The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jun 8, 2014 at 12:41 AM
    #7641
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Really? Swapping your drums on would be easy and axle shafts into your drums.
    Never saw the need for rear disks either so much.
  2. Jun 8, 2014 at 12:45 AM
    #7642
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    well id need a press since th eaxles wouldnt be the same length and the shop wanted 500 to do the swap so i could buy a complete axle for less than that
  3. Jun 8, 2014 at 12:55 AM
    #7643
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh sheesh. 500? That's ridiculous.
  4. Jun 8, 2014 at 12:55 AM
    #7644
    JuansTaco
    Juan
    gilbert az
    yep thats why i didnt keep it
  5. Jun 8, 2014 at 12:56 AM
    #7645
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good call haha
  6. Jun 8, 2014 at 12:59 AM
    #7646
    JuansTaco
    Juan
    gilbert az
    ya but im glad i did my SUA on my own mostly. gave me a lot of knowledge and know how to help others.
  7. Jun 8, 2014 at 1:08 AM
    #7647
    Blackdawg
    Monte
    Wyoming/St. Louis
    For sure man. DIY FTW!
  8. Jun 8, 2014 at 1:08 AM
    #7648
    JuansTaco
    Juan
    gilbert az
    Garage fab FTW haha.
  9. Jun 8, 2014 at 1:10 AM
    #7649
    Blackdawg
    Monte
    Wyoming/St. Louis
    That too :D :cool:
  10. Jun 8, 2014 at 12:49 PM
    #7650
    Blackdawg
    Monte
    Wyoming/St. Louis
    Parts store didn't have the pinion nut...
    FML
    :frusty:
  11. Jun 8, 2014 at 1:56 PM
    #7651
    Blackdawg
    Monte
    Wyoming/St. Louis
    Was gonna wait and do one big post but screw it.
    Continuing the build of the front diff..
    So this is where i left the solid collar spacer..
    [​IMG]Front diff assembly-6.jpg by Monte Nickles Photos, on Flickr
    the bench to grind!
    [​IMG]Front diff.jpg by Monte Nickles Photos, on Flickr
    after first pass..
    [​IMG]Front diff-5.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Front diff-4.jpg by Monte Nickles Photos, on Flickr
    so more grinding..
    [​IMG]Front diff-2.jpg by Monte Nickles Photos, on Flickr
    Done!
    [​IMG]Front diff-3.jpg by Monte Nickles Photos, on Flickr
    Now to finish getting the inner race in. Thanks to the god of diffs, Zuk, he told me to do this. Took a lot of messing with but i got it to work after many attempts.
    first i set it up like so
    [​IMG]Front diff-6.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Front diff-7.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Front diff-8.jpg by Monte Nickles Photos, on Flickr
    of course that was stupid for three reasons. One, on the outer pinion side is where i needed to wrench on. Two, having the two nuts on the inside isn't nessicary. Three, the washer hit the housing so i couldn't get it down even if i wanted to.
    So, after more messing about the final setup looked like so.
    I used the old bearing race to help press in the new one.
    [​IMG]Front diff-9.jpg by Monte Nickles Photos, on Flickr
    and had most the all thread in the inside.
    Of couse i also used super fine grit sand paper, 2000 grit, on the outside of the race and then used a big ass wrench and the screw drive to counter turn. Slide right in with some man handling.
    hell..yes..
    that was a mile stone in itself let me tell you. I hope that trick alone helps someone out there out cause i beat my head against the way for literally HOURS trying to get that fucker in.
    but its done now :D
    So with that all done, i put the pinion in and and ratched down the outer bearing, slapped the ring housing on and did a pattern check. My god was it off...
    needless to say...that..is..horrible..haha I wasn't sure if my ring was way off or the pinion(which it was off, i shall show you in a second) so i emailed the god Zuk again and he told me to add more to the pinion..Which made sense to me especially since i didn't have a single spacer on there because i THOUGHT the OEM one didn't have one..but i was wrong.
    But now i had another problem, how the hell do i get the bearing off it without it getting destroyed.
    Time to build a bearing splitter!
