The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Apr 19, 2015 at 1:38 PM
    #9861
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Yeah I'll be in the first weekend of June. So ya looks like fun! What about the last weekend in May? Anything going on then?
  2. Apr 19, 2015 at 1:43 PM
    #9862
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I know we had the dever thing..but if we come back i was thinking that would be the weekend to do the mod weekend? Or saturday rather.
  3. Apr 19, 2015 at 8:25 PM
    #9863
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Honestly, I am pretty set on running a fuse block back there.
    If all I was going for was to charge batteries, I would agree. But I want the flexibility to do a lot more. For example, I want to avoid clamping the inverter to the battery as I have been doing and having to use the laptop on the hood. The tailgate and swingout table offer a much better workspace.
    ATM there will be 3 circuits, 2 for aux lights, 1 for the inverter and I want the ability to power the fridge from back there if I decide to move it back there at some point.
  4. Apr 19, 2015 at 8:44 PM
    #9864
    Blackdawg
    Monte
    Wyoming/St. Louis
    The 12v plug will be better to power the fridge too.
    You can still run everything off a 12v plug. You just need the converter for the laptop. The car charger for it.
    Be a simpler and cleaner install too.
  5. Apr 19, 2015 at 8:50 PM
    #9865
    Digiratus
    Roaming the PNW
    The RedHead
    You have a link to said power port?
    I already have the inverter.
  6. Apr 19, 2015 at 9:00 PM
    #9866
    Blackdawg
    Monte
    Wyoming/St. Louis
    Something like this
    http://www.amazon.com/Waterproof-Accessory-Lighter-Recepticle-Motorcycle/dp/B00791W8BW
    Mine came with wire on it from O'Reillys. 14ga I believe. Was under 20 bucks.
    You can still use the inverter. Id put it in the cab. Then you can charge batteries while you drive. What I do.
    This is closer to what I have http://www.carid.com/dorman/12-volt...T8Hq-gFHUmagvxdOOk4VmAQX4ahk6edousaAk_U8P8HAQ
  7. Apr 19, 2015 at 9:16 PM
    #9867
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I've seen these types. I like the waterproof idea, but this one is only rated for 15 amps tho. Needs to be at least twice that.
    Also, I really need 4 circuits.
    Why is this better?
  8. Apr 19, 2015 at 9:56 PM
    #9868
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your fridge draws 30amps DC? I kind of doubt that..that would be 360w continuous. I know the cooler I've used is way more power hungry then yours and it runs fine.
    It's just simpler. less wires run and your not having to mount the inverter. Going off your previous bed wiring install....that's probably the way to go haha
    The fridge would be the biggest thing you'd probably ever put on it and my dad and I both run ours off a 12v plug as does just about everyone else that keeps them in the bed.
    You can then run your Latin car charger and battery chargers easily off the bed too.
  9. Apr 19, 2015 at 10:14 PM
    #9869
    Digiratus
    Roaming the PNW
    The RedHead
    Naw man, its the inverter that need the 30 amp circuit. Fridge is on a 15 or 20 amp circuit now. Can't remember.
    I do not see how it is less wires to run. I just have to power the fuse block from the Bat. One set.
    Inverter would not be permanently mounted back there. I would use a quick discnnect for the inverter. Besides, we don't have cubbys like 2nd gens.
    Can't use the previous wire I used for the light. Its in n the wrong place for one and way too light of a gauge. I think its 18 awg. Plenty for one light, but that is about it. Besides, that was a temp solution only.
    There is another problem with the power port you linked. It requires almost 2" of depth. There is a little gap between the bed and the outer sheetmetal but 2"s is not available where I want it to be.
  10. Apr 19, 2015 at 11:08 PM
    #9870
    Blackdawg
    Monte
    Wyoming/St. Louis
    They fit in the corners of the bed. Just drill a hole and your good.
    I think it would be a better install all around. Be either will work
  11. Apr 19, 2015 at 11:29 PM
    #9871
    Digiratus
    Roaming the PNW
    The RedHead
    Access to the corner near the tailgate is now severely restricted. I looked pretty closely at that area yesterday. There is the big 'ole honking bumper with bottom skids in the way. Would be a real pain to mess around in that corner and I am not removing the bumper for this. :rolleyes:
    Besides, still does not give me 4 circuits.
  12. Apr 19, 2015 at 11:35 PM
    #9872
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha yea don't take that off..haha
    Your inverter has 4 outles? I figured it was two like most.
    If your planning on running all 4 then you should probably run a dedicated wire to the inverter. Not off the fuse block. You might go through some 30 amp fuses. And I would exceed that in the block.
  13. Apr 19, 2015 at 11:40 PM
    #9873
    Digiratus
    Roaming the PNW
    The RedHead
    We already covered this yesterday. Are you flip flopping your position?
    And the 4 circuits, I identified earlier too. Fridge, Inverter, lights, lights.
  14. Apr 19, 2015 at 11:45 PM
    #9874
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh right.
    I think you misunderstood the 12v plug. It wasn't supposed to replace all of that. Just run off the fuse block. So you'd have a plug for the fridge. On for the laptop/chargers and then keep your lights.
    Make sense?
    Im not changing my position. Just giving my thoughts on the inverter as it sounds like your set to do that regardless
  15. Apr 27, 2015 at 12:24 AM
    #9875
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  16. Apr 27, 2015 at 1:09 AM
    #9876
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Ever thought of using one of the Safety Hubs from blue sea instead of their regular fuse block?
    https://www.bluesea.com/products/7725/SafetyHub_100_Fuse_Block
    It has three circuits from 30-200 amps max, and four circuits for 1-20 amps max. If you're worried about the inverter melting the fuse block, this would be a great choice. Although I doubt you'd be anywhere near 30amps if you're just running a laptop or charging some batteries. You'd obviously want to run bigger wire than 8 awg if you're going this route though. At least I would so I have enough current there if/when I added a high draw accessory.
    I almost went with one of these under the hood so I could run my amp through it as well, but it doesn't have enough regular circuits for all my other accessories. And the bigger version is just physically too big for where I wanted to mount it.
  17. Apr 27, 2015 at 6:10 AM
    #9877
    Blackdawg
    Monte
    Wyoming/St. Louis
    :anonymous:
    Yea....haha
    I'm a loud mouth is what that says haha
    Very cool! Didn't know they made those. Id consider them. Looks very handy.
  18. Apr 27, 2015 at 1:17 PM
    #9878
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    The fact that your higher than Lisa is impressive....
  19. Apr 27, 2015 at 1:31 PM
    #9879
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh. Passed her long time ago. Ha
  20. Apr 27, 2015 at 1:49 PM
    #9880
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good god...wtf. All of my hyper links in my own thread are all screwed up. What's going on with that??? @tcBob and can we not hyper link to individual posts anymore??
    Edit: figured out how to get the direct post links. But why aren't my old links going to the posts? They just go to the page or are off a page or two..
