The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jan 7, 2015 at 10:06 AM
    #9341
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Thanks man! It's coming together haha
    Someday you will I am sure :cool:
  2. Jan 7, 2015 at 2:01 PM
    #9342
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  3. Jan 7, 2015 at 2:53 PM
    #9343
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmm...not bad..not bad at all really.
  4. Jan 7, 2015 at 3:08 PM
    #9344
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Are most lower links 48" like that? I feel like that would rob you of clearance...
  5. Jan 7, 2015 at 3:28 PM
    #9345
    Blackdawg
    Monte
    Wyoming/St. Louis
    Those are trailing arms. They are lower coilover mounts. Yea for crawling not totally ideal, but awesome for go fast.
  6. Jan 7, 2015 at 3:33 PM
    #9346
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    They have a 55" and 62" version as well.
  7. Jan 7, 2015 at 3:51 PM
    #9347
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea figured 48" will be too short.
  8. Jan 7, 2015 at 4:04 PM
    #9348
    BradyT88
    BradyT88 Well-Known Member
    What exactly would make a trailing arm too short? And what is the advantage to a longer trailing arm?
    Just looking at the diagrams for all 3, using the front shock mount, all 3 lengths have similar shock to axle travel ratios. For rock crawling I would think the shorter arms will provide better clearance and be ideal since the differences in travel as so small.
    I just measured my driveshaft from carrier bearing u-joint to pinion flange and it is only 44" long so I could see 48's being a bit short in my case. I might end up with too much pinion angle change (whatever the term is for that) and bind up u-joints too easy or something.
  9. Jan 7, 2015 at 4:16 PM
    #9349
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'd probably have to get a solid drive shaft with links anyways.
    55" seems like the best size to me. But I'd have to check the math for it all that.
    I'm not building a rock crawler either. Never was. Not now either. Besides. They just become skids anyways.
  10. Jan 9, 2015 at 1:57 PM
    #9350
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Monte what rotors and pads do you recommend?
  11. Jan 9, 2015 at 2:05 PM
    #9351
    Blackdawg
    Monte
    Wyoming/St. Louis
    I still have stock rotors and can't remember what pads.
    EBC seems to make good stuff though.
    I mostly want to do the tundra brake swap. Need new rims for it though.
  12. Jan 9, 2015 at 2:18 PM
    #9352
    LSC15
    Logan
    2008 TRD D-Cab
    Yea I got ebc now but didn't put new rotors on when I did it a year ago. Need to put all new stuff in
  13. Jan 9, 2015 at 4:21 PM
    #9353
    Blackdawg
    Monte
    Wyoming/St. Louis
    We'll get their rotors then.
    Just took Frank out for probably the last time till may. Took some nice poser shits. I can't wait to edit them!
  14. Jan 9, 2015 at 4:37 PM
    #9354
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Gotta love some poser shits :cool:
  15. Jan 9, 2015 at 4:53 PM
    #9355
    Blackdawg
    Monte
    Wyoming/St. Louis
  16. Jan 9, 2015 at 7:12 PM
    #9356
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Ya Dude. Pose for them shits.
  17. Jan 9, 2015 at 10:38 PM
    #9357
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
  18. Jan 10, 2015 at 7:21 PM
    #9358
    LSC15
    Logan
    2008 TRD D-Cab
    Where are these pictures at?
  19. Jan 10, 2015 at 7:24 PM
    #9359
    Blackdawg
    Monte
    Wyoming/St. Louis
    Coming. I get back to St. Louis tomorrow night. Have about 400 photos to go through.
  20. Jan 10, 2015 at 7:40 PM
    #9360
    LSC15
    Logan
    2008 TRD D-Cab
    Ok I'll be waiting
