The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Aug 1, 2014 at 9:39 PM
    #8061
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Waitin' for the steeeeeeeeeeeeeeeeeeeeeerin rack!
  2. Aug 2, 2014 at 11:22 AM
    #8062
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Should be done today finally. I hope.
  3. Aug 2, 2014 at 7:57 PM
    #8063
    Blackdawg
    Monte
    Wyoming/St. Louis
    We'll SOB. Got rained out.
    Pretty much done. Decided last minute to swap my bushings over to the new rack as they weren't that tore up.
    Just need to button up the lines and add fluid. Bleed brakes. Then I can take it off the truck. Then swap in a new cv.
  4. Aug 2, 2014 at 8:54 PM
    #8064
    Digiratus
    Roaming the PNW
    The RedHead
  5. Aug 2, 2014 at 8:56 PM
    #8065
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's still raining here...wtf. Not like wyo at all
  6. Aug 2, 2014 at 9:34 PM
    #8066
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    When you take it off of the trailer make sure you have the trailer hooked up to another truck.
  7. Aug 2, 2014 at 9:37 PM
    #8067
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well yea haha that and I have to move the trailer anyways.
    Gotta find a truck to do it with though.
  8. Aug 2, 2014 at 9:52 PM
    #8068
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good lord I wouldnt do that anyways. A 8000lb load would not go well on Igor haha
  9. Aug 2, 2014 at 10:04 PM
    #8069
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    That could get interesting pretty quickly.
  10. Aug 2, 2014 at 10:11 PM
    #8070
    Blackdawg
    Monte
    Wyoming/St. Louis
    Could jump it off
    :itllbuffout:
  11. Aug 3, 2014 at 9:32 AM
    #8071
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Yeah, i mean it is a racetruck afterall
  12. Aug 3, 2014 at 10:25 AM
    #8072
    Blackdawg
    Monte
    Wyoming/St. Louis
  13. Aug 3, 2014 at 8:57 PM
    #8073
    Digiratus
    Roaming the PNW
    The RedHead
    Did it stop raining? :rain:
  14. Aug 4, 2014 at 1:35 AM
    #8074
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. But have an outer tie rod issue now. Thread got fubared up. Gotta get a new one
  15. Aug 4, 2014 at 9:15 AM
    #8075
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Time to SAS :spy:
  16. Aug 4, 2014 at 1:39 PM
    #8076
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    When swapping out my eibach/5100s for Saw coilovers do I need to unbolt anything other than lower bolt and upper bolts on the coil strut assembly?
  17. Aug 4, 2014 at 1:42 PM
    #8077
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    May have to loosen the LCA bolt or UBJ depending on how far you can make your suspension droop to remove/replace you coilovers.
  18. Aug 4, 2014 at 3:19 PM
    #8078
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ha!
    No :p
    No. Should go right in. Get a pry bar and have a buddy do this
    IMG_8009.jpg by Monte Nickles Photos, on Flickr
    That will give you all the room you should need
    Shouldn't have to do that with the above technique.
  19. Aug 4, 2014 at 6:36 PM
    #8079
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I used the bottle jack. Put the base on the UCA and the braced it agaisnt a block of wood on the wheel well. Works good if you dont have an extra hand.
  20. Aug 4, 2014 at 6:46 PM
    #8080
    PcBuilder14
    Brent
    Nor Cal
    Seems like that method works well for some and not others. Mine wouldn't go low enough, period, until the upper ball joint was taken apart.
    Tried the bottle jack method, and it couldn't push down enough for me.
