The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Jan 9, 2016 at 4:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I'm thinking I will pass on doing the Rubicon trail this year. The redhead is probably capable enough, not sure the driver is tho. And it doesn't seem worth it to me to risk breaking something that far from home. I not in a position to call someone with a tow rig if I did run into trouble.
    I'm am sure you'll be able to get a good group of guys together to join you in that adventure.
    :notsure:
    Maybe you should have if what we do is so boring in frank..
    Personally, I have found plenty of pucker factor in our past trips. I don't have a need to bump it up a notch.
  2. Jan 9, 2016 at 4:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I think you guys are over thinking rubi. It's not THAT bad. You don't have to do the hard lines and there are plenty of by passes..
    Id I where it went but ben posted and must've deleted it.
    Why not do rubi in August and then Utah for two weeks in oct late sept?
  3. Jan 9, 2016 at 5:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Id do two weeks in Utah. And week on rubi. And when I've said rubi I've always meant rubi plus trails around it. Or on the way. was pretty clear on that around the camp fire and other times. Just like we always do. How is that not like our normal trips??
    And yea right man. Not even I will do all the hard stuff on rubi. Come on. I don't have a death wish.
    And as for traffic. Probably be just like alpine loop area. Or whipsaw. But other trails will be more sparse I'm sure.
  4. Jan 9, 2016 at 5:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay, knew idea. Mike what do you want to do? Like where and how long. Same for you ben. I know you want to do Utah but what else?
    Also. Idk why we are talking about this in here haha we can go to the bs thread too
  5. Jan 9, 2016 at 6:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I will. I just want a computer first. Not in St. Louis till tomorrow
  6. Jan 9, 2016 at 6:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This seems as good a place to discuss this as any.
    I think you know what I want to do. I have been saying it. I want to go back to Canada. A 2 week adventure so 16 days including 2 days before and 2 days after for travel to and from.
    I would like to follow rickashay and explore the northern Canadian Rockies in and around Banff. At least to start with.
    It would be easy enough to do stuff leading up to such a trip. Like begin at Goose, follow it with Independence and then onto Glacier before heading into Canada. Or starting at Glacier and then adding on more after Banff, like working our way to central British Columbia, Prince George and beyond. I'm pretty sure it would be easy to fill up 2 weeks.
    I trip like this doesn't have to be in August but can't be too early in July either. It can be in September, as long as its before the winter weather starts.
  7. Jan 9, 2016 at 7:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea be easy to two week for Canada. But again. Finite amount of time for me to make money so two weeks off in August/September not very appealing to me. Canada is though. Have to sit on that.
    Another factor is that maybe ill get a job offering right off the bat or middle of summer..which would suck.
    I'm gonna look at rubi more too. But basically you and ben would rather go to Canada for two weeks then moab for a week. Noted
  8. Jan 9, 2016 at 8:47 PM
    jkirkpatrick
    jkirkpatrick Well-Known Member
    Edmonton
    2018 4Runner TRD Offroad edition (2000 Tacoma sold in 2018)
    Lift, tires, wheels, bumper, winch, sliders, skids, regeared
    Just to clear some misconceptions: Banff isn't the northern Canadian Rockies, it's south. :DAnd September "central" Rocky Mountain weather is like this :thumbsup::
    DSC_0005_7f47e7d4980267b12421c326ee9f23d11ed4161f.jpg :bananadance:
  9. Jan 9, 2016 at 8:48 PM
    jkirkpatrick
    Edmonton
    By the way, I love that you guys are discussing all your plans here. Let's me live vicariously through you!
    TacoVio likes this.
  10. Jan 9, 2016 at 8:52 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    :drool:
    TheSpeediTurtle likes this.
  11. Jan 9, 2016 at 8:58 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    @jkirkpatrick So is the region surrounding Panorama worth exploring? :cool:
  12. Jan 9, 2016 at 11:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks sweet!! I know it does tend to get cold in September. Does here anyways. That's archery season here. Used to start snowing sometimes on us. But not usually till oct
  13. Jan 10, 2016 at 7:06 AM
    jkirkpatrick
    Edmonton
    I've never wheeled down there, so I can't say. Most of my wheeling is up toward Robb or Rocky Mountain House.
    You could join untitledoffroad.com. That's a group local to Calgary. They'll know the southern Rockies best. I haven't wheeled with them yet, but I hope to get out with them sometime next summer.
    SconnieHailer[QUOTED] likes this.
  14. Jan 10, 2016 at 10:05 AM
    jkirkpatrick
    Edmonton
    If you guys do make it up here (central Rockies, not southern Rockies) this summer, there's a couple of us that would be able to take you out for a couple of days. The area would be the same as those pictures I posted.
  15. Jan 10, 2016 at 9:20 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That whole trip was tits
    Soooo much fun! Colorado has so much great things to offer!
    I'm following your guys banter on the trips so I can see what you're thinking of doing and where I'll be during theow times :)
  16. Jan 10, 2016 at 9:40 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm basically doing the same, seeing if any of this would be possible for me. Canada looks like a blast and Moab is on my list too.
    Digiratus likes this.
  17. Jan 11, 2016 at 12:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You ran holy cross right? Or did Slugo break before that...
  18. Jan 11, 2016 at 5:08 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Sluggo was one of the only 2 or 3 rigs that never needed a winch. I was using someone else's spre 35 but that's besides the point :)
  19. Jan 11, 2016 at 5:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha nice! I really wanna do it. Looks super fun.
  20. Jan 11, 2016 at 8:29 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    It was awesome! Solid challenge! Id give it a 7+ out of 10. If you're in the back and everyone rutted it out before you (Dylan lol) 8+ with the "easy" lines. There are a couple hard options with a 10+ section at the very end.
    I want to do chinaman gulch bad to.
    Def love the MTN trails there more than idaho
