The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Aug 5, 2016 at 6:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Where I'm gonna put mine. Hopefully
  2. Aug 5, 2016 at 7:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn. Runs good. So far. Need to tweak my throttle bracket more. Cable keeps catching and making it idle high.
    SconnieHailer likes this.
  3. Aug 5, 2016 at 7:20 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I put mine on the passenger kick panel. Not win afraid of getting water in the cab and fucking it up lol. Do not wanna solder those wires again though haha
  4. Aug 5, 2016 at 7:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I just put mine up above the ecu. Turned out good. Still have access to the port to tune later.
  5. Aug 5, 2016 at 8:35 PM
    anthony250f
    Anthony
    San Diego, CA
    Can you get to it without removing anything
  6. Aug 5, 2016 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. I'll probably get a cable and just leave it attached.
    Just test drove it. Is more power. But not that much. Not that impressed really. I don't have gauges yet so no way of monitoring to see if something is screwy. Also don't have 91 octane in yet. Still was expecting a tad more. My dads is much faster. But power boost is nice. But I was hoping for more
  7. Aug 5, 2016 at 9:15 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    ....but does it sound good? :D
    YotaOverAll and Blackdawg[OP] like this.
  8. Aug 5, 2016 at 9:20 PM
    anthony250f
    Anthony
    San Diego, CA
    Hmm odd. Mine was like night and day difference. Hauls ass. You can measure the boost from the urd and a laptop if you don't have a gauge
  9. Aug 5, 2016 at 9:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes!
    Hmm..
    I wouldn't say it hauls ass. Goes. But not crazy.
  10. Aug 6, 2016 at 11:56 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    More pictars!! Can you change the boost level on a SC (other than changing the pulley)?
  11. Aug 6, 2016 at 12:25 PM
    anthony250f
    Anthony
    San Diego, CA
    No. You could gain a pound or so if you tune good
  12. Aug 6, 2016 at 12:54 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I didn't think so. In that case, 91 octane shouldn't make a difference... if it doesn't knock on regular pump gas, there's no need for 91.
  13. Aug 6, 2016 at 1:37 PM
    anthony250f
    Anthony
    San Diego, CA
    I only run 91. Runs better and less knock
    j0shu4 likes this.
  14. Aug 7, 2016 at 4:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just got back. Frank drove fine. Sorta.
    I am not happy with this fucking blower. I have less power now then I did before it. Thought it was my ECU as the 96 doesn't like boost. I swapped it with a 97 and ran the same if not worse. Unplugged the 7th injector and ran a bit better but barely.
    I can't pull hills in 4th anymore and I could accelerate up them in 5th before. Seriously considering pulling it and selling it.
    On top of that. My. 4wd will not engage. Thank god I had a locker. Carrier bearing needs replaced. Clutch is starting to go as well.
  15. Aug 7, 2016 at 4:38 PM
    anthony250f
    Anthony
    San Diego, CA
    I'm pretty close to selling mine too honestly LOL. If the clutch is almost out the sc is gonna rape it.
  16. Aug 7, 2016 at 4:38 PM
    anthony250f
    Anthony
    San Diego, CA
    You could have a huge boost leak
  17. Aug 7, 2016 at 4:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Carrier bearing? In the diff? Or center support bearing in the middle of the rear driveshaft?
  18. Aug 7, 2016 at 4:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Maybe. The part on the back by the bypass valve moves. Not sure if it is supposed too
  19. Aug 7, 2016 at 4:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Drive shaft one.
    And my cvt tent cover zipper is fucked.
  20. Aug 7, 2016 at 4:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not ideal, but I drive around with mine unzipped for a while. The straps held it covered pretty good, even on the highway.
