The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Sep 1, 2014 at 9:03 PM
    #8381
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    So neither option applies in our case. We already do CB and are feeling its limitations.
    What are that advantages of a dual band radio? Is that 2 meter and 70 centemeters? Monte and I talked a little bit about this that day we were waiting for you and the trailer but there is so much information, it is hard to take it all in at once. Hearing it again will help.
    When do you use 70CM and when 2M. Is it a single antenna?
  2. Sep 1, 2014 at 9:10 PM
    #8382
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea same antenna. The thing with dual band is you can monitor and broadcast on two frequencies. Thats the main pro.
    With my dads and my radio we can set them up as repeaters but to do that we have to have one channel on 70cm and one on 2m since the radio can not listen and broadcast at the same time on the same band.
    Really different repeaters in the areas will use either 70cm or 2m. Just allows you more options.
    Also because they are different wave lengths they do have some pros and cons with regards to distance and such. 2m travels farther I believe due to the larger wave length
  3. Sep 1, 2014 at 9:26 PM
    #8383
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    ^^^ what he said except I'm not sure 2m goes further. I'll have to research that.
  4. Sep 1, 2014 at 9:32 PM
    #8384
    Digiratus
    Roaming the PNW
    The RedHead
    Is a single band radio always 2 meter?
  5. Sep 1, 2014 at 9:34 PM
    #8385
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not always. But it's the more popular choice
    Yea its one or the other. Or its that 70cm bounces better or something. ..I cant remember
  6. Sep 2, 2014 at 7:32 AM
    #8386
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    2m and 70cm travel about the same. The big difference in distance is the antenna. Depending on the antenna depends if it send out the signal in more of a flat "horizontal" pattern (great for flat terrain)or if it is more omni directional sending the signal out in more of a circular direction (better for mountainous terrain).
    A good dual band radio is more versatile in traveling around to different areas. Some places have more repeaters of one or the other. Although I would say 2m is more common for Hams, while 70cm is more common for government radios. If you have a 70cm radio you can monitor (but not TX) on a lot of police and fire bands.
    Depending on the dual band radio, you can also setup APRS on one side while still using the other side to talk. APRS is a location beaconing system. This can share you GPS location to others around you and if close enough to a station setup as an igate, it will relay your location to the Internet for the whole world to be able to see were you are. You can even send text messages via APRS.
    Another use for a dual band is to talk/monitor two different freqs. There are tons of reasons while you would want to do this, But I wont list them all.
  7. Sep 2, 2014 at 11:20 AM
    #8387
    Blackdawg
    Monte
    Wyoming/St. Louis
    Chip! About time you chimed in.
    Thanks for more info.
    I tried doing dprs or aprs but couldn't get it to work on my way down here. Gotta play with it some more.
  8. Sep 2, 2014 at 11:23 AM
    #8388
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    What radio do you have?
  9. Sep 2, 2014 at 11:23 AM
    #8389
    Blackdawg
    Monte
    Wyoming/St. Louis
    Icom 5100.
  10. Sep 2, 2014 at 11:25 AM
    #8390
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha for sure man. It is a lot to take in. But pretty damn cool when said and done
  11. Sep 2, 2014 at 11:39 AM
    #8391
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    That's a cool looking radio.
    It doesn't do traditional APRS, it does D-PRS. This is the part of ham radio that is really shitty. Almost every manufacture has it's own propitiatory protocol for things, and none of them share/talk to each other. Although APRS is pretty much universal among them all.
    Your D-Star/D-PRS signal can only be read by other D-Star (Icom) radios. If you have a DSTAR repeater in your area that is setup properly to convert the D-PRS signal to APRS and send it to www.APRS.fi, than you will show up on the web.
    With A GPS unit and a TNC I think you can get your Icom to speak the language of APRS.
  12. Sep 2, 2014 at 11:42 AM
    #8392
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Yeah, it can fry your brain sometimes. I am studying for my Extra license right now, One chapter is guaranteed to put you to sleep. But once I past it, there is no more tests for me.
    Doesn't hurt that I was a radio operator in the Army.
  13. Sep 2, 2014 at 11:51 AM
    #8393
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well the 5100 has built in gps. So should be okay.
    I knew it was dprs and yea the whole digital protocol wars is stupid. Haha happens all the time for technology. Makes ya wonder who will win it..
  14. Sep 2, 2014 at 4:03 PM
    #8394
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    So I feel like dual band is definitely worth it, but there's quite the price range from $300 to $800 for the radio. The most common ones I've seen are the Yaesu and Icom, are those the good ones? There's probably a better place to ask, but we're on the subject :eek:
    Also, what antennas are you guys running? I already have a magmount Wilson on the cab, would it be bad to run another mag mount up there? Alternatively I'm thinking a corner of the hood mount. I saw MrGrimm running that.
    Also, how do you like the Uniden 520xl CB radio? I'm using the 510 but I think it's limiting me a lot. I thought for sure I had a good setup because the receiving is awesome (hearing people skipping from Georgia here in CA), but transmission only goes out for like a mile even on flat.
    Oh and I just noticed a random blue coat hanger in the parking lot of those hdr shots you took in your OP :p
  15. Sep 2, 2014 at 5:43 PM
    #8395
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think dual band is worth it. I'd get one for sure. Price range and features are of course your limiting factors.
    Icom and yaesu are the top brands for sure.
    I'm just running a mag mount for my ham. It works fine. Not sure if running dual mag antennas will be bad or good. I run dual mag ones on Igor but didn't really get to mess with them. Hood mounts work great. My dad put his cb on the passenger side and drilled a freaking hole in the roof for his ham :laugh:
    The 520xl is IMO the best lil CB you can get. Idk why but they seem very powerful for broadcasting and receiving. Having the rf gain nob is well worth it.
    Ha! Finally someone did :p I noticed it after I took them too as it was near dark when I took them. Was funny.
    :laugh:
    The 2820h is what I was going to get originally. It is a nice unit
  16. Sep 2, 2014 at 6:01 PM
    #8396
    Blackdawg
    Monte
    Wyoming/St. Louis
    Really? Sweet man. Doing what?
  17. Sep 2, 2014 at 6:07 PM
    #8397
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I would get that first too :p still hoping the new job I applied to works out. But not holding out.
    Nice man! That's kinda cool. Nori but cool
  18. Sep 2, 2014 at 9:04 PM
    #8398
    Blackdawg
    Monte
    Wyoming/St. Louis
    Those are the lights I was telling you about Timmy that Ben posted. Also check out visionx lighting canons. I'd probably run a set of the 6"s as a driving light.
    My piaas died too so yea..I am looking for some options. Your holes are big enough you could fit a led cube easy in them. Which I think LEDs make awesome flood/fog lights so I all for that
    Edit: no jk Ben was wrong give me a second
  19. Sep 2, 2014 at 9:08 PM
    #8399
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Sep 2, 2014 at 9:11 PM
    #8400
    Digiratus
    Roaming the PNW
    The RedHead
    Very nice.
