
    #7602
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea they are fine. Not really sure how the nut stripped even..no idea how ill get a new one either
  3. Jun 7, 2014 at 11:26 PM
    #7603
    Digiratus
    Roaming the PNW
    The RedHead
    Wait, was that the stock one? Or will the stock one not work?
    I know on the rear you probably went to a 29 spline (up from 27) pinion but the front setup should be the same size isn't it? I would think the nut sizes remain the same too.
    :notsure:
  4. Jun 7, 2014 at 11:29 PM
    #7604
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes same nut works. But the one Yukon gave me didn't have a big washer on it so it was smaller and was barely wide enough to pull down the flange. I use the Yukon on to sart it. Then the OEM one to finish it as it was wide and fit easy.
    Now. Neither will go on good.
  5. Jun 7, 2014 at 11:33 PM
    #7605
    Digiratus
    Roaming the PNW
    The RedHead
    Ouch. Sure its not the threads on the pinion that are messy?
  6. Jun 7, 2014 at 11:41 PM
    #7606
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea they look fine. Pinion steel is hard a fuck. Nuts aren't and a bit chewed.
    Maybe I can get one at a parts store.
    :itllbuffout:
    Was pretty sure I'd drive it this Sunday..but..may not now..
  7. Jun 7, 2014 at 11:47 PM
    #7607
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Should be able to get a pinion nut from a parts store. Fairly common.
  8. Jun 7, 2014 at 11:51 PM
    #7608
    Blackdawg
    Monte
    Wyoming/St. Louis
    For a Toyota? Hope so..haha
  9. Jun 8, 2014 at 12:00 AM
    #7609
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    You should tally up the hours you put into this, pay yourself, and then buy some lockers.
  10. Jun 8, 2014 at 12:02 AM
    #7610
    Digiratus
    Roaming the PNW
    The RedHead
    :laughing:
  11. Jun 8, 2014 at 12:03 AM
    #7611
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    I'm not buying lockers this year for two reasons..
    One: can't afford it
    Two: I don't want to tear these things apart again till at least next year haha
    But a lot a lot of hours no doubt
  12. Jun 8, 2014 at 12:04 AM
    #7612
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    MOAB 2015!
  13. Jun 8, 2014 at 12:09 AM
    #7613
    Blackdawg
    Monte
    Wyoming/St. Louis
    No I promised myself no Moab till a lock since I want to do more challenging trails haha
  14. Jun 8, 2014 at 12:13 AM
    #7614
    Blackdawg
    Monte
    Wyoming/St. Louis
    Slightly yes haha
  15. Jun 8, 2014 at 12:13 AM
    #7615
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Lockers could also reduce the risk of breaking stuff.
  16. Jun 8, 2014 at 12:15 AM
    #7616
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh..not really..increase cv failure.
    Plus..lockers tend to take you more places your shouldn't go..sorta..so..more damage haha
  17. Jun 8, 2014 at 12:18 AM
    #7617
    95 taco
    95 taco Battle Born
    Running the same trails you could potentially go slower (less damage possibly), or even choose different lines (less damage, or a line that would keep you off your skids).
    Sucks about the nut.
  18. Jun 8, 2014 at 12:20 AM
    #7618
    Blackdawg
    Monte
    Wyoming/St. Louis
    No one takes the easy line when they get lockers..or the easy trails haha least I sure wont.
  19. Jun 8, 2014 at 12:20 AM
    #7619
    Blackdawg
    Monte
    Wyoming/St. Louis
    :cool:
    :anonymous:
  20. Jun 8, 2014 at 12:24 AM
    #7620
    95 taco
    95 taco Battle Born
    depends on the type of person.
    Nope, maybe Moab some year.
