The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Aug 23, 2014 at 9:27 PM
    #8261
    cmj
    cmj Well-Known Member
    Oregon
    98 Tacoma 4x4
    Do you realize how many ball joints you sold for camelback Toyota? I'd guess at least 10 pairs
  2. Aug 23, 2014 at 9:34 PM
    #8262
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I demand reimbursement!!!!
    Haha
  3. Aug 23, 2014 at 9:48 PM
    #8263
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    captain balljoint
  4. Aug 23, 2014 at 9:56 PM
    #8264
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ill bust your ball joints..
  5. Aug 23, 2014 at 9:56 PM
    #8265
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I can say I'm one of those 10 pairs lol
  6. Aug 23, 2014 at 10:01 PM
    #8266
    cmj
    Oregon
    98 Tacoma 4x4
    Same here! I knew I needed to do it but Monte's ordeal got me to cash out on a pair.
  7. Aug 23, 2014 at 10:03 PM
    #8267
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm just providing a service to you all...hahaha
  8. Aug 23, 2014 at 10:43 PM
    #8268
    Blackdawg
    Monte
    Wyoming/St. Louis
    Like size and stuff?
    Thread is 1.25 pretty sure. Fine thread. 40mm bolt I think not sure though. Torque is 45ft/lb don't forget red locktite.
    Maybe someone can confirm the length.
  9. Aug 24, 2014 at 7:43 AM
    #8269
    Blackdawg
    Monte
    Wyoming/St. Louis
    That sounds right size wise. If your just going to the parts store make sure they are grade 8.8.
    I can tell you I torqued mine more then 45ftlbs :p
    You won't fuck up.
    Or go to Toyota and buy Toyota bolts but they are a bit pricey.
  10. Aug 24, 2014 at 8:50 AM
    #8270
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    Hey monte, in case you didn't know already, replace ONLY with Toyota Factory LBJ, I used a 555 once and it ended similar to yours. The toyota ones move freely with little effort, the 555 or moog (same thing) grind in the cup until they pop out.
  11. Aug 24, 2014 at 10:04 AM
    #8271
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Nice!!
  12. Aug 24, 2014 at 11:35 AM
    #8272
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    That is a sweet shot. :cool:
  13. Aug 24, 2014 at 7:21 PM
    #8273
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  14. Aug 24, 2014 at 8:41 PM
    #8274
    Blackdawg
    Monte
    Wyoming/St. Louis
    That sounds better then 45. I know mine are just..tight haha
    Don't worry. They aren't staying on. OEM ones go on at Christmas. But the 555 were just available to me local the same day. I knew they would last the 1200 miles or so for my trip.
    Seriously. Sick photo
  15. Aug 24, 2014 at 10:04 PM
    #8275
    Blackdawg
    Monte
    Wyoming/St. Louis
    before i go to bed and start school tomorrow...My wheeling season is over :pout:
    BUT
    got some awesome shots to remind me of my awesome home land while i suffer through St louis city life. Like this one :)
    [​IMG]SOSMeet.jpg by Monte Nickles Photos, on Flickr
  16. Aug 24, 2014 at 10:45 PM
    #8276
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea just missed it by like a day or two. Its a great photo. Imma gonna steal it for FB i think :p haha
  17. Aug 25, 2014 at 12:37 PM
    #8277
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
  18. Aug 25, 2014 at 1:04 PM
    #8278
    Blackdawg
    Monte
    Wyoming/St. Louis
    Tony! whats up man
  19. Aug 26, 2014 at 12:39 AM
    #8279
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Aug 26, 2014 at 7:17 AM
    #8280
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    :jellydance:
    Those are some awesome pictures!
