The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Dec 20, 2015 at 12:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    FRANK IS ALIVE!!!! HAHAHAHAAAA
    batteries where frozensolid . Thawed them out and they recharged no problem. Yellow tops ftw!
  2. Dec 20, 2015 at 12:13 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    What's the difference between the yellow tops and red tops never thought about it?!
  3. Dec 20, 2015 at 12:30 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Yellow tops are deep cycle, I need to swap in my yellow top in my truck.
  4. Dec 20, 2015 at 12:34 PM
    TacoVio
    Kolton
    CO/WY
    That's what I read but what does that exactly mean?
  5. Dec 20, 2015 at 1:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    A red tops life will be extremely shortened if youre constantly draining it near death and bringing it back to life. It is a starter battery as in it doesn't like to drop below 10.4ish volt ever.
    Vs a yellowtop that will do a total drain and recharge no problem. Well. To an extent. It handles the abuse much better anyways.
    Redneck92 likes this.
  6. Dec 20, 2015 at 1:10 PM
    TacoVio
    Kolton
    CO/WY
    That makes sense! So it's a better battery to run accessories off of too?!
  7. Dec 20, 2015 at 1:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea its better for a second battery for sure. I originally had a red for starter and yellow for second. But now I'm just dual yellows.
  8. Dec 20, 2015 at 1:15 PM
    TacoVio
    Kolton
    CO/WY
    I really want a dual battery setup but I need to learn more about electrical and what not first lol!
  9. Dec 20, 2015 at 1:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Beefing up the electrical system and dual batteries has paid for itself tenfold.
  10. Dec 20, 2015 at 1:24 PM
    TacoVio
    Kolton
    CO/WY
    I'm planing on doing the big 3 doesn't seem tOo hard and now that I pulled my motor I have more clarity where the wires go throughout the motor and what not! What amp alternator are you running?!
  11. Dec 20, 2015 at 1:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have a cs144 gm alternator. Is a 140 I think. But can do around 100 at idle
  12. Dec 20, 2015 at 2:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The advantage of the yellow top is that it can be deeply discharged repeatedly without damage and still be used as a starting battery. You do the same thing to a starting battery like a red top and it will eventually kill it.
    The yellow top still has limitations though. I think it is rated at 300+ deep discharges.
  13. Dec 20, 2015 at 2:29 PM
    TacoVio
    Kolton
    CO/WY
    That's quite a few discharges still lol!
  14. Dec 20, 2015 at 2:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Maybe. But I guess it depends on your perspective too.
    By comparison, both Northstar and Odessy rate their starting deep cycle batteries at 400+ discharge cycles to 80% capacity. But these two are significantly more expensive than a yellow top.
    In any case, an AGM type battery is definitely worth the investment.
  15. Dec 20, 2015 at 2:43 PM
    TacoVio
    Kolton
    CO/WY
    Now you guys are making me want one lol!
  16. Dec 20, 2015 at 3:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sorry dudes. My camera is dead so no super high quality photos for now..
    Anyways. Grabbed the smaller rack and it is perfect sized. Won't have to cut one of the big racks. But the hump the extended cab is throwing me off. Not totally sure what I'll do yet.
    Will work wonderfully for side led bar mounting if I et it to work.
    because_wumbo-truck likes this.
  17. Dec 20, 2015 at 4:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well this is gonna work great! Found some extra slide nuts in the tops of the main rails.
    Slapped me in the rails of the rack
    Found some bolts in the bin of Toyota bolts haha just a mass collection of bolts from working on them for so long haha used em to hold down the led bar bracket.
    Slapped on my old blitzpro 21" bars. Gonna Work awesome!
    Clears the small rails so you can adjust them if needed
    TheSpeediTurtle likes this.
  18. Dec 20, 2015 at 5:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea thought of that. But then the cross bars that are curved for the roof wouldn't be in contact. Just not sure Id like it raised like that.
  19. Dec 20, 2015 at 8:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Just modify the roofline. Take that stupid hump out. :cookiemonster:
  20. Dec 20, 2015 at 8:27 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    he already tried that :stirthepot:
    we can call the new one frank2.0
    Digiratus[QUOTED] likes this.
