The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Apr 17, 2015 at 9:09 PM
    #9841
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I suspected you might way that...
    It is a 400 watt inverter. I would use it to recharge camera batteries, and my led flashlight and maybe my laptop.
    I plan to use 8 awg from the battery to the fuse block.
    It seems unlikely I would ever maxx out the inverter load. I don't really weant to run two power cables to the back of the bed. Will only have 2 circuits for lights and this one.
  2. Apr 17, 2015 at 9:11 PM
    #9842
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea you'll probably be fine using it for that. Just no power tools :p
  3. Apr 17, 2015 at 9:20 PM
    #9843
    Digiratus
    Roaming the PNW
    The RedHead
    You don't think I will melt the fuse block if i were to go to say 35 amps sustained? It would not blow the fuse because that is a 40 amp fuse?
  4. Apr 17, 2015 at 9:35 PM
    #9844
    Blackdawg
    Monte
    Wyoming/St. Louis
    Charging the camera batteries and laptop won't go over 30 amps anyways. You could do that all with a 100-200w inverter.
  5. Apr 17, 2015 at 9:44 PM
    #9845
    Digiratus
    Roaming the PNW
    The RedHead
    Kool! Thanks for feedback. I feel a whole lot better about doing it this way.
  6. Apr 17, 2015 at 9:45 PM
    #9846
    Blackdawg
    Monte
    Wyoming/St. Louis
    Have the whole setup back there haha
  7. Apr 17, 2015 at 9:58 PM
    #9847
    Digiratus
    Roaming the PNW
    The RedHead
  8. Apr 17, 2015 at 10:00 PM
    #9848
    Blackdawg
    Monte
    Wyoming/St. Louis
    Did I give you mine? Maybe my dad stole it. I had one of those. Switched to the bussman and power block though.
  9. Apr 17, 2015 at 10:03 PM
    #9849
    Digiratus
    Roaming the PNW
    The RedHead
    Steve must have stole it. :cool:
  10. Apr 17, 2015 at 10:05 PM
    #9850
    Blackdawg
    Monte
    Wyoming/St. Louis
    Could have. But he has a Bussman too...so. Idk haha I don't remember. Not worth waiting for me to get home to see :p
  11. Apr 17, 2015 at 10:35 PM
    #9851
    Digiratus
    Roaming the PNW
    The RedHead
    Soon buddy! Soon!
  12. Apr 17, 2015 at 10:40 PM
    #9852
    Blackdawg
    Monte
    Wyoming/St. Louis
    Very soon!
    Then start cutting shit off Frank! Haha
  13. Apr 18, 2015 at 8:17 AM
    #9853
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Franks going on a diet!? lol
  14. Apr 18, 2015 at 11:20 AM
    #9854
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not exactly hahabed rack is getting cut up and redone. I'm not sure the roof rack will be staying. But prinsue designs is supposed to co,e out with some for 1st gens this summer so I'll see how that looks. I just can't think of a good way to incorporate the roof rack into the new bed rack design. Not without it being a stupid design anyways.
    But gotta bix the frame and get the new rear shocks done. And gusset the front end. Pretty much the first projects to get out of the way to make Frank really wheel able for the summer. Then maybe do front hydros and rear hydros and lockers hopefully. If anything a rear locker is going in for sure this summer.
  15. Apr 18, 2015 at 7:35 PM
    #9855
    SconnieHailer
    Marc
    I figured he wasn't going to lose much just a re-configuration of what you've got. I've still got those bed bars if you think you can use them, on me bro. I'll take a measurement of the width if you think it's possible for the plans you've got in ur head.
    Don't stress too much about gettin the rear done before the desert/dune trip. There's always 3 things that need fixing for every one thing you change to get it dialed... The trip is lots of just rough dirt road so no need for anything perfect. Plus the woops at the Killpeker entrance are way too big for my rig north of 15mph haha. I'm sure with your front end dialed in and a decent rear end you could pull on me but the whoops are deeeep there. Time will tell, but dont stress too much before the early season trip!
  16. Apr 18, 2015 at 11:08 PM
    #9856
    Blackdawg
    Monte
    Wyoming/St. Louis
    If anythin it'll be even heavier haha
    I want new rear shocks. Need them really. Although it did surprisingly well on Christmas. But I bet if I had a real alignment Id have wanted to go faster and harder...so..yea. I'll want the shocks done for sure. But I won't tear the whole truck apart until I know I can get it done.
    I doubt I'll pass you up. Your shocks will be dialed in vs mine that aren't. And I'll have a very similar setup out back to yours.
    Maybe when I link it :p but then the front would be limiting it.
    Good to know there's some fun terrain though! Be a fun trip!
    I am struggling on deciding what length of shock to get though..either 10s again or 12s. Probably get 12s. Idk if I can get a 14" in there and it be worth it.
  17. Apr 19, 2015 at 7:03 AM
    #9857
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    I stole the fuse block years ago.
    On another note, Mike if all your doing is charging batteries then going from 12v to 120v back to whatever your chargers take is pretty inefficient. You would be better off running cigarette lighter sockets and getting car chargers for battery packs. The chargers draw very little power so you could run smaller wire and less chance of burning your truck down.
  18. Apr 19, 2015 at 7:56 AM
    #9858
    SconnieHailer
    Marc
    Monte there is lots of fun/cool terrain on the route:
    Here's a shot above the dunes and honeycomb buttes:
    These are the Honeycomb buttes:
    It's going to be a seriously cool trip man. Way different than anything we normally do. We'll be total overlanders...better wear your khaki pants!
    Steve, will you be around that first weekend in June? It's gonna be a longer day but tame enough to be a family affair :D
  19. Apr 19, 2015 at 8:48 AM
    #9859
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thats not a bad idea actually mike. I got a 12v weather proof plug for like 15 bucks. You could run 2 or more off the block easy.
    SICK MARC! stoked!! get to see a new part of Wy :cool:
    you wear the khakis. Ill wear the flat bill hat and be the "bro" :laugh:
  20. Apr 19, 2015 at 9:21 AM
    #9860
    Blackdawg
    Monte
    Wyoming/St. Louis
    What about which leafs?
