The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Feb 12, 2016 at 7:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea but could still have 2-4 months in wyo if im in MT for that one gig...sooo...yea..idk.
  2. Feb 15, 2016 at 7:39 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Are you going to Mt for that gig? I may have missed that..
  3. Feb 15, 2016 at 7:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Highly possible. It'll through my summer plans off a lot. But it's too good. Unless I get a gig in la I'll probably do that.
  4. Feb 15, 2016 at 7:50 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    What area?
  5. Feb 15, 2016 at 7:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  6. Feb 15, 2016 at 7:53 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Awesome man, knew you had some sort of jobs lined up but thats sweet. Beautiful area.
  7. Feb 15, 2016 at 7:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. Sadly it's only 6 weeks. Not a full time gig. But still a good 6weeks
  8. Feb 15, 2016 at 8:04 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    For sure, enjoy it.
  9. Feb 15, 2016 at 8:24 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Monte what exactly do you do? Something with music?
  10. Feb 15, 2016 at 8:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. Not just music though. Audio engineering. But currently, other then school, I work at the St. Louis symphony with the company that does the audio for them. We record them almost every week and a radio broadcast. We do a jazz club too whenever a client wants a recording. And location stuff.
    But I really hope to stay in music. Even though that's slim chances. The music industry is just too bad right now to break into. Movie music would be my ultimate goal.
    But there's tons of stuff in the audio world.
    gray223[QUOTED] and FirstGen Jer like this.
  11. Feb 18, 2016 at 1:47 PM
    1stgenyota2014
    1stgenyota2014 Well-Known Member
    Garrett
    2004 ext cab Black Tacoma
    Flatbed, OME springs, 5100 billies
    Blackdawg have you had to replace cv axle seals? I didn't see a link to it on the first page so I was wondering if you have one or know of a good write up of replacing cv axle seals
  12. Feb 18, 2016 at 2:52 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I don't know if @Blackdawg has but I know @EB Group has, I'd PM him.
  13. Feb 18, 2016 at 3:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you asking about the rubber boots on the cv axles or front diff seals?
  14. Feb 18, 2016 at 6:41 PM
    1stgenyota2014
    Garrett
    Sorry should've specified, I'm talking about diff seals.
  15. Feb 18, 2016 at 6:48 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I dont know of a write up but the seals themselves are fairly easy. Use a bearing puller or seal puller to get them out becuase they are a tight fit. Then find a socket big enough to fit the outer edge of the seal to hit it back in. Not much to it.
  16. Feb 18, 2016 at 6:50 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    just don't do what the previous owner did trying to get a rear axle seal in my truck
  17. Feb 18, 2016 at 7:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have replaced the passenger side one. Twice. Once because it was leaking. And once because I put it in backwards :anonymous:
    It's pretty straight forward though. Only tip Id say is to tap in the seal but not too far. Get it in there and then use the cv to push it where it needs to sit. Other wise it'll go too far in.
  18. Feb 18, 2016 at 7:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    When I replace my axles, should I just figure on new seals at that time? Or just wait for a leak? 155K on the originals now.
  19. Feb 18, 2016 at 9:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wouldn't worry unless it starts to leak. I'll be a slow leak too.
    Digiratus[QUOTED] likes this.
  20. Feb 19, 2016 at 6:25 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I believe the way we did it for the passenger side was put the seal on the CV first before we put it in. Helped bring the seal to the right depth without going too far.
    PcBuilder14 likes this.
