The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Oct 9, 2015 at 12:39 AM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    May be a little easier to do the 2jz(and trans) swap and build it. Rather than turbo charge a 130k+ miles 5vz and risk damaging it. Would maybe cost more to put the same power as the 2jz. Idk. I dont know the facts. Just spit balling here lol
  2. Oct 9, 2015 at 12:45 AM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    It was my understanding that a SC is harder on an engine than a turbo...
  3. Oct 9, 2015 at 12:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It would cost a lot more to make the same power.
    You don't have to swap the trans and i wouldn't, the r154 has taller gears. The r150 bolts right to the 2jz anyways. Plus 2jz parts are so freaking pricey..you'd end up with 10k in it easily when your done. Have great to end power but not the low end grunt.
    Turboing can't be any worse than SC...well..sorta. More power from a turbo. But knowing how guys abuse the 5vz with the SC and i have seen plenty that do it on 180k+ motors that im fine with doing it. Id probably never go over 10-12psi from a 62mm turbo. or 8-10 from a 67mm.
    the cool factor would be insane with a 2jz. And yes, probably a bit more reliable as its made for boost and proven for 600hp stock internals no problem. It would be nice to see a dyno of a turboed 5vz to really compare the two. Gearing is always working for me on the low end too.
    There are a ton of factors for any situation..splitting hairs really. a 2jz would still be fun i think..
    what? How so...
  4. Oct 9, 2015 at 12:58 AM
    dakotasyota
    Dakota
    Ellensburg, WA
    Because constant boost? More pressure on the motor constantly... Right?
  5. Oct 9, 2015 at 4:56 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    My dyno numbers should be in next week. I'm keeping my fingers crossed, just in the hopes of getting good numbers......I'll keep you posted. Should be on the rollers getting the tune today at 10psi w/meth.
    dakotasyota likes this.
  6. Oct 9, 2015 at 5:20 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Superchargers dont provide constant boost any more than a turbo would.. superchargers have bypass valves to release the pressure built up. While they still will provide some air compression its not enough to overcome vaccum and actually be boost which is the same as a turbo continually spinning without building boost either.
    dakotasyota[QUOTED] likes this.
  7. Oct 9, 2015 at 6:03 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Debatable. You can abuse the engine as much as you want with either forced induction but generally, yes this is correct.
    The issue with the TRD s/c is it uses the old three lobe design which is very inefficient at higher RPM's. Boost is built two ways: Packing in air, and heating the air.
    I can't find the thread, but the stock TRD S/C intake temps at 5k rpms (~redline for 5VZ) are 300F over ambient (stock pulley mind you). After around 9psi, the S/C isn't building boost so much by moving more air but by supper heating the intake air. This is compounded by not having an intercooler; IMO meth injectors are a must for the S/C. Another $400-500 for you Monte :D
    Then there is the approx 30hp+ parasitic loss (I forgot the RPM's) from turning the S/C that puts an extra load on the engine.
    Lastly, for some reason, some 5VZ's will ping if you accelerate in high gear (high load, low RPM ping). This is why Toyota actually had a volunteer recall on the S/C. The URD kit does not tune closed loop, IIRC, and does not fix this. You need a piggy back and a good tune for closed loop operation to keep it from pinging.
    This is why I chose Turbo (and as Monte points out, its cheaper :D)
  8. Oct 9, 2015 at 8:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well. Everyone beat me too it. But yea superchargers don't boost all the time. My dads won't be cursing down the highway untill you hit a hill for example. It's using the bypass there.
    Yea the only real reason I would consider the supercharger is ease of install and reliability. But really all boost is going to affect the reliability. My dads throws codes all the time. Granted his is tweaked a bit more towards the edge than the average TRD blower but still.
  9. Oct 9, 2015 at 8:17 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    one nice thing about a roots style blower aka TRD is there isnt any pressured intake piping. i HATED dealing with pipe coupling blowing off from turbos..such an annoyance even with bead rolled pipes and tclamps
  10. Oct 9, 2015 at 8:45 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I think for the power goals, psi won't be much over 10-12 :notsure:
    The problem with turbo on these trucks is the maf. BOV makes it more complicated. If you tune the MAF and BOV release correctly it can be mitigated but I don't think BOV's are necessary.
    This guy is annoying AF but gets the point across pretty well. BOV's aren't needed :stirthepot:
    https://www.youtube.com/watch?v=ZnLv27EOWIo
  11. Oct 9, 2015 at 8:51 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i never had an issue with having a BOV and MAF on my 240sx, granted a different animal. But just re-route the bov pressure in behind the maf sensor so you dont lose metered air and itll help spool the turbo for the next gear :devil:
  12. Oct 9, 2015 at 9:01 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    A re route isn't totally necessary and doesn't always work.
    Ideally you would position the BOV before the MAF (MAF bt BOV and TB) and adjust it so when it releases you minimize air back flowing over the MAF. As long as you adjust the BOV spring so it doesn't dump to much too fast, you can maintain boost pressure and reduce/eliminate the pressure spikes.
    The MAF will always be an issue for boosted cars but as long as you do it right, you shouldn't have to worry about stalling the car.
  13. Oct 9, 2015 at 9:06 AM
    jkirkpatrick
    jkirkpatrick Well-Known Member
    Edmonton
    2018 4Runner TRD Offroad edition (2000 Tacoma sold in 2018)
    Lift, tires, wheels, bumper, winch, sliders, skids, regeared
  14. Oct 9, 2015 at 10:08 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    if you relocate a MAF between the turbo and throttle body you are measuring compressed air intake which isnt the true amount of air. its easier to leave the MAF right after the air filter and just have the bov route between the turbo inlet/maf. shouldnt have any pressure spikes unless your bov isnt fully functioning and letting off the "boost" in a timely manner.
  15. Oct 9, 2015 at 10:11 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I think there is guys on here boosting with 200k on the motor with no problems.
  16. Oct 9, 2015 at 11:32 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    @Blackdawg what was the specs on the turbo you were thinking about getting?
  17. Oct 9, 2015 at 11:34 AM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    There's a guy on instagram that swapped one into his single cab tacoma, and he changed the trans. I just figured you had to
  18. Oct 9, 2015 at 12:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's true. That will be tricky for me with the bumper.
    For autos BOVs aren't as needed. Manuals. Different story. I think they are pretty needed on a manual truck.
    I'm more curious as to why everyone puts the MAF after the turbo. No stock MAF turbo car is like that. My supra sure as hell wasn't.
    I'm considering getting rid of the MAF all together. Looking at using a MAP sensor which is more accurate and easier to tune anyways.
    I don't get that either..wouldn't be easy to put in front of the turbo anyways. Only about 2" in diameter.
    Billet 6262 with probably a .58 AR housing.
    Nope. Not if you want 4wd drive. Which I know you don't have anyways haha but still. Not needed. Just need an r154 bellhousing to bolt to our r150
  19. Oct 9, 2015 at 12:43 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    MAP FTW!
    whats 2" diameter? the air intake?
  20. Oct 9, 2015 at 12:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No the maf housing for our motors. Most turbos are 4" or 3".
    Yea map is much better. Just need to read more to see if its do able on our trucks.
