The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jan 26, 2015 at 2:02 PM
    #9541
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Eh. I hacked out the hangers by choice. I wanted to use the 63s and throw on some creepers. Adam got awesome droop out of his pack too. How you threw together a bunch of leafs to make it work that well. I don't know haha. Luck? But the weight is a big plus, certainly helps.
  2. Jan 26, 2015 at 4:49 PM
    #9542
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Not even close lol
  3. Jan 26, 2015 at 5:00 PM
    #9543
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Holy shit. That worked!
  4. Jan 26, 2015 at 5:09 PM
    #9544
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Agreed, I see it now
  5. Jan 26, 2015 at 5:30 PM
    #9545
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea luck probably. And longer shackles..haha
    :rofl:
  6. Jan 26, 2015 at 5:40 PM
    #9546
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    What don't you like about the shackle flip? I think its a great idea... It adds gobs of travel.
  7. Jan 26, 2015 at 5:42 PM
    #9547
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have seen lots of guys do it with success and other not so much. As in the kits line up good or don't.
  8. Jan 26, 2015 at 5:44 PM
    #9548
    dakotasyota
    Dakota
    Ellensburg, WA
    Hmm well we'll see soon :D
  9. Jan 26, 2015 at 6:33 PM
    #9549
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You could not be more wrong.
  10. Jan 26, 2015 at 11:28 PM
    #9550
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea cause really..you get to run a longer shock..but you have to add a bigger bump or risk bottoming out the shock..so really it just ends up moving where the wheel travel is at..which is just lower so it appears you get tons of droop but you loose up travel..make sense?
    granted. thats an issue with 1st gens too. Really any truck and the stock shock mounts.
  11. Jan 27, 2015 at 8:10 AM
    #9551
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Take shock mounting completely out of the equation. Doing a shackle flip will preload the spring. Depending on rear mounting location, you'll either have just about the same ride height or slightly higher. Now paired with a preloaded spring, yeah, you'll get more droop travel, but the pack is almost flat just at ride height. Any amount of flexy and you're negative arch. Which means clapped out springs a lot sooner or long ass bump stops. Not only that...since every leaf pack I've seen for Tacomas are progressive, since the spring is more preloaded...it's gonna ride like shit!
    Oh, and forget go fast wheeling. No bump travel means no fun.
    RoaminRoman likes this.
  12. Jan 27, 2015 at 8:44 AM
    #9552
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really..just takes a hell of a lot of work to get dialed in perfect...or close to it. Not easy.
    Or that. Nice explanation as always Jason.
  13. Jan 27, 2015 at 10:52 AM
    #9553
    dakotasyota
    Dakota
    Ellensburg, WA
    Damn you guys... okay my plan was a shackle flip and relocating my shock mounts so I can run a 12" shock. I hope that will let me leave my bumpstops stock or not have to move them down to much. I don't want any preload or any loss of uptravel...
  14. Jan 27, 2015 at 10:59 AM
    #9554
    Blackdawg
    Monte
    Wyoming/St. Louis
    Doing the shackle flip means you'll have to extend the bumps from keeping the leafs from going mega negative. A little is okay. But a lot isn't.
    The pelfrey relocation kit is sick and runs a 12" shock on stock shackles. Plus hydro bumps. Marc has it on his rig and it is sweeeeettt
  15. Jan 27, 2015 at 11:08 AM
    #9555
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha
    even then you should have a touch taller bump with your short bodies. Yours are damn close to perfect though..what i wish i had gotten them first go around...
  16. Jan 27, 2015 at 11:36 AM
    #9556
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Dude...draw a line. It's that simple.
    Draw an imaginary line from the front hanger to the shackle where the leaf connects on your current inverted shackle.
    Now pretend you have a shackle flip (which is now BELOW the frame). Draw another imaginary line where the spring would connect to the shackle.
    Line 1 is higher than line 2. Meaning shackle flip = lost uptravel and preloaded spring. You'll have to drop your bump stops like over 2".
  17. Jan 27, 2015 at 11:37 AM
    #9557
    Blackdawg
    Monte
    Wyoming/St. Louis
    Really? You wish you had done SUA huh??
  18. Jan 27, 2015 at 11:47 AM
    #9558
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    6" shackles below the frame :eek:
    Leverage is overrated. :p
  19. Jan 27, 2015 at 11:48 AM
    #9559
    Blackdawg
    Monte
    Wyoming/St. Louis
    I can not see you linking it. Haha not for your needs anyways..unless those are changing..
    Yea hopefully works out for you.
  20. Jan 27, 2015 at 11:49 AM
    #9560
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not that long really..mine are 5.5 right now. 6" would only be a 1.25" lift shackle.
