The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jun 3, 2015 at 6:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    With Ben not Joe. His wasn't bearing knock
  2. Jun 4, 2015 at 4:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh i did it a while ago. Seemed to help. After i did new oil and plugs as it was just past 100k for me.
  3. Jun 4, 2015 at 4:31 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    i did the whole do it through the throttle body, world of a difference in build up was gone, but I refused to do the whole dump it in your oil thing
  4. Jun 4, 2015 at 4:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I did both and in gas too.
  5. Jun 10, 2015 at 10:10 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Any Progress on the new bed rack??
  6. Jun 11, 2015 at 3:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. Have the lower legs done. Which took almost a week and a half to do. Tolerances are pretty damn tight. Got the parts in the mail today so I can finish it mostly and get it set in the truck for bolt holes. Hoping my other parts arrive tomorrow so I can wrap it up this weekend and start on rear shock/axle project.
    Ordered new front coils too. Eibach 16" 700lb. The 700lb rate feels great I just can't fit the 18" coil well on my shocks. If these don't work I'm going to try 18" 600lbs since 18" coils get compressed about 2" on my current bottom plates.
  7. Jun 11, 2015 at 6:01 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Nice. I wanna see that thing :popcorn:
    What thickness tube are you using for it?
  8. Jun 15, 2015 at 10:03 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    I have a set of chrome corner lights with clear lenses if u want them, might look good on frank. I have no use for them.
  9. Jun 15, 2015 at 10:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    A mix of tubing. Mostly 1/8" though.
    Unless they are for 95-97 won't fit. Different fender mounts.
  10. Jun 15, 2015 at 10:26 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    yup, thats why i have no use for them. got them from tacomaboss. he forgot to give them to the guy he sold his taco to.
  11. Jun 16, 2015 at 4:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh what he sold his?! Wtf...
    Well that's interesting..mine are even cracked..pm me what you want for em
  12. Jun 18, 2015 at 8:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Today I swapped out my 18" 700lb coils for 16" 700lb coils. Basically only 3/4" preload on the new coils. Brought the front end down but rides great and isn't too low. Once the bed rack and tent are back on should be close to stance before LT.
    Rides a bit rough when going slow. But the harder and faster I go the smoother it is. Perfect to me!
    Also in process of putting my skid back on. That's should make it a tad smoother.
    m3bassman likes this.
  13. Jun 18, 2015 at 8:25 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  14. Jun 18, 2015 at 8:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea man! I'm pretty stoked where it's sitting right now. I was also worried about the 18" coils block height.
    Alignment wise my camber is off now. But it drives a bit better already and turns better. I'm sure you where right about it being so high up it was screwing with things. Gonna play with that again later. Probably call you while I'm doing it
  15. Jun 18, 2015 at 8:29 PM
    SconnieHailer
    Marc
    :thumbsup:
    Drove 2500 miles over the last week or so on my home alignment and my tires look great :D
  16. Jun 18, 2015 at 8:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :cool:
    Baller!
    Oh and in got some clevis mounts for my straps. Stoked to get them on. Waiting for the new plasma to come..although if it doesn't ill just cut out plates. Won't be as odd shaped as yours was anyways.
  17. Jun 18, 2015 at 8:46 PM
    SconnieHailer
    Marc
    Sweet, clevis' rule. I've adjusted mine a bit recently.
    So you got the plasma warrantied? That was super weird how it just stopped working.
  18. Jun 18, 2015 at 8:48 PM
    SconnieHailer
    Marc
    Oh also my buddy back home told me he had a 115v welder with my name on it after I left... Damnit! Not like a 115 is a ton of good anyways
  19. Jun 18, 2015 at 8:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea Eastwood was super cool about it. Tim called em and they said we must've gotten one of the earlier ones that it was common on. Sent us a shipping label and we boxed it up and they paid for shipping. Just waiting on the new one.
    A lot of stretch eh?? I might need to get an inch shorter strap
  20. Jun 18, 2015 at 9:51 PM
    SconnieHailer
    Marc
    Nah not much stretch just evening the sides out. Did you order different straps yet?
