The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Sep 25, 2016 at 7:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Mm. Idk. Id do it separate. That way the glare guard can swivel with the bar.
  2. Sep 25, 2016 at 8:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea but you still need to angle the light so it not pointing up too high or down too low.
    If you make the shield ridged then you'll need a big gap between it and the bar in order to allow play in the bar to set the beam.
    If you make it separate. You can make it hug the led bar and rotate with it.
    You don't need to over build a freaking led bar mount. The led bar makes it one huge solid structure.
    Stop being an engineer and overthinking this haha
  3. Sep 25, 2016 at 8:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Now that's called stealing ben. Haha
    Yea and Id be care with the guard. You won't want it too wide or the bar would get sucked down enough.
  4. Sep 25, 2016 at 8:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's just sheet metal screws drilled into the a pillar. I'll take photos later
  5. Oct 10, 2016 at 10:11 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    How in the world did this truck not get into the calendar...:goingcrazy: lol
  6. Oct 10, 2016 at 10:23 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha idk. No biggie though.
    gray223[QUOTED] likes this.
  7. Oct 10, 2016 at 9:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Haha. Frank in a beauty pageant? Nope! :rofl:
    Blackdawg[OP] likes this.
  8. Oct 11, 2016 at 8:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. Oct 11, 2016 at 8:44 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    When it's running right... :rofl:
  10. Oct 11, 2016 at 8:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :brianr:
  11. Oct 11, 2016 at 8:51 AM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Haha! Such cheerful banter in here.
  12. Oct 11, 2016 at 9:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So when you guys gonna finally do some 1st gen stuff :boink:
    TheSpeediTurtle and fiziks like this.
  13. Oct 11, 2016 at 9:16 AM
    mh.meier
    The Doctor
    Commiefornia
    Once we are done with the stuff for the 2016+ we will be hitting come older stuff including possibly the LC
    TheSpeediTurtle likes this.
  14. Oct 11, 2016 at 9:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice. Look forward too it. Igor could use some bumpers.
  15. Oct 11, 2016 at 9:23 AM
    mh.meier
    The Doctor
    Commiefornia
    We are too. I know Tyler is looking forward to being able to have more time to design and get other products out there.
  16. Oct 11, 2016 at 9:27 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    man if i was closer. Id drop him off for you guys to use. haha Actually, how close to Tuscon are you?
  17. Oct 11, 2016 at 10:18 AM
    mh.meier
    The Doctor
    Commiefornia
    I am in Flagstaff but they are about 5 hours from Tucson I would venture
  18. Oct 11, 2016 at 10:52 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Frank isn't straight enough to design off anyway...
  19. Oct 11, 2016 at 10:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah okay. Might be down in Tuscon later but not sure yet.
    Talking about igor!
    Because that is probably true :anonymous:
  20. Oct 11, 2016 at 1:55 PM
    SconnieHailer
    Marc
    Haha ahh Igor. Makes more sense now
