The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Sep 20, 2014 at 10:18 AM
    #8561
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That is good to hear. Honestly, it was your good experience with Alcan that was the deciding factor for me to go this route. I found Bill Ford and Owen very good to deal with.
  2. Sep 20, 2014 at 10:25 AM
    #8562
    Digiratus
    Roaming the PNW
    The RedHead
    I have had 700 lb leafs before and on my truck the ride and flex were horrible. Not saying they wouldn't be a good choice for you, but I sure wasn't happy with them and got them off of there as soon as I could.
    If you are carrying that much weight all the time, springs that stiff might be OK. :notsure:
    The choice for me to go 500 lbs was a compromise no doubt. And was partially based on my experience with their 200 lbs springs.
  3. Sep 20, 2014 at 10:26 AM
    #8563
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea I always go for fully loaded since usually when I use the rig it's fully loaded or at least loaded up good
  4. Sep 20, 2014 at 10:36 AM
    #8564
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, its always gonna be a compromise. You've got great flex and certainly don't want to give that up. I think that is the core dilemma with new leaf packs.
    And, initially I am going to put the stock shackles back on.
    I am a little concerned about being too high in back, at least in the beginning. Lets see what I end up with going that route. If it has bro-lean when fully loaded (which I doubt it will), I can then use the extended shackles to get back up there.
  5. Sep 20, 2014 at 10:50 AM
    #8565
    Blackdawg
    Monte
    Wyoming/St. Louis
    id leave the extended ones on to keep the extra travel..but thats me.
    Im pretty certain you'll have rake with it unloaded but who cares. Not like you drive it a lot unloaded anyways.
  6. Sep 20, 2014 at 11:00 AM
    #8566
    Digiratus
    Roaming the PNW
    The RedHead
    Its this one I think. Looks like it and this is the place I bought it from.
    http://www.rightchannelradios.com/adjustable-universal-hood-mount-pl-259.html
    The new leafs are going to add lift. Maybe as much as a couple of inches over where its at now. I hear what you are saying tho. We'll see where everything settles out at before using the extended shackles.
    It is an easy fix if I need to swap them on there.
  7. Sep 20, 2014 at 11:02 AM
    #8567
    Blackdawg
    Monte
    Wyoming/St. Louis
    well ya they will be a bit high at first. Gonna take a fully loaded trip of flexing to break em in really.
    Im just saying might as well leave them on. Use as much shock travel as possible.
  8. Sep 20, 2014 at 11:06 AM
    #8568
    Digiratus
    Roaming the PNW
    The RedHead
    I know, I just take a little more conservative approach than you. :p
    Remember, I have access to a forklift so I will be able to see exactly where the shocks are after the swap.
  9. Sep 20, 2014 at 11:20 AM
    #8569
    Blackdawg
    Monte
    Wyoming/St. Louis
    Come on!! :p
    Also dont forget you'll be adding 200lbs off the ass of it alone..so its gonna change quiet a bit from how you will see it the first time. Id leave the shackles on. I think you'll need them haha
    Be interesting to see how the shocks look on the forklift. They looked great on Shoshone
  10. Sep 20, 2014 at 11:36 AM
    #8570
    Digiratus
    Roaming the PNW
    The RedHead
    With the current setup they are very close under full compression, less than an inch without the little rubber ring. On the long end, there may be a couple of inches to spare right now. Another reason I want to try first with the stock shackle. If I am 2" higher, I don't want to over extend the shock. I think it may be close. Really depends on the amount of flex the new leafs will have.
  11. Sep 20, 2014 at 11:42 AM
    #8571
    Blackdawg
    Monte
    Wyoming/St. Louis
    You have lots of down travel left. Up is a bit short but with the current shackles works perfect. With a shorter shackled you'll have to get new bumps for sure.
  12. Sep 20, 2014 at 12:04 PM
    #8572
    Digiratus
    Roaming the PNW
    The RedHead
    We shall see. :)
    2footer?
    And a new coax cable too?
  13. Sep 20, 2014 at 12:13 PM
    #8573
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea he does. And wow got a whole new unit too huh?
  14. Sep 20, 2014 at 12:26 PM
    #8574
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh wow. Nice. Did ya open it up to see what fried??
    I opened my amp up. Had two melted transformers haha no idea how it happened.
  15. Sep 20, 2014 at 12:30 PM
    #8575
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hahaha
    I'd do it. Be interested as to why it died.
  16. Sep 20, 2014 at 12:54 PM
    #8576
    Blackdawg
    Monte
    Wyoming/St. Louis
    Figured. When mike and I drove it we thought we heard one
  17. Sep 20, 2014 at 1:22 PM
    #8577
    Blackdawg
    Monte
    Wyoming/St. Louis
    JB weld wont last on a header haha I can get you some and mike can drop them off on his way back from Christmas.
  18. Sep 20, 2014 at 2:02 PM
    #8578
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea stock ones anyways. You work it out if ya want. Idk how much they would cost. Under 100 I'm sure probably 50
  19. Sep 20, 2014 at 2:33 PM
    #8579
    Digiratus
    Roaming the PNW
    The RedHead
    I would not assume that. It isn't what he said.
    VVVVV
  20. Sep 20, 2014 at 2:36 PM
    #8580
    Digiratus
    Roaming the PNW
    The RedHead
    My guess the reason the radio failed is that you damaged it by continuing to try to broadcast after the mount broke....while it lay ungrounded in the bed of the truck.