    Went through the scrap plate we had lying around and found a perfect piece, quiet literally perfect. Mike you'll reconige this as the chunk i cut out your bumper reinforcement plate out of :p
    1/4'' boiler plate, it'll work nicely :cool:
    Fired up the good ole torch and cut off the long piece and was left with a 6x6 about piece.
    [​IMG]Front diff-10.jpg by Monte Nickles Photos, on Flickr
    took a square, a washer, and file to mark it and drew this out.
    [​IMG]Front diff-11.jpg by Monte Nickles Photos, on Flickr
    and went on cutting. First cut
    [​IMG]Front diff-12.jpg by Monte Nickles Photos, on Flickr
    and second
    [​IMG]Front diff-13.jpg by Monte Nickles Photos, on Flickr
    fired up the bench grinder and spend a long time grinding. Damn 1/4'' boiler plate is hard shit. Basically i ground only on one side to create a wedge, or knife edge to go inbetween the bearing and pinion.
    turned out alright.
    [​IMG]Front diff-14.jpg by Monte Nickles Photos, on Flickr
    From there i put in on the pinion, used two clamps to hold it in place, and put it on the press and let it rip.
    [​IMG]Front diff-15.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Front diff-16.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Front diff-17.jpg by Monte Nickles Photos, on Flickr
    worked great! bit of an explosion after it pops out but still works well.
    [​IMG]Front diff-18.jpg by Monte Nickles Photos, on Flickr
    From there i added a small .020 shim. Wear pattern barely changed at which point i decided to look at the OEM pinion one last time and sure as shit...had a big ass shim on it :facepalm:
    SOOOO..pulled it apart and there it was.
    [​IMG]Front diff-19.jpg by Monte Nickles Photos, on Flickr
    And now im am without a pinion nut and can't finish my diff :pout: i am almost certain i would be driving it by tonight if i would be able to get a nut.
    Oh well..
  12. Jun 8, 2014 at 4:01 PM
    #7652
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    nice bearing splitter :cool:
  13. Jun 8, 2014 at 4:08 PM
    #7653
    Blackdawg
    Monte
    Wyoming/St. Louis
    It works :p haha
    now We(Dad, Tim and i) have one :p haha im sure Tim might buy one..but..maybe not haha
  14. Jun 8, 2014 at 10:49 PM
    #7654
    Blackdawg
    Monte
    Wyoming/St. Louis
    So since i was dead in the water today, did some chores..cleaned up some stuff..
    then went to my stomping ground with the dogs to stretch out the legs a bit of Igor the double cab. Pushed the stock suspension a bit but had fun and was gorgeous. I needed it bad, so did the dogs :p was fun.
    Picture whoring:
    [​IMG]Igor by Monte Nickles Photos, on Flickr
    [​IMG]Igor 2 by Monte Nickles Photos, on Flickr
    [​IMG]Igor 3 by Monte Nickles Photos, on Flickr
    [​IMG]Burning grass by Monte Nickles Photos, on Flickr
    [​IMG]Bad lands by Monte Nickles Photos, on Flickr
    [​IMG]Wyoming.jpg by Monte Nickles Photos, on Flickr
  15. Jun 8, 2014 at 10:57 PM
    #7655
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    What happened to the pinion nut?
  16. Jun 8, 2014 at 11:02 PM
    #7656
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    lol
  17. Jun 8, 2014 at 11:02 PM
    #7657
    Blackdawg
    Monte
    Wyoming/St. Louis
    just got chewed up. Won't go on now without starting to cross thread.
  18. Jun 8, 2014 at 11:09 PM
    #7658
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    cross thread or torqued to spec, tight it tight!
    also your first pattern was pretty awesome :laugh:
    not that I would do any better. front clam is teh ghey
  19. Jun 8, 2014 at 11:15 PM
    #7659
    Blackdawg
    Monte
    Wyoming/St. Louis
    It was my own fault. I had no shims under the inner bearing haha i needed to start with the OEM 0.086..thats a lot haha
    and id be okay with the saying fuck it and cross thread it but i have two things holding be back..
    1) i still have to tear it apart to check final pattern
    2) id like to add a locker to it someday haha
  20. Jun 9, 2014 at 4:33 AM
    #7660
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ooooo me likely :thumbsup:
