The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Dec 9, 2014 at 9:02 PM
    #8921
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wrong!
    I dd Frank loooonnngggg be fore Igor ever came around and you know it. Dded it for 3.5 years.
    And I have been offroad with Igor and my first Toyota which had an auto. So I can say that thank you :luvya:
    Damn near. He wants the ipt mod for faster shift times for sure then maybe he will get the smaller pully. But he is tossing around the idea of getting the URD stage three kit...and maybe the sleeve bore kit..
    Be nuts...
    But...want a second hand Trd blower :boink: :p
  2. Dec 9, 2014 at 9:08 PM
    #8922
    BradyT88
    BradyT88 Well-Known Member
    Mine doesn't, but the 2nd gen 5 spd auto has similar gear ratios to the 1st gen 5spd manual. Pair that with my 4.88 diff gears and it slows down real quick when you let off the throttle.
    The weird thing I find with all of these arguments is it seems like everyone forgets that you can manually downshift autos. When I do my high speed stuff I typically throw the shifter in 2nd and leave it there. I can do about 50 mph in 2nd gear and it's pretty easy to keep my rpm in the powerband in 2nd. If I get slow enough to need 1st it will just downshift itself as needed and if I get going fast enough to need 3rd I just reach down and bump it up a gear and then bump it back down to 2nd when I slow back down.
    So far, the only complaint I have found with my auto, is when I am at WOT trying to climb a dune in 2nd gear and start losing speed, it's waits a bit too long to shift to 1st gear. I would prefer it to drop into 1st gear at like 5K rpm so that I still have some power, but it waits and drops in around 3K and I've usually lost too much momentum by then. I'm guessing it does this to protect the trans though.
    If I had a manual though I would probably get too antsy though and downshift too soon and over rev the motor... so it is kind of a trade off I suppose...
  3. Dec 9, 2014 at 9:12 PM
    #8923
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There you go. Apple to oranges. Pre-Tacos don't count for this discussion. :luvya:
    And DD in Wyoming DEFINITELY does not count. Seattle, SLC, STL, those count which you have not done.
    You have been off pavement with igor but I said wheeling and you know I was referring to situations where 4lo and articulation and steep inclines are involved.
    It is ok to admit you lack the true experience to compare a manual tacoma to a auto tacoma. Its Ok. :luvya:
  4. Dec 9, 2014 at 9:16 PM
    #8924
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I kid I kid. My tits are calmer than Jamaican islands
  5. Dec 9, 2014 at 9:20 PM
    #8925
    Digiratus
    Roaming the PNW
    The RedHead
    :cheers:
  6. Dec 9, 2014 at 9:22 PM
    #8926
    dakotasyota
    Dakota
    Ellensburg, WA
    :woot: where you from? Hawks fan I see :thumbsup:
  7. Dec 9, 2014 at 9:31 PM
    #8927
    Digiratus
    Roaming the PNW
    The RedHead
    I have to agree with Brady. Slowing down with the 4.88s is not the same as with stock gearing. Engine braking is way more effective. I was impressed with how much speed control I had with just the throttle when trying to run away from Frank (it was easy actually :cool:) when we were exploring the trail that leads to Lake Abundance. 2nd gear give a very wide power band.
    This VVVVVVVVVVVVVVVVVVVV
  8. Dec 9, 2014 at 9:34 PM
    #8928
    Digiratus
    Roaming the PNW
    The RedHead
    I am in the Seattle area.
    Yeah man, hard not to be these days. Go Hawks :woot:
    :D Of course I am punk
  9. Dec 9, 2014 at 9:35 PM
    #8929
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    I notice I engine break alot more in the 4runner. The 4.88s do change the game up and Brady is right in what he is saying. Sometimes you really wish it would kick down a gear and it just doesn't want to.
  10. Dec 9, 2014 at 9:42 PM
    #8930
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    :laugh: i do that literally every time i get into the truck after driving the Subaru for about a week
  11. Dec 9, 2014 at 10:05 PM
    #8931
    dakotasyota
    Dakota
    Ellensburg, WA
    Yeee I had no idea! Come to a meet sometime!
  12. Dec 9, 2014 at 10:13 PM
    #8932
    Digiratus
    Roaming the PNW
    The RedHead
    I do once in a while. But its been a couple of years since I've wheeled with any western wa or oregon guys.
    Do you get out much?
  13. Dec 9, 2014 at 10:19 PM
    #8933
    dakotasyota
    Dakota
    Ellensburg, WA
    Not with the TW guys very much. They're all westsiders and Im stuck over here in the burg :/ go wheelin all the time with my best friend (he's got a jeep) :smack:
  14. Dec 9, 2014 at 10:30 PM
    #8934
    Digiratus
    Roaming the PNW
    The RedHead
    I almost joined you guys when you did the Gallagher Lake a couple of months ago but something came up so I had to drop out.
    Once the snow melts, I want to explore From Ellensburg to Cashmere. I know there is a lot of stuff back up that way but I've never been. Ben and I explored north of Cashmere and up the Entiat drainage and over to lake chelan. It was right before the fires last summer.
  15. Dec 9, 2014 at 10:34 PM
    #8935
    Digiratus
    Roaming the PNW
    The RedHead
    That was like mid june wasn't it? The 10th or so.
  16. Dec 9, 2014 at 10:47 PM
    #8936
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    No thanks, I like my auto. :)
  17. Dec 9, 2014 at 11:43 PM
    #8937
    Blackdawg
    Monte
    Wyoming/St. Louis
    No!! I have offroaded in an auto! And whatever. Dd is a dd!! I drove it everywhere all the time. Same thing.
    And I have been with Igor in 4lo several times. Hell..I got the low ass sob stuck hahaha
    And I have driven yours offroad :luvya: my manual and gears are far superior if you want to play that game :D
    Aahhhhhh it's good to be back in this thread bickering..there was Cobb webs forming there for a while haha
    Again..slowing with my gears is better :luvya: in fact I believe I recall you complaining I was too slow going down hill :p
    Yea...Frank was easy this year to keep up with....no shocks...hahahahahahaha gonna be impossible this year though :cool:
    Screw your auto old man :D
    Haha! Dude..I bet that happens big time. Especially ripping around in that sweet ride all week haha
    I miss snow..we barely have had any here...
  18. Dec 10, 2014 at 12:02 AM
    #8938
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Where do you wheel in the burg? Always want to know a good place to have some fun in the dirt. I go through that area all the time on my way to and from Spokompton. Also I totally understand the best friend having a Jeep deal, sometimes we just have to go wheeling with him as my spotter when his Jeep is on the fritz. :rolleyes:
  19. Dec 10, 2014 at 10:33 AM
    #8939
    dakotasyota
    Dakota
    Ellensburg, WA
    Shoot!! Yeah there is some awesome stuff inbetween there. Manastash and funny rocks are awesome as well!
    Ok who/what is Igor??
    Mostly up by Liberty and manastash. There's a few trails up reecer creek as well. Hahaha yeah the jeep makes TW meets hard. People don't want him there. Wish we could do the Taco Takeover meet together :/
  20. Dec 10, 2014 at 10:34 AM
    #8940
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    His DD tacoma^^
