The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jun 20, 2015 at 3:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'm running the BC15 or BC 23A can't remember. Sounds much much better the built in one
  2. Jun 20, 2015 at 5:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you recall how the camp light on the bumper is powered? I'm guessing it comes from the same line the powers the backup light relay, but wasn't sure. Is that last bit to the camp light fused?
  3. Jun 20, 2015 at 5:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Actually..I don't remember :oops:
    Should be easy to tell though.
    Something wrong with it?
  4. Jun 20, 2015 at 6:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, won't turn on. Worked fine last time I used it. :(
    I've looked I don't see a fuse in that last bit. Of course, the main power from the front is fused but the trouble lies elsewhere. It looks to me like you got power for that light from the main source I ran back there from the fuse block.
    The tail lights, the backup lights and the license plate lights are working.
  5. Jun 20, 2015 at 6:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Must be from the fuse block then..or the switch died.
    Or the main wire you ran back there. I actually think you ran that wire cause I don't remember doing that.
  6. Jun 20, 2015 at 6:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I did run that wire. And I think you misssunderstood what I said. Power is fine to back there. You go power from that line I ran. You powered the backup light relay and also the license plate lights from that power.
    Naw, if there is no hidden fuse just for that camp light, then its either the switch (my bet is here) or it's the light itself (seems unlikely).
  7. Jun 20, 2015 at 6:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh right.
    Yea Id bet the switch is bad. Volt meter will tell you this easily.
  8. Jun 20, 2015 at 6:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh and it's not fused because it's off the same fuse as all the others. Not really needed.
  9. Jun 20, 2015 at 8:02 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    The pro520xl. Ok ill look at that, thanks!
    Yea my built in isnt that nice, plus its in the console so if its shut i cant hear it
  10. Jun 20, 2015 at 8:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Geez, Spend $2K on a bumper and defeated by a $2 switch. :eek:
    That isn't the point. Would have been so simple if it was a blown fuse. :p
    That's a good radio. That is what all of us run.
  11. Jun 20, 2015 at 8:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha 2k?? Since when did it cost that?!
    Stupid switch..try and find a weather sealed one.
    Yea that's the best lil cb radio
  12. Jun 20, 2015 at 8:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yup. More actually. When you add in shipping/transportation costs. Quite a bit more.
    Its alright. Was worth it for sure.
  13. Jun 20, 2015 at 8:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Shipping and transportation...true..
    Sheesh..hope so haha
  14. Jun 20, 2015 at 8:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I knew going in about how much it would cost me to do this. So that was not a big surprise. Then when it was finished and I saw the look on your face when it was on the truck, I knew it was the right move. :D
    Blackdawg[OP] likes this.
  15. Jun 20, 2015 at 9:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    Fair enough :cool:
  16. Jun 20, 2015 at 11:14 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Ok, now Let's see this bumper haha
  17. Jun 20, 2015 at 11:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mikes bumper?? I posted a write up on it. It's pretty awesome.
  18. Jun 20, 2015 at 11:33 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    Wait that bumper?? It is awesome but holy hell how did it end being upwards of 2 grand?? :eek:
  19. Jun 20, 2015 at 11:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There are a bunch in my gallery.
    [​IMG]IMG_9279 by mike digirat, on Flickr
  20. Jun 20, 2015 at 11:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well, cost about 1400 and the rest was driving from Washington to Wyoming and hotel I'm sure. Lot of gas man haha
