The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Dec 23, 2015 at 6:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    SW is for star wars...I just don't understand what he is getting at..
  2. Dec 23, 2015 at 6:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I took it SW= South West :notsure:
  3. Dec 23, 2015 at 7:13 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  4. Dec 24, 2015 at 7:55 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
  5. Dec 27, 2015 at 8:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
  6. Dec 27, 2015 at 8:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Digiratus[QUOTED] likes this.
  7. Dec 28, 2015 at 9:20 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  8. Dec 28, 2015 at 9:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    A search turned up a link to an ebay sale for the same item and it was the same guy. Or at least the pics were identical. He was asking $450 on ebay.
  9. Dec 29, 2015 at 4:09 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Call him up and offer him $300 cash monies today. See how motivated he is to sell.
  10. Jan 2, 2016 at 11:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I see what you did there..
  11. Jan 2, 2016 at 11:23 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Ooooo another bumper build? Could it be?
  12. Jan 3, 2016 at 4:31 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    So :jellydance:
  13. Jan 4, 2016 at 1:24 PM
    j0shu4
    Hey man. Putting my front LT on next week. I have the week off work. I'm excited. Full Solo kit. Question. I'm swapping the front discs with the tundra set up. I was thinking about using my front discs on the t100 axle I have being set up for the rear. It has the same bolt pattern. Otherwise I'll have to buy new shoes and drums which I don't want to do. Is there a caliper mount that would work for this? I also have to press out the axles to put new bearings in. Can I get them out myself, then have a shop press them? Any input would be appreciated.
  14. Jan 4, 2016 at 1:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You can use the same drums off your stock axle. Just swap the axle shafts. What im going to do.
    I have not done axle bearings so I'm not sure if you can do them yourself. Think I've read you need a special tool for it.
    Only rear disc caliper mounts I know is the trail gear one.
    Still wouldn't go discs out back though.
  15. Jan 4, 2016 at 3:12 PM
    j0shu4
    I'm wanting to sell the axle when I swap. It's elocker. Not sure still what I want to do. My first priority is getting the front squared away. Thx man
  16. Jan 4, 2016 at 11:24 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Subbed....sick build:bowdown:
  17. Jan 4, 2016 at 11:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks!
    Some plans coming this summer once I graduate college and have cash flow again. And time.
  18. Jan 4, 2016 at 11:53 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    I finally graduate in May
  19. Jan 6, 2016 at 7:59 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Monte, going to do some maint on the truck this winter and plan on a new alt. Probably going to do this: Just wanted to pick your brain; what alt did you use?
  20. Jan 6, 2016 at 8:49 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    StAndrew[QUOTED] likes this.
