The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jul 9, 2015 at 6:44 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  2. Jul 9, 2015 at 6:55 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  3. Jul 9, 2015 at 11:26 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
  4. Jul 9, 2015 at 11:48 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Its not boost level that determines injector size, its power goal.. :rollseyes:
    Decide how much power you want and then find injectors that will meet that goal.
  5. Jul 9, 2015 at 3:51 PM
    SWYPER
    SWYPER Well-Known Member
    Dylan
    South Carolina
    1998 Tacoma 2.7L 4x4
    I'm trying to make my own switch panel for under the radio, how did you attach yours so it's not floating around?
  6. Jul 9, 2015 at 4:08 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Order one from paranoid fab, they're great
    YotaOverAll and SWYPER[QUOTED] like this.
  7. Jul 9, 2015 at 8:23 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Reminds me that I need to order one!
  8. Jul 9, 2015 at 8:33 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    PM'd
  9. Jul 9, 2015 at 9:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I hate you..
    haha
    i am not turboing without the port fueler. After all the research ive done, the 5vz runs like dog shit when you up the stock injectors and try and tune it. Unless you get a total standalone, which i am not going to do. Fuck that.
    The turbo i am going to get is 880 alone. But way better then a CX one and should fit the motor better IMO.
    I guess ill just wait it out.
    well shit. No one showing love for the 5vzfe anymore. :pout:
    PSI has NOTHING to do with power. So you can never say, im just wanting 6-7 psi and call it good. That can mean a very wide power range, what matter for FAI is CFM and how much air is moving.
    a 44mm turbo at 7psi moves a lot less air then a 67mm turbo at 7psi.
    Injector size has to do with the fuel needed to support the power you want.
    I always used this for injectors from the supra days: http://www.supraforums.com/forum/showthread.php?564330-Injector-sizing-guide.
    its literally sandwhiched between the outper plastic panel and the plastic pocket that was in there. That is it. And its cut to size so it doesn't move at all.
    This is a great option as well. I didn't do this purely because i needed more switches then 6..
    SWYPER[QUOTED] likes this.
  10. Jul 10, 2015 at 7:11 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Bummer. You call Gadget yet about that port fueler? The AEM FIC piggy back can tune injector pulse width so tuning bigger injectors should be just fine. Go on Customtacos and ask around, I know there are people running bigger primaries on there.
  11. Jul 10, 2015 at 9:07 AM
    SWYPER
    Dylan
    South Carolina
    Okay that's why my thing... I really like switches and lights, so I want room to expand:D that being said I'm gonna try and make something like you did, how thick is yours?
  12. Jul 10, 2015 at 10:01 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Get the small stuff from Amazon and ebay. If you would like I could give a full breakdown of mine. In fact I bought things I didn't need which pissed me off but oh well. Ultimately you have to make the buying decisions for what you feel is best. Your super knowledgeable.
    Keep in mind cx does military discount, don't know if that could apply to you somehow.
    I'm needing a new clutch, way too much power is causing it to slip. Any suggestions monte?
    Yeah, I want to itemize what all I bought for my own record. Plus to help others.....I'll try and post it this weekend.
  13. Jul 10, 2015 at 10:11 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Pick your poison:
    http://www.lceperformance.com/Dual-Comp-Clutch-Kit-5VZ-95-04-10-p/1053033.htm - 385HP Max
    http://www.lceperformance.com/Metallic-Clutch-Kit-5VZ-95-04-10-p/1053036.htm - 475HP Max
    http://urdusa.com/store/Trans,-Clut...on-Clutch,-Stage-II,-5VZ-FE/product_info.html - Stage II (80% increase in torque)
    http://urdusa.com/store/Trans,-Clut...utch-Kit-for-5vz-FE-5-Speed/product_info.html - Stage III (180% increase in torque)
    http://urdusa.com/store/Trans,-Clut...utch-Kit-for-5vz-FE-5-Speed/product_info.html - Stage III+ (225% increase in torque)
    http://urdusa.com/store/Trans,-Clut...utch-Kit-for-5vz-FE-5-Speed/product_info.html - Stage IV 450 RW Torque
  14. Jul 10, 2015 at 12:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'll do more research for sure. Haven't called him yet but will soon on it.
    Hmmm iI think its about 1/16th
    Yea im looking at better parts to use in most areas which adds up fast.
    Be cool to see a list for sure.
    Chris gave you all the perfomance clutches. i have the trail gear ceramic one now and really like it. Not sure how it would cope with high power
  15. Jul 11, 2015 at 8:07 PM
    gray223
    SE Missouri
    2014 Tundra Limited
  16. Jul 12, 2015 at 2:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    A Driftmotion 67mm Billet Turbo. USA built and all garret internals.
  17. Jul 12, 2015 at 7:21 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Monte, will I need to use axle relocation plates for a 33.5" tire (11.5" wide) on the back axle?
    I think I'll be going with 1.25" spacers on the front, possibly on the rear also, and some cutting on the front.
    Stock wheels.
  18. Jul 12, 2015 at 7:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes.
    The 01-04s are pretty notorious for rubbing the back half of the rear fenders...or the front..i can't remember exactly. Double cabs i believe are even worse.
    That said. I would wait until you have the tires on and see what happens. Not everyone needs them.
    If you do spacers id recommend doing them on all 4 tires. Plus it will look better, get extended thread lug nuts too to mount the spacers.
    If they are indeed true 33.5s you'll have to use the BFH a lot but not too bad. shouldn't be an issue.
  19. Jul 12, 2015 at 7:51 PM
    95 taco
    95 taco Battle Born
    Thanks for the info.
    I believe they will rub the front side of the fenders.
    I was gonna order one (A spare) when I'm about 5 K from replacing the tires to mount on the spare rim and start the clearancing.
    Yeah, I'd prefer spacers on all 4.
    I've got a BFH, torch, and welder, most of it shouldn't be an issue, I just want it to look decent.
  20. Jul 12, 2015 at 8:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you definitely won't need the torch or welder haha Just cut the pinch weld off completely and then start bashing it in with the BFH.
    Thats a good plan with the spare.
