The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Sep 18, 2014 at 10:12 PM
    #8521
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Red head was just tired if not being the drama queen and wanted it's share if the spot light.
  2. Sep 18, 2014 at 10:17 PM
    #8522
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thinks just so,e 150amp one from the parts store.
    Get a yellow top. You want a deep cycle for a second battery as it will see a large change in voltage. Especially if you run a fridge off it all night all the time and lights or whatever else. Red tops aren't deep cycles but more of a starter batter. They don't like to loose their charge and recharge multiple times.
  3. Sep 18, 2014 at 10:21 PM
    #8523
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I like how you think haha
  4. Sep 18, 2014 at 10:23 PM
    #8524
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nothing wrong with the diehards. Just not a nice box for you to have to hold it pre fabbed haha
    Blue top is the same as a yellow top really
  5. Sep 18, 2014 at 10:24 PM
    #8525
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    x2 on the Yellow Top. I will admit tho that I am an Optima fanboi. I've had a lot of good fortune with them being dependable and lasting a long time. <knocksonwood>
    That is the nature of being ginger. :D
  6. Sep 18, 2014 at 10:27 PM
    #8526
    PcBuilder14
    Brent
    Nor Cal
  7. Sep 18, 2014 at 10:28 PM
    #8527
    Blackdawg
    Monte
    Wyoming/St. Louis
    My yellow tops have been great so far too
    Nice!
    And well my yellow tops have dual studs. Well. A place for studs if you want them. I just put bolts in them. So dual positive and negative terminals.
    Think all the 34/78 or whatever's are like that.
  8. Sep 18, 2014 at 10:36 PM
    #8528
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    The side posts are the only difference between the two.
  9. Sep 18, 2014 at 10:38 PM
    #8529
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bingo.
    Just the 34 just has top ones. 34/78 has top and side...or front..whatever you want to call it
  10. Sep 18, 2014 at 10:41 PM
    #8530
    Digiratus
    Roaming the PNW
    The RedHead
  11. Sep 18, 2014 at 10:41 PM
    #8531
    Redneck92
    Concord, NC
    There's a few boxes out for the diehards now. Not many but a few. The diehard will probably be my next one when I kill my 34-78 unless I can get another one for a steal. Only paid 35 bucks or so for it when I got it at work.
  12. Sep 18, 2014 at 10:50 PM
    #8532
    Blackdawg
    Monte
    Wyoming/St. Louis
    Idk I found them useful. I'm using all 4 on both batteries..haha
  13. Sep 18, 2014 at 11:00 PM
    #8533
    Blackdawg
    Monte
    Wyoming/St. Louis
    I use the front one on the starter bat for the winch and the main cable to the second battery where I use the front one to connect to the solenoid from the starter.
    Front ground for the winch rope for the body on the starter battery
    Front ground for a frame ground. Top for body on the second battery
    Just helps keep stuff cleaner sorta.
  14. Sep 18, 2014 at 11:01 PM
    #8534
    Digiratus
    Roaming the PNW
    The RedHead
    Amps, winches, fuse blocks, relay banks... You know, all the normal crap we do. :D
  15. Sep 18, 2014 at 11:03 PM
    #8535
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wiring!! :goingcrazy:
    Love it haha
  16. Sep 18, 2014 at 11:13 PM
    #8536
    Blackdawg
    Monte
    Wyoming/St. Louis
    Die hard is a bit nicer. But lot more money.
    Shit I paid 200 and 220 for my yellow tops.
    Also you have lights too ;) :D
    Anyways..
    Either will be fine I'm sure.
  17. Sep 18, 2014 at 11:27 PM
    #8537
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh mine are doing good.
    Led bar
    Noooooo
    :p haha
  18. Sep 18, 2014 at 11:32 PM
    #8538
    Blackdawg
    Monte
    Wyoming/St. Louis
    Whoa..led bad ass over here...haha
    My aux one is...two years? Going on three. And other one is new.
    No issues this far..
  19. Sep 18, 2014 at 11:37 PM
    #8539
    Digiratus
    Roaming the PNW
    The RedHead
    3 years for mine as a starting battery
  20. Sep 18, 2014 at 11:40 PM
    #8540
    Blackdawg
    Monte
    Wyoming/St. Louis
    Darn. Woulda like to see how those did.
    Yea guess we will find out :p
