The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Aug 10, 2016 at 11:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well if you can somehow show me the full map Id greatly appreciate it. Was banking on getting the file as I'm leaving for Canada on Friday.
  2. Aug 10, 2016 at 11:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I hope it works good. Says 01-04 only..but I'll make it work.
  3. Aug 10, 2016 at 11:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    @anthony250f i figured it out.
    Right click on the file and click rename. Delete the .mdb extension and replace it with .txt
    Should be able to send it that way or upload directly here. Email should work for sure though
    And then change it back to .mdb when you're done
  4. Aug 10, 2016 at 11:25 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Any recommendations on a wide band gauge or what to stay away from as far as brands go?
  5. Aug 10, 2016 at 11:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Don't go cheap basically. I'm an AEM fan. Innovation performance and..zenntronix? I think are good too.
    BossFoss[QUOTED] likes this.
  6. Aug 11, 2016 at 8:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    @anthony250f wpuld you be able and willing to attempt send me the file using the above process tonight?
  7. Aug 11, 2016 at 8:32 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yeah just got home sorry. Gonna try to do what you said right now
  8. Aug 11, 2016 at 8:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thank you so much man
  9. Aug 11, 2016 at 8:43 PM
    anthony250f
    Anthony
    San Diego, CA
    couldnt figure out how to change it to .txt but i emailed you the file. see if it opens ok
  10. Aug 11, 2016 at 8:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I got it! I'll see what happens. Trying now
  11. Aug 11, 2016 at 9:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn. Didn't change. Still gets choked off hard at 3k under boost
  12. Aug 11, 2016 at 9:16 PM
    anthony250f
    Anthony
    San Diego, CA
    Gotta be something else then cause that's when mine really picks up
  13. Aug 11, 2016 at 9:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Its the hoodoo I put on it. :D I want the redhead to be able to still keep up...
  14. Aug 11, 2016 at 9:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well now anything can keep up. I cant go above 3k hardly.
  15. Aug 11, 2016 at 9:31 PM
    anthony250f
    Anthony
    San Diego, CA
    Was it that bad with the other ecu?? I'm thinking wiring
  16. Aug 11, 2016 at 9:31 PM
    anthony250f
    Anthony
    San Diego, CA
    Fuel filter clogged or old?
  17. Aug 11, 2016 at 9:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mm..yea was pretty similar. Think it worse with the newer one.
    Fuel filter has 130-135k on it. Think I have one laying around I can put in.
  18. Aug 11, 2016 at 9:44 PM
    anthony250f
    Anthony
    San Diego, CA
    Try that. Might be getting clogged with boost.
  19. Aug 11, 2016 at 9:59 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I think he needs more duct tape on his airbox
    Digiratus likes this.
  20. Aug 11, 2016 at 10:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :facepalm::smack: This is serious binnis
